Home » Eclipse Projects » Remote Application Platform (RAP) » deploy my RAP-App as War-File
deploy my RAP-App as War-File [message #491434] Wed, 14 October 2009 10:51 Go to next message
Hi everybody.
I want to deploy my RAP-Application as war-File and get the Following Error:
eclipse.core.runtime.compatibility.registry_0.0.0 failed to resolve.:Host plug-in org.eclipse.equinox.registry_[3.3.0,3.5.0) has not been found.
I don't understand the error, becaus the target- and the eclipse-version contains "org.eclipse.equinox.registry_3.5.0.v20090911.jar"
I'm using Eclipse Galileo Build id: 20090920-1017 and the RAP Target 1.3 M2 (with some Birt Plugins).
Thank you in advance
Olli
Re: deploy my RAP-App as War-File [message #491438 is a reply to message #491434] Wed, 14 October 2009 11:00 Go to previous messageGo to next message
Hi Oliver,
did you follow the guide from RAP documentation [1]?
[1]
http://help.eclipse.org/galileo/index.jsp?topic=/org.eclipse .rap.help/help/html/advanced/deployment.html
Best,
Ivan
Oliver Koch wrote:
> Hi everybody.
> Error:
> not been found.
> Olli
Re: deploy my RAP-App as War-File [message #491584 is a reply to message #491438] Thu, 15 October 2009 03:46 Go to previous messageGo to next message
Good Morning,
to deploy my WebApp i follow the guid from the documentation [1] and the Tutorial from the RAP-Blog [2].
However, I have now thrown out "eclipse.core.runtime.compatibility.registry" from the feature.xml (Is this needed at all?). PDE-Exports runs through without any problems. But if I deploys my war-File now on Tomcat 6.x, I get some bad errors in the tomcat-console:
org.osgi.framework.BundleException: The bundle could not be resolved. Reason: Missing Constraint: Require-Bundle: org.eclipse.equinox.http.registry; bundle-version="1.0.100"
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolverError(AbstractBundle.java:1313)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.getResolutionFailureException(AbstractBundle.java:1297)
	at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:319)
	at org.eclipse.osgi.framework.internal.core.AbstractBundle.resume(AbstractBundle.java:370)
	at org.eclipse.osgi.framework.internal.core.Framework.resumeBundle(Framework.java:1068)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.resumeBundles(StartLevelManager.java:554)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.incFWSL(StartLevelManager.java:461)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.doSetStartLevel(StartLevelManager.java:246)
	at org.eclipse.osgi.framework.internal.core.StartLevelManager.dispatchEvent(StartLevelManager.java:442)
	at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:227)
	at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread.run(EventManager.java:337)
And so on, over all PlugIns...
[2] http:// eclipsesource.com/blogs/2007/12/07/rap-deployment-part-2-dep loying-your-application-as-a-war-file/
Re: deploy my RAP-App as War-File [message #491664 is a reply to message #491584] Thu, 15 October 2009 08:22 Go to previous messageGo to next message
Hi Oliver,
you |have to ensure that all needed bundles (and their dependencies) are
available in|:
1. feature.xml
2. |config.ini
3. "build\webapp\WEB-INF\eclipse\plugins" after PDE export||.
To debug the problem enable the osgi console in web.xml. Use "ss"
command in osgi console to list all bundles and their status or "diag
<bundle no>" for the reason why the bundle is not active.
Best,
Ivan
Oliver Koch wrote:
> Good Morning,
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolverError(AbstractBundle.java:1313)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.getR esolutionFailureException(AbstractBundle.java:1297)
> at
> org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:319)
> at
> org.eclipse.osgi.framework.internal.core.AbstractBundle.resu me(AbstractBundle.java:370)
> at
> org.eclipse.osgi.framework.internal.core.Framework.resumeBun dle(Framework.java:1068)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.r esumeBundles(StartLevelManager.java:554)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.i ncFWSL(StartLevelManager.java:461)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.d oSetStartLevel(StartLevelManager.java:246)
> at
> org.eclipse.osgi.framework.internal.core.StartLevelManager.d ispatchEvent(StartLevelManager.java:442)
> at
> org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEve nt(EventManager.java:227)
> at
> org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:337)
> [2]
> http://eclipsesource.com/blogs/2007/12/07/rap-deployment-par t-2-deploying-your-application-as-a-war-file/
Re: deploy my RAP-App as War-File [message #491679 is a reply to message #491664] Thu, 15 October 2009 09:21 Go to previous messageGo to next message
Okay....
