IllegalStateException thrown by Dali [message #491950] |
Fri, 16 October 2009 13:19  |
Using Dali, I created entities from the database tables and renamed most of the fields from a "database" name to a "java" name. Everything worked fine without issues.
However, the DBA added several tables and removed several others. The next time I ran the 'entities from tables' wizard again, I get the exception below and the wizard doesn't move past the first page.
I'm guessing that it's because the entitygen cache file (in .settings) has references to tables to that do not exist anymore. Is there any way I can hack on the file to remove the references?
Dan
EXCEPTION:
java.lang.IllegalStateException
at java.util.AbstractList$Itr.remove(AbstractList.java:356)
at org.eclipse.jpt.gen.internal2.ORMGenCustomizer.addForeignKey Associations(ORMGenCustomizer.java:693)
at org.eclipse.jpt.gen.internal2.ORMGenCustomizer.addForeignKey Associations(ORMGenCustomizer.java:643)
at org.eclipse.jpt.gen.internal2.ORMGenCustomizer.getAssociatio ns(ORMGenCustomizer.java:619)
at org.eclipse.jpt.gen.internal2.ORMGenCustomizer.getAssociatio ns(ORMGenCustomizer.java:419)
at org.eclipse.jpt.ui.internal.wizards.gen.TableAssociationsWiz ardPage.updateAssociationsListPanel(TableAssociationsWizardP age.java:562)
at org.eclipse.jpt.ui.internal.wizards.gen.TableAssociationsWiz ardPage.setVisible(TableAssociationsWizardPage.java:290)
at org.eclipse.jface.wizard.WizardDialog.updateForPage(WizardDi alog.java:1171)
at org.eclipse.jface.wizard.WizardDialog.access$2(WizardDialog. java:1149)
at org.eclipse.jface.wizard.WizardDialog$5.run(WizardDialog.jav a:1138)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.jface.wizard.WizardDialog.showPage(WizardDialog. java:1136)
at org.eclipse.jface.wizard.WizardDialog.nextPressed(WizardDial og.java:830)
at org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:369)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:624)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:228)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3493)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3112)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.jpt.ui.internal.platform.base.EntitiesGenerator2 .generate(EntitiesGenerator2.java:64)
at org.eclipse.jpt.ui.internal.platform.base.EntitiesGenerator2 .generate(EntitiesGenerator2.java:39)
at org.eclipse.jpt.ui.internal.platform.base.BaseJpaPlatformUi. generateEntities(BaseJpaPlatformUi.java:288)
at org.eclipse.jpt.ui.internal.actions.GenerateEntitiesAction.e xecute(GenerateEntitiesAction.java:24)
at org.eclipse.jpt.ui.internal.actions.ProjectAction.execute(Pr ojectAction.java:87)
at org.eclipse.jpt.ui.internal.actions.ProjectAction.execute(Pr ojectAction.java:63)
at org.eclipse.jpt.ui.internal.actions.ProjectAction.run(Projec tAction.java:55)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
FUDForum. Page generated in 0.03995 seconds
