Home » Modeling » EMF » [Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP
[Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP [message #491704] |
Thu, 15 October 2009 10:11  |
Dear newsgroup,
I'm trying to use Teneo in a RCP project, but when I run the RCP
application, the following error occurs:
org.hibernate.HibernateException: Unable to instantiate default tuplizer
[org.eclipse.emf.teneo.hibernate.tuplizer.EMFTuplizer]
at
org.hibernate.tuple.entity.EntityTuplizerFactory.constructTu plizer(EntityTuplizerFactory.java:110)
at
org.hibernate.tuple.entity.EntityTuplizerFactory.constructTu plizer(EntityTuplizerFactory.java:82)
at
org.hibernate.tuple.entity.EntityEntityModeToTuplizerMapping . <init>(EntityEntityModeToTuplizerMapping.java:72)
at
org.hibernate.tuple.entity.EntityMetamodel.<init>(EntityMetamodel.java:323)
at
org.hibernate.persister.entity.AbstractEntityPersister.<init >(AbstractEntityPersister.java:456)
at
org.hibernate.persister.entity.JoinedSubclassEntityPersister . <init>(JoinedSubclassEntityPersister.java:113)
at
org.hibernate.persister.PersisterFactory.createClassPersiste r(PersisterFactory.java:87)
at
org.hibernate.impl.SessionFactoryImpl.<init>(SessionFactoryImpl.java:267)
at
org.hibernate.cfg.Configuration.buildSessionFactory(Configur ation.java:1341)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.buildSess ionFactory(HbSessionDataStore.java:198)
at
org.eclipse.emf.teneo.hibernate.HbSessionDataStore.initializ e(HbSessionDataStore.java:86)
Caused by: java.lang.ClassNotFoundException:
at
org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:494)
at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:410)
at
org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:398)
at
org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
The RCP currently consists of only one plugin yet. When I run this
plugin as an ordinary Java application, Teneo works fine. But the
above-mentioned exception occurs when it is started as an RCP.
The plugin contains all the required Hibernate jars and depends on
Teneo's core and Hibernate plugins: org.eclipse.emf.teneo,
org.eclipse.emf.teneo.eclipse, org.eclipse.emf.teneo.hibernate.eclipse,
org.apache.commons.logging,org.eclipse.emf.teneo.annotations ,
org.eclipse.emf.teneo.hibernate.mapper, org.eclipse.emf.teneo.hibernate
The Hibernate jars are added in the plugin's bundle classpath and each
jar's packages are added to the bundles exported packages. (Even the
Eclipse-BuddyPolicy: dependent line exists, but I guess this is irrelevant.)
Apparently I miss to configure something. May be somebody recognizes my
mistake.
Frank
Re: [Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP [message #491750 is a reply to message #491704] |
Thu, 15 October 2009 12:10   |
Hi Frank,
These CNE's are always annoying... I think the classloading behavior of running as a java app is different than running
in an osgi environment (although also the java app uses the plugin classpath definitions).
Can you post/link the manifest.mf of the rcp plugin and the hibernate plugin here? Are your model classes located in
another plugin (if so can you also attach/post its manifest.mf?).
gr. Martin
Frank Grimm wrote:
> Dear newsgroup,
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> mistake.
> Frank
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP [message #491896 is a reply to message #491750] |
Fri, 16 October 2009 09:11   |
Dear Martin,
> plugin here? Are your model classes located in another plugin (if so can
I'm using two plugins: on contains the hibernate jars and a little teneo
test (which triggers the CNE), the other plugin contains the Ecore model.
Here is the test plugin's bundle:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Teneo JARs
Bundle-SymbolicName: teneojars;singleton:=true
Bundle-Version: 1.0.0.qualifier
Bundle-RequiredExecutionEnvironment: J2SE-1.5
Bundle-ClassPath: jars/antlr-2.7.6.jar,
jars/asm-3.2.jar,
jars/cglib-2.2.jar,
jars/commons-collections-3.1.jar,
jars/dom4j-1.6.1.jar,
jars/h2-1.1.119.jar,
jars/hibernate3.jar,
jars/jta-1.1.jar,
jars/log4j-1.2.15.jar,
jars/slf4j-api-1.5.8.jar,
jars/slf4j-log4j12-1.5.8.jar,
Require-Bundle:
org.eclipse.emf.teneo;bundle-version="1.1.1";visibility:=reexport,
org.eclipse.emf.teneo.eclipse;bundle-version="1.1.0";visibility:=reexport,
org.eclipse.emf.teneo.hibernate.eclipse;bundle-version="1.1.0 ";visibility:=reexport,
org.apache.commons.logging;bundle-version="1.0.4";visibility:=reexport,
org.eclipse.emf.teneo.annotations;bundle-version="1.1.0";visibility:=reexport,
org.eclipse.emf.teneo.hibernate.mapper;visibility:=reexport,
org.eclipse.emf.teneo.hibernate;visibility:=reexport,
de.scopeset.ec.sde;bundle-version="1.0.0",
org.eclipse.ui;bundle-version="3.5.1"
Export-Package: antlr,
And here is the model plugin's (de.scopeset.ec.sde) bundle:
Bundle-Name: %pluginName
Bundle-SymbolicName: de.scopeset.ec.sde;singleton:=true
Bundle-ClassPath: de.scopeset.ec.sde.jar
Bundle-Vendor: %providerName
Bundle-Localization: plugin
Export-Package: de.scopeset.ec.sde,
de.scopeset.ec.sde.impl,
de.scopeset.ec.sde.util
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.emf.ecore;visibility:=reexport,
org.junit4;bundle-version="4.5.0"
Bundle-ActivationPolicy: lazy
Frank
Re: [Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP [message #491908 is a reply to message #491896] |
Fri, 16 October 2009 09:36   |
Hi Frank,
Can you try the following: set the Eclipse-BuddyPolicy: dependent
in the model plugin?
