Home » Modeling » EMF » [Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP
[Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP [message #491704] Thu, 15 October 2009 10:11 Go to next message
Dear newsgroup,
I'm trying to use Teneo in a RCP project, but when I run the RCP
application, the following error occurs:
org.hibernate.HibernateException: Unable to instantiate default tuplizer
[org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer]
at
org.hibernate.tuple.entity.EntityTuplizerFactory.constructTu plizer(EntityTuplizerFactory.java:110)
at
org.hibernate.tuple.entity.EntityTuplizerFactory.constructTu plizer(EntityTuplizerFactory.java:82)
at
org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping . <init>(EntityEntityModeToTuplizerMapping.java:72)
at
org.hibernate.tuple.entity.EntityMetamodel.<init>(EntityMetamodel.java:323)
at
org.hibernate.persister.entity.AbstractEntityPersister.<init >(AbstractEntityPersister.java:456)
at
org.hibernate.persister.entity.JoinedSubclassEntityPersister . <init>(JoinedSubclassEntityPersister.java:113)
at
org.hibernate.persister.PersisterFactory.createClassPersiste r(PersisterFactory.java:87)
at
org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:267)
at
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1341)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.buildSess ionFactory(HbSessionDataStore.java:198)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:86)
Caused by: java.lang.ClassNotFoundException:
at
org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:494)
at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:398)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
The RCP currently consists of only one plugin yet. When I run this
plugin as an ordinary Java application, Teneo works fine. But the
above-mentioned exception occurs when it is started as an RCP.
The plugin contains all the required Hibernate jars and depends on
Teneo's core and Hibernate plugins: org.eclipse.emf.teneo,
org.eclipse.emf.teneo.eclipse, org.eclipse.emf.teneo.hibernate.eclipse,
org.apache.commons.logging,org.eclipse.emf.teneo.annotations ,
org.eclipse.emf.teneo.hibernate.mapper, org.eclipse.emf.teneo.hibernate
The Hibernate jars are added in the plugin's bundle classpath and each
jar's packages are added to the bundles exported packages. (Even the
Eclipse-BuddyPolicy: dependent line exists, but I guess this is irrelevant.)
Apparently I miss to configure something. May be somebody recognizes my
mistake.
Frank
Re: [Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP [message #491750 is a reply to message #491704] Thu, 15 October 2009 12:10 Go to previous messageGo to next message
Hi Frank,
These CNE's are always annoying... I think the classloading behavior of running as a java app is different than running
in an osgi environment (although also the java app uses the plugin classpath definitions).
Can you post/link the manifest.mf of the rcp plugin and the hibernate plugin here? Are your model classes located in
another plugin (if so can you also attach/post its manifest.mf?).
gr. Martin
Frank Grimm wrote:
> Dear newsgroup,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> mistake.
> Frank
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP [message #491896 is a reply to message #491750] Fri, 16 October 2009 09:11 Go to previous messageGo to next message
Dear Martin,
> plugin here? Are your model classes located in another plugin (if so can
I'm using two plugins: on contains the hibernate jars and a little teneo
test (which triggers the CNE), the other plugin contains the Ecore model.
Here is the test plugin's bundle:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Teneo JARs
Bundle-SymbolicName: teneojars;singleton:=true
Bundle-Version: 1.0.0.qualifier
Bundle-RequiredExecutionEnvironment: J2SE-1.5
Bundle-ClassPath: jars/antlr-2.7.6.jar,
jars/asm-3.2.jar,
jars/cglib-2.2.jar,
jars/commons-collections-3.1.jar,
jars/dom4j-1.6.1.jar,
jars/h2-1.1.119.jar,
jars/hibernate3.jar,
jars/jta-1.1.jar,
jars/log4j-1.2.15.jar,
jars/slf4j-api-1.5.8.jar,
jars/slf4j-log4j12-1.5.8.jar,
Require-Bundle:
org.eclipse.emf.teneo;bundle-version="1.1.1";visibility:=reexport,
org.eclipse.emf.teneo.eclipse;bundle-version="1.1.0";visibility:=reexport,
org.eclipse.emf.teneo.hibernate.eclipse;bundle-version="1.1.0 ";visibility:=reexport,
org.apache.commons.logging;bundle-version="1.0.4";visibility:=reexport,
org.eclipse.emf.teneo.annotations;bundle-version="1.1.0";visibility:=reexport,
org.eclipse.emf.teneo.hibernate.mapper;visibility:=reexport,
org.eclipse.emf.teneo.hibernate;visibility:=reexport,
de.scopeset.ec.sde;bundle-version="1.0.0",
org.eclipse.ui;bundle-version="3.5.1"
Export-Package: antlr,
And here is the model plugin's (de.scopeset.ec.sde) bundle:
Bundle-Name: %pluginName
Bundle-SymbolicName: de.scopeset.ec.sde;singleton:=true
Bundle-ClassPath: de.scopeset.ec.sde.jar
Bundle-Vendor: %providerName
Bundle-Localization: plugin
Export-Package: de.scopeset.ec.sde,
de.scopeset.ec.sde.impl,
de.scopeset.ec.sde.util
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.emf.ecore;visibility:=reexport,
org.junit4;bundle-version="4.5.0"
Bundle-ActivationPolicy: lazy
Frank
Re: [Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP [message #491908 is a reply to message #491896] Fri, 16 October 2009 09:36 Go to previous messageGo to next message
Hi Frank,
Can you try the following: set the Eclipse-BuddyPolicy: dependent
in the model plugin?
