Home » Modeling » Epsilon » Node with 2 labels [GMF](I need create a node with 2 labels)
Node with 2 labels [GMF] [message #491760] Thu, 15 October 2009 13:08 Go to next message
Hello everyone!
I'm creating some graphical editors with EuGENia. My problem is that I need create a node with 2 labels, one of them to show the name (EAttribute) and another one must be show a fixed text (not EAttribute).
I don't know how to do, any ideas??
Thank you,
ajimenezr
[Updated on: Thu, 15 October 2009 13:09] by Moderator
Re: Node with 2 labels [GMF] [message #491765 is a reply to message #491760] Thu, 15 October 2009 13:27 Go to previous messageGo to next message
You can specify the first label (the one that is bound to the EAttribute
) in the @gmf.node(label="...") annotation. Then you need to add the
second label in your .gmfgraph model via a polishing transformation as per:
http://www.eclipse.org/gmt/epsilon/doc/articles/eugenia-poli shing/
If you have trouble with this, please send your metamodel and a drawing
of how you want your node to look like and I'll be happy to help.
Dimitris
ajimenezr wrote:
> Hello everyone!
> (EAttribute) and another one must be show a fixed text.
> Thank you,
> ajimenezr
Re: Node with 2 labels [GMF] [message #491768 is a reply to message #491765] Thu, 15 October 2009 13:49 Go to previous messageGo to next message
Hi again,
I've already known your idea (I created another editors using GMF) but I want to create all through emfatic code and EuGENia plugin, but I don't know if it is possible:
Could I create a complex editor using only emfatic code and EuGENia?
ajimenezr
Re: Node with 2 labels [GMF] [message #491769 is a reply to message #491768] Thu, 15 October 2009 14:02 Go to previous messageGo to next message
As explained in
http://eclipse.org/gmt/epsilon/doc/articles/eugenia-polishin g/ , EuGENia
doesn't provide a 1:1 mapping with GMF (if it did, it would be as
complex as GMF and this would beat the whole point).
Its aim is to support the most commonly used features of GMF using
annotations so that you can get a working and fairly complete editor
very quickly, and then provide you with a systematic way of polishing
your editor.
So the short answer is that you can create an editor up to a certain
level of complexity with the built-in annotations, but you then have to
use the polishing transformations if you need to go any further.
In case it helps, in addition to the example above, the following two
examples also use polishing transformations:
http://eclipse.org/gmt/epsilon/examples/index.php?example=or g.eclipse.epsilon.eugenia.examples.endlabels
http://eclipse.org/gmt/epsilon/examples/index.php?example=or g.eclipse.epsilon.eugenia.examples.flowchart
Dimitris
ajimenezr wrote:
> Hi again,
> ajimenezr
Re: Node with 2 labels [GMF] [message #491774 is a reply to message #491769] Thu, 15 October 2009 14:35 Go to previous message
Hi Dimitris,
your answer is perfect!
"Its aim is to support the most commonly used features of GMF using
your editor.
use the polishing transformations if you need to go any further."
Thank you very much!
Alvaro
Re: Node with 2 labels [GMF] [message #582080 is a reply to message #491765] Thu, 15 October 2009 13:49 Go to previous message
Hi again,
ajimenezr
Re: Node with 2 labels [GMF] [message #582102 is a reply to message #491768] Thu, 15 October 2009 14:02 Go to previous message
As explained in
your editor.
Dimitris
ajimenezr wrote:
> Hi again,
> ajimenezr
Re: Node with 2 labels [GMF] [message #582123 is a reply to message #491769] Thu, 15 October 2009 14:35 Go to previous message
Hi Dimitris,
your editor.
Alvaro
Previous Topic:Node with 2 labels [GMF]
Next Topic:Set source.decoration in a link when navigability is BIDIRECTIONAL
Current Time: Sat Jul 26 21:04:14 EDT 2025
Powered by FUDForum. Page generated in 0.05444 seconds
