Home » Eclipse Projects » Eclipse Platform » IProject instanceof MyProject
IProject instanceof MyProject [message #491921] Fri, 16 October 2009 10:47 Go to next message
I am currently working on an eclipse plugin to create our own projects an debug them.
The project and file creation wizard is ready ready to use.
Now the problem is the following:
If I create a file with the fileCreationWizard I want to check whether the selected project is instanceof MyProject or not.
I don't really know how to check that.
A java project for example is a IJavaProject I think.
How can I create a IMyProject to check wheter IProject is instanceof IMyProject or not?
I would appreciate any help because I really don't know how to do that.
Great thanks!
Best regards
Alex
Re: IProject instanceof MyProject [message #491932 is a reply to message #491921] Fri, 16 October 2009 10:54 Go to previous messageGo to next message
Alex,
It's not possible. Look at the Javadoc and you'll see
* @noimplement This interface is not intended to be implemented by clients.
* @noextend This interface is not intended to be extended by clients.
You should look at IProjectNature for better ways to "type" your projects.
Alexander Mack wrote:
> Hello,
> an debug them.
> I don't really know how to check that. A java project for example is a
> IMyProject or not?
> Great thanks!
> Best regards
> Alex
Re: IProject instanceof MyProject [message #492182 is a reply to message #491921] Mon, 19 October 2009 06:55 Go to previous messageGo to next message
Projects are distinguished by their "Types" using natures or facets (wtp) not by implementation class.
Facets are more powerful than natures in the sense that the latter can only "tag" your projects of certain type while the
former allows you to do certain actions while adding/removing the tag.
For more information on natures see
http://www.eclipse.org/articles/Article-Builders/builders.ht ml
http://wiki.eclipse.org/FAQ_When_does_my_language_need_its_o wn_nature%3F
Re: IProject instanceof MyProject [message #492184 is a reply to message #491921] Mon, 19 October 2009 06:59 Go to previous message
Thanks Ravi and Ed Merks, I read those articels and decided to add my own project nature.
Alex
Previous Topic:LaunchShortcut Extension
Next Topic:Debug a simple file
Current Time: Mon Jul 21 00:01:56 EDT 2025
Powered by FUDForum. Page generated in 0.03426 seconds