I checked it all and it seem to be okay, but the errors continued to exist. Then I noticed that in the Run-Configuration my "*.rap" and "*.nl1" fragments are configured with "AutoStart=false".
I changed the config.ini in this way (delete "@start") and it works right away. Never read something like this in the newsgroup or the help...
Here is my config.ini:
#Eclipse Runtime Configuration File
osgi.bundles=  com.ibm.icu.base@start,\
  com.ibm.icu@start,\
  de.xyz.KomLag.nl1,\
  de.xyz.KomLag.rap,\
  de.xyz.KomLag@start,\
  de.xyz.kunden.KomLag@start,\
  de.xyz.maskenbasis.nl1,\
  de.xyz.maskenbasis.rap,\
  de.xyz.maskenbasis@start,\
  org.eclipse.core.commands@start,\
org.eclipse.equinox.servletbridge.extensionbundle
osgi.bundles.defaultStartLevel=4
The problems seem to be solved Very Happy .
Thank you anyway for your help Ivan.
Olli
Re: deploy my RAP-App as War-File [message #492142 is a reply to message #491679] Mon, 19 October 2009 02:20 Go to previous messageGo to next message
Hi Everybody
My App, now, runs fine in the Tomcat.
But.... Very Happy
You'll not see one single Picture!!!!!
Yes I added them all in the build.properties File and the Jar-File contains them all. I debugged, with Remote Debbuging, my RAP-App in the Tomcat and the Object splash existet (see Code Snippet). Of course, in Eclipse/Jetty everything works fine.
Image splash = Activator.getImageDescriptor("/splash.bmp").createImage();
Re: deploy my RAP-App as War-File [message #492392 is a reply to message #492142] Tue, 20 October 2009 06:36 Go to previous messageGo to next message
Hi Oliver,
maybe omitting the preceding slash helps?
Stefan.
Oliver Koch schrieb:
> Hi Everybody
> But.... :d You'll not see one single Picture!!!!!
Re: deploy my RAP-App as War-File [message #492396 is a reply to message #492142] Tue, 20 October 2009 06:47 Go to previous messageGo to next message
Oliver,
how do you use the images? Did you use any hard-coded paths to access
the image resources?
Ben
Oliver Koch wrote:
> Hi Everybody
Benjamin Muskalla | EclipseSource Karlsruhe
http://www.eclipsesource.com | http://twitter.com/eclipsesource
Re: deploy my RAP-App as War-File [message #492407 is a reply to message #492396] Tue, 20 October 2009 07:18 Go to previous messageGo to next message
@Stefan
I try with and without the slash, it has the same effect.
@Benjamin
I use Paths such as in this example:
public static final String ICONS_PATH = "resources/icons/";
public static final String ICO_PRINTER = ICONS_PATH + "printer.png";
But like I said, I have debugged the App and the Object splash (from my other example) exists and knows the right height and wide of the Image. It just won't display it Sad.
Re: deploy my RAP-App as War-File [message #492411 is a reply to message #492407] Tue, 20 October 2009 07:23 Go to previous messageGo to next message
But how do you use the images? In SWT widgets (eg. Buttons, Toolbars,
...) or do you use them in another context like in a SWT Browser widget
or in the branding?
Another thing you could check is what happens on the client side. For
example you could use FireBug [getfirebug.com] to see what happens with
the HTTP requests for the images.
