Re: Cannot reproduce EVL-GMF tutorial [message #582245 is a reply to message #491971] |
Fri, 16 October 2009 16:04  |
Hi Michali,
In Galileo, the Validate option has (for some reason) been moved from
the Diagram to the Edit menu:
http://www.eclipse.org/forums/index.php?t=msg&goto=47919 2
I'll update the tutorial shortly.
Dimitris
Dimitris Kolovos wrote:
> Hi Michali,
> Thanks for reporting this! I've reproduced the problem under Galileo.
> The Diagram->Validate option seems to be missing indeed in Galileo (this
> does not appear to be an EVL issue but a GMF one). I'll investigate and
> get back to you shortly.
> Cheers,
> Dimitris
> Michalis Famelis wrote:
>> I should have mentioned I use Eclipse Galileo.
FUDForum. Page generated in 0.06975 seconds