I also would propose a different plugin structure:
- a hibernate libraries plugin with just the hibernate jar files with: Eclipse-BuddyPolicy: dependent
- a model class plugin which contains the model classes
- a separate plugin with your test class which required the commons-logging plugin, the org.eclipse.emf.teneo.hibernate
plugin, model-plugin as well as the hibernate plugin
gr. Martin
Frank Grimm wrote:
> Dear Martin,
> jars/asm-3.2.jar,
> jars/cglib-2.2.jar,
> jars/jta-1.1.jar,
> Require-Bundle:
> Frank
The Netherlands
Re: [Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP [message #493424 is a reply to message #491908] |
Mon, 26 October 2009 04:21   |
Dear Martin,
> commons-logging plugin, the org.eclipse.emf.teneo.hibernate plugin,
following your advise worked, thanks! In addition, I had to switch from
javaassist to cglib following your explanation given at
https://bugs.eclipse.org/bugs/show_bug.cgi?id=292151#c3
Frank
> Frank Grimm wrote:
>> Dear Martin,
>> jars/asm-3.2.jar,
>> jars/cglib-2.2.jar,
>> jars/jta-1.1.jar,
>> Require-Bundle:
>> Thanks,
>> Frank
Re: [Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP [message #493428 is a reply to message #493424] |
Mon, 26 October 2009 04:45   |
Good to hear Frank! For other users, I also added this issue to the troubleshooting section:
http://www.elver.org/hibernate/troubleshooting.html#javassis t_duplicate
gr. Martin
Frank Grimm wrote:
> Dear Martin,
> Frank
>> Frank Grimm wrote:
>>> Dear Martin,
>>> jars/asm-3.2.jar,
>>> jars/cglib-2.2.jar,
>>> jars/jta-1.1.jar,
>>> Require-Bundle:
>>> Thanks,
>>> Frank
The Netherlands
Re: [Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP [message #1060650 is a reply to message #493428] |
Mon, 27 May 2013 09:25   |
Hi Martin,
Could you please update the link to the specific javaassist duplicate method error?
Can't find it in the Teneo docs.
Thanks!
Martin Taal wrote on Mon, 26 October 2009 09:45Good to hear Frank! For other users, I also added this issue to the troubleshooting section:
gr. Martin
Frank Grimm wrote:
> Dear Martin,
> Frank
>> Frank Grimm wrote:
>>> Dear Martin,
>>> jars/asm-3.2.jar,
>>> jars/cglib-2.2.jar,
>>> jars/jta-1.1.jar,
>>> Require-Bundle:
>>> Thanks,
>>> Frank
The Netherlands
Re: [Teneo] org.hibernate.proxy.HibernateProxy not found when running as RCP [message #1060656 is a reply to message #1060650] |
Mon, 27 May 2013 10:23  |
Here it is:
http://wiki.eclipse.org/Teneo/Hibernate/FAQ#Duplicate_method_exception_with_javaassist
gr. Martin
On 05/27/2013 03:25 PM, Erdal Karaca wrote:
> Hi Martin,
> Thanks!
>> gr. Martin
>> Frank Grimm wrote:
>> > Dear Martin,
>> > > Thanks,
>> > Frank
>> > >> Frank Grimm wrote:
>> >>> Dear Martin,
>> >>> jars/asm-3.2.jar,
>> >>> jars/cglib-2.2.jar,
>> >>> jars/jta-1.1.jar,
>> >>> Require-Bundle:
>> >>> Thanks,
>> >>> Frank
>> The Netherlands
>> Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
The Netherlands
Current Time: Thu Jul 31 00:47:51 EDT 2025
Powered by FUDForum. Page generated in 0.46320 seconds
