| failed to take query results from kenai/jira server [message #68737] |
Mon, 04 May 2009 14:55  |
Originally posted by: l.uncu.isnet.net.tr
hey fellas, im trying to use mylyn in eclipes, i add https://kenai.com/jira
with username and password
after doing this operation it can take web based query names, as a result
when i shoose query name to take tasks, it s waiting on %22 and its never
done,
after all, when i try to add new task ,its waiting in updating repository
configuration almost forever.
i know im a newbie, i might be do some mistakes in configuration . please
help me to fix these problems
| Re: failed to take query results from kenai/jira server [message #68817 is a reply to message #68758] |
Tue, 05 May 2009 14:39   |
thanks for answer.
"George Lindholm" <gnl@ballroomdancemusic.info>, iletisinde şunu yazdı,
news:gtnfbn$m9k$1@build.eclipse.org...
>> https://kenai.com/jira with username and password
>> result when i shoose query name to take tasks, it s waiting on %22 and
>> its never done,
>> repository configuration almost forever.
>> please help me to fix these problems
> May be related to https://bugs.eclipse.org/bugs/show_bug.cgi?id=247912
> since the kenai Jira is at 1.13.1
> This fixed something similar for me:
> steffen.pingel@tasktop.com wrote:
>> > Please try to disable compression on the task repository properties
>> > page or
>> > update your JIRA server to the latest version.
| Re: failed to take query results from kenai/jira server [message #597554 is a reply to message #68737] |
Mon, 04 May 2009 15:23  |
> its never done,
> > Please try to disable compression on the task repository properties page or
| Re: failed to take query results from kenai/jira server [message #597568 is a reply to message #68758] |
thanks for answer.
>> its never done,
>> > page or
| Re: failed to take query results from kenai/jira server [message #598967 is a reply to message #68817] |
Mon, 31 August 2009 21:10  |
The Bugzilla entry is still open, so this is still unsolved I assume.
I found earlier posts at kenai.com which we just launched as a JSR host for
my Expert Group at JCP.org.
While Bugzilla was offered as the probably more mature alternative, we
decided to give JIRA a try (also cause it has more advanced options and
features at least in the web interface for now ;-)
Hope, whatever side needs to fix that (JIRA itself, Kenai.com or the Mylyn
connector for JIRA ?!) does that?
The still pretty incubation stage connector for HP Quality Center almost 5
years after Mylyn started is probably a bad example for a fairly common
product still not being able to use Mylyn ;-/
(of course that makes our work at Babel easier if there are only limited
connectors at least those officially supported by Eclipse.org ;-)
Werner
| Re: failed to take query results from kenai/jira server [message #599052 is a reply to message #483313] |
Thu, 10 September 2009 11:38  |
> 5 years after Mylyn started is probably a bad example for a fairly
> common product still not being able to use Mylyn ;-/
The Mylyn project does not have the staffing to implement AND MAINTAIN
connectors for commercial issue trackers, like HP Quality Center.
I think that requests for the latter should be directed at HP, not the
Mylyn project. There may be contributors or committers willing to work
on such a connector for profit.
The Mylyn project does not even have the staffing to accept donations of
additional connectors for OSS issue trackers or toolkit like systems,
unfortunately since I created one.
The current set of connectors is provided as examples and for providing
feedback to eclipse.org itself.
Maarten
| Re: failed to take query results from kenai/jira server [message #599730 is a reply to message #485149] |
Sun, 18 October 2009 15:41  |
Well I noticed, HP Quality Center has not changed at all since they took
over Mercury.
Still the same old crap. Even dual screen is not supported well. Pop-ups
show on the primary even if your browser is on screen 2.
Not to mention it is still called "Mercury" everywhere. So while completely
eliminating EDS now, this does not even seem an area well-staffed at a giant
like HP ?;-)
FUDForum. Page generated in 0.06002 seconds