Ben
Oliver Koch wrote:
> @Stefan
> @Benjamin
> It just won't display it :(.
Re: deploy my RAP-App as War-File [message #492424 is a reply to message #492411] Tue, 20 October 2009 08:16 Go to previous messageGo to next message
I use the images in Labels:
lbl_Splash = new PSB_Label(cmp_Middle, SWT.CENTER);
Image splash = Activator.getImageDescriptor("splash.bmp").createImage();
lbl_Splash.setImage(splash);
In ToolItems:
ToolItem clearSearch = new ToolItem(toolBar, SWT.PUSH);
clearSearch.setImage(Activator.getImageDescriptor(IKomLagImages.ICO_CROSS).createImage());
or my own Extensions for Actions
<!-- plugin.xml -->
<RefreshAction
            Icon="resources/icons/arrow_refresh.png"
            name="Refresh">
</RefreshAction>
etc...
I used Firebug, as you have recommended.
All HTTP-Request for Images results in 404 Errors. The URL's of the Requests are for example:
http://127.0.0.1:8080/KomLag/rwt-resources/4.fwk6658066/resources/img/splash_300x225.png
http://127.0.0.1:8080/KomLag/rwt-resources/themes/Custom_1/widgets/tree/start_minus.gif
pffff...... Confused
Benjamin Muskalla wrote on Tue, 20 October 2009 07:23
or in the branding?
Ben
Re: deploy my RAP-App as War-File [message #492447 is a reply to message #492424] Tue, 20 October 2009 08:58 Go to previous messageGo to next message
Oliver,
those paths look good. If all images (including theme images) are
missing then I suppose that your problem is somehow related to resource
registration. Could you please post the output of the ss command in your
OSGi console? You should also enable the -consolelog parameter in your
web.xml to track errors.
Regards, Ralf
> In ToolItems:
> clearSearch.setImage(Activator.getImageDescriptor(IKomLagIma ges.ICO_CROSS).createImage());
> <!-- plugin.xml -->
> <RefreshAction
> name="Refresh">
> </RefreshAction>
> etc...
> http://127.0.0.1:8080/KomLag/rwt-resources/4.fwk6658066/reso urces/img/splash_300x225.png
> http://127.0.0.1:8080/KomLag/rwt-resources/themes/Custom_1/w idgets/tree/start_minus.gif
> pffff...... :?
>> widget or in the branding?
>> with the HTTP requests for the images.
>> Regards,
>> Ben
Re: deploy my RAP-App as War-File [message #492452 is a reply to message #492447] Tue, 20 October 2009 09:46 Go to previous messageGo to next message
Here is the output from the ss command in the OSGI-console in Tomcat 6.x:
id      State       Bundle
0       ACTIVE      org.eclipse.osgi_3.6.0.v20090914
                    Fragments=40
1       ACTIVE      com.ibm.icu.base_4.0.1.v20090415
2       RESOLVED    de.xyz.KomLag.nl1_1.0.0.20091012
                    Master=4
3       RESOLVED    de.xyz.KomLag.rap_1.0.0.20091012
                    Master=4
4       ACTIVE      de.xyz.KomLag_1.0.0.20091012
                    Fragments=2, 3
5       ACTIVE      de.xyz.kunden.KomLagPsb_1.0.0.20091012
6       RESOLVED    de.xyz.maskenbasis.nl1_1.0.0.20091012
                    Master=8
7       RESOLVED    de.xyz.maskenbasis.rap_1.0.0.20091012
                    Master=8
8       ACTIVE      de.xyz.maskenbasis_1.0.0.20091012
                    Fragments=6, 7
9       ACTIVE      org.apache.commons.logging_1.0.4.v200904062259
10      ACTIVE      org.eclipse.core.commands_3.5.0.I20090525-2000
11      ACTIVE      org.eclipse.core.contenttype_3.4.100.v20090831
