Home » Eclipse Projects » Subversive » Update results in error
Update results in error [message #490549] Fri, 09 October 2009 02:21 Go to next message
If I update my svn project I get the message:
Some resources were not updated.
svn: Processing REPORT request response failed: XML document structures
must start and end within the same entity. (/svn/!svn/vcc/default)
svn: REPORT request failed on '/svn/!svn/vcc/default'
It looks like the update was succesful. Any idea what could cause the
error message?
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
Re: Update results in error [message #490591 is a reply to message #490549] Fri, 09 October 2009 06:05 Go to previous messageGo to next message
Hi Lars,
SVN Version? Post comment hooks in the repo?
I have never seen such messages.
Cheers, Jörg
On 10/09/09 08:21, Lars Vogel wrote:
> error message?
> Best regards, Lars
Re: Update results in error [message #491248 is a reply to message #490591] Tue, 13 October 2009 14:36 Go to previous messageGo to next message
Hi Jörg,
I'm using SVN 1.6.
I'm not sure what you mean with your question "Post comment hooks in the
repo?". Can you please clarify?
Best regards, Lars
Jörg Thönnes wrote:
> Hi Lars,
> Cheers, Jörg
>> Hi,
>> error message?
>> Best regards, Lars
Re: Update results in error [message #491646 is a reply to message #491248] Thu, 15 October 2009 07:38 Go to previous messageGo to next message
Hello Lars,
It seems this issues relates to svn connector you use. Probably it depends
on connection speed, network settings or something like this. Could you
please try to make update with another connector(SVNKit, JavaHL or with
another connector version)?
> Hi Jorg,
> I'm using SVN 1.6.
> Best regards, Lars
> Jorg Thonnes wrote:
>> Hi Lars,
>> Cheers, Jorg
>>> Hi,
>>> error message?
>>> Best regards, Lars
Re: Update results in error [message #491838 is a reply to message #491646] Fri, 16 October 2009 02:28 Go to previous messageGo to next message
Hi Igor,
thanks. I believe I solved this issue. The project I tried to
synchronize was deleted on the server and then I tried to synchronize I
got this strange error.
Best regards, Lars
Igor Burilo wrote:
> Hello Lars,
>> Hi Jorg,
>> I'm using SVN 1.6.
>> Best regards, Lars
>> Jorg Thonnes wrote:
>>> Hi Lars,
>>> Cheers, Jorg
>>>> Hi,
>>>> error message?
>>>> Best regards, Lars
Re: Update results in error [message #495140 is a reply to message #490549] Tue, 03 November 2009 16:39 Go to previous message
this is reproducable. I created https://bugs.eclipse.org/bugs/show_bug.cgi?id=294123
Best regards, Lars
Previous Topic:How do I merge a deletion into the branch?
Next Topic:Subversive plugin depends on Mylyn parts?
Current Time: Sat Jul 26 11:39:29 EDT 2025
Powered by FUDForum. Page generated in 0.04583 seconds