I also would propose a different plugin structure:
- a hibernate libraries plugin with just the hibernate jar files with: Eclipse-BuddyPolicy: dependent
- a model class plugin which contains the model classes
- a separate plugin with your test class which required the commons-logging plugin, the org.eclipse.emf.teneo.hibernate
plugin, model-plugin as well as the hibernate plugin
gr. Martin
Frank Grimm wrote:
> Dear Martin,
> jars/asm-3.2.jar,
> jars/cglib-2.2.jar,
> jars/jta-1.1.jar,
> Require-Bundle:
> Frank
The Netherlands
Re: [Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP [message #493424 is a reply to message #491908] Mon, 26 October 2009 04:21 Go to previous messageGo to next message
Dear Martin,
> commons-logging plugin, the org.eclipse.emf.teneo.hibernate plugin,
following your advise worked, thanks! In addition, I had to switch from
javaassist to cglib following your explanation given at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=292151#c3
Frank
> Frank Grimm wrote:
>> Dear Martin,
>> jars/asm-3.2.jar,
>> jars/cglib-2.2.jar,
>> jars/jta-1.1.jar,
>> Require-Bundle:
>> Thanks,
>> Frank
Re: [Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP [message #493428 is a reply to message #493424] Mon, 26 October 2009 04:45 Go to previous messageGo to next message
Good to hear Frank! For other users, I also added this issue to the troubleshooting section:
http://www.elver.org/hibernate/troubleshooting.html#javassis t_duplicate
gr. Martin
Frank Grimm wrote:
> Dear Martin,
> Frank
>> Frank Grimm wrote:
>>> Dear Martin,
>>> jars/asm-3.2.jar,
>>> jars/cglib-2.2.jar,
>>> jars/jta-1.1.jar,
>>> Require-Bundle:
>>> Thanks,
>>> Frank
The Netherlands
Re: [Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP [message #1060650 is a reply to message #493428] Mon, 27 May 2013 09:25 Go to previous messageGo to next message
Hi Martin,
Could you please update the link to the specific javaassist duplicate method error?
Can't find it in the Teneo docs.
Thanks!
Martin Taal wrote on Mon, 26 October 2009 09:45
gr. Martin
Frank Grimm wrote:
> Dear Martin,
> Frank
>> Frank Grimm wrote:
>>> Dear Martin,
>>> jars/asm-3.2.jar,
>>> jars/cglib-2.2.jar,
>>> jars/jta-1.1.jar,
>>> Require-Bundle:
>>> Thanks,
>>> Frank
The Netherlands
Re: [Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP [message #1060656 is a reply to message #1060650] Mon, 27 May 2013 10:23 Go to previous message
Here it is:
http://wiki.eclipse.org/Teneo/Hibernate/FAQ#Duplicate_method_exception_with_javaassist
gr. Martin
On 05/27/2013 03:25 PM, Erdal Karaca wrote:
> Hi Martin,
> Thanks!
>> gr. Martin
>> Frank Grimm wrote:
>> > Dear Martin,
>> > > Thanks,
>> > Frank
>> > >> Frank Grimm wrote:
>> >>> Dear Martin,
>> >>> jars/asm-3.2.jar,
>> >>> jars/cglib-2.2.jar,
>> >>> jars/jta-1.1.jar,
>> >>> Require-Bundle:
>> >>> Thanks,
>> >>> Frank
>> The Netherlands
>> Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
The Netherlands
Previous Topic: problem with inheritance and access to subclass
Next Topic:[Texo] Generated Code
Current Time: Thu Jul 31 00:46:43 EDT 2025
Powered by FUDForum. Page generated in 0.05101 seconds