12      ACTIVE      org.eclipse.core.databinding.beans_1.2.0.I20090525-2000
13      ACTIVE      org.eclipse.core.databinding.observable_1.3.0.I20090901-0800
14      ACTIVE      org.eclipse.core.databinding.property_1.2.100.I20090825-0800
15      ACTIVE      org.eclipse.core.databinding_1.3.0.I20090825-0800
16      ACTIVE      org.eclipse.core.expressions_3.4.100.v20090429-1800
17      ACTIVE      org.eclipse.core.jobs_3.4.100.v20090429-1800
18      ACTIVE      org.eclipse.core.runtime_3.5.100.v20090911
19      ACTIVE      org.eclipse.equinox.app_1.2.0.v20090520-1800
20      ACTIVE      org.eclipse.equinox.common_3.5.100.v20090817
21      ACTIVE      org.eclipse.equinox.http.jetty_2.0.0.v20090520-1800
22      ACTIVE      org.eclipse.equinox.http.registry_1.0.200.200910201527
23      ACTIVE      org.eclipse.equinox.http.servletbridge_1.0.100.v20090306-1900
24      ACTIVE      org.eclipse.equinox.http.servlet_1.0.200.200910201527
25      ACTIVE      org.eclipse.equinox.preferences_3.2.300.v20090520-1800
26      ACTIVE      org.eclipse.equinox.registry_3.5.0.200910201527
27      ACTIVE      org.eclipse.help_3.5.0.v20090729
28      ACTIVE      org.eclipse.osgi.services_3.2.0.v20090520-1800
29      ACTIVE      org.eclipse.rap.jface.databinding_1.3.0.20090929-1121
30      ACTIVE      org.eclipse.rap.jface_1.3.0.20090929-1121
31      RESOLVED    org.eclipse.rap.rwt.q07_1.3.0.20090929-1121
                    Master=32
32      ACTIVE      org.eclipse.rap.rwt_1.3.0.20090929-1121
                    Fragments=31
33      ACTIVE      org.eclipse.rap.ui.cheatsheets_1.3.0.20090929-1121
34      ACTIVE      org.eclipse.rap.ui.forms_1.3.0.20090929-1121
35      ACTIVE      org.eclipse.rap.ui.views_1.3.0.20090929-1121
36      ACTIVE      org.eclipse.rap.ui.workbench_1.3.0.20090929-1121
37      ACTIVE      org.eclipse.rap.ui_1.3.0.20090929-1121
38      ACTIVE      org.mortbay.jetty.server_6.1.15.v200905151201
39      ACTIVE      org.mortbay.jetty.util_6.1.15.v200905182336
40      RESOLVED    org.eclipse.equinox.servletbridge.extensionbundle_1.0.0
                    Master=0
Re: deploy my RAP-App as War-File [message #492583 is a reply to message #492452] Tue, 20 October 2009 16:49 Go to previous messageGo to next message
Hi Oliver,
you're deploying a Jetty into Tomcat, so you have two concurrent servlet
containers running. I'm not sure about the consequences, but that
probably won't go well. You should leave out equinox.http.jetty and the
mortbay.jetty bundles.
Best regards, Ralf
> id State Bundle
> Fragments=40
> Master=4
> Master=4
> Fragments=2, 3
> Master=8
> Master=8
> Fragments=6, 7
> 13 ACTIVE
> 14 ACTIVE
> 23 ACTIVE
> org.eclipse.equinox.http.servletbridge_1.0.100.v20090306-190 0
> Master=32
> Fragments=31
> Master=0
icon14.gif  Re: deploy my RAP-App as War-File [message #492620 is a reply to message #492583] Wed, 21 October 2009 02:55 Go to previous message
Good Morning,
I tried it and it worked right away Very Happy . The next time I think more about which plugin I should add Rolling Eyes .
I thank you all for your help.
Best Regards
Olli
Previous Topic:Suspend Upload with Upload Widget
Next Topic:TrayDialog and HelpTray
Current Time: Mon Jul 21 10:47:00 EDT 2025
Powered by FUDForum. Page generated in 0.37052 seconds
