Home » Eclipse Projects » EclipseLink » be able to specify JDBC driver jar w/o adding it to manifest
be able to specify JDBC driver jar w/o adding it to manifest [message #491935] Fri, 16 October 2009 11:34 Go to next message
hi,
from what i understand, it is mandatory that the JDBC driver bundle either needs to be imported or required in the MANIFEST by the bundle using EL.
are there any plans to make this more dynamic? i.e. be able to specify the location of the driver via properties, such there is no need for a user to change the manifest if he chooses to use another JDBC driver/database?
is there a bug/enhancement for this already? i'd be happy to vote on it Wink
Re: be able to specify JDBC driver jar w/o adding it to manifest [message #492234 is a reply to message #491935] Mon, 19 October 2009 10:35 Go to previous messageGo to next message
The issue is that the way JDBC is normally used does not really function in an OSGi environment. I think there is some discussion in the OSGi community to define how JDBC should work, such as an OSGi service. In the man time, I'm not sure there is much EclipseLink can do to address this on its own.
Re: be able to specify JDBC driver jar w/o adding it to manifest [message #492249 is a reply to message #492234] Mon, 19 October 2009 11:11 Go to previous message
ok, thx.
i guess we need to wait for that then.
Previous Topic:Related records as a non-entity collection
Next Topic:bizar?
Current Time: Sat Jul 26 19:27:34 EDT 2025
Powered by FUDForum. Page generated in 0.04114 seconds
