Home » Eclipse Projects » Eclipse Platform » Execute console commands, show output in console view
Execute console commands, show output in console view [message #490090] Wed, 07 October 2009 05:46 Go to next message
I'm using eclipse 3.4.2 on linux x64. In my plugin I want to execute
some linux console commands/scripts and show the output in the eclipse
console view.
For me it is also important that the shell from which eclipse was
started is used for input as there are some environment variables set I
want to use.
So, how can I do it?
Vitaliy
Re: Execute console commands, show output in console view [message #491594 is a reply to message #490090] Thu, 15 October 2009 04:00 Go to previous message
I am afraid you can't get the shell from which the eclipse is launched. Eclipse runs in JVM and so it isn't aware how is it lauched (AFIAK). You could always run Runtime.getRuntime().exec to execute system command. Write a script that will do the environment setup and call it before launching your custom script. Hope this helps
Ravi
Previous Topic:My osgi.framework.extensions got deleted from the config.ini by eclipse
Next Topic:API to find whether user has chosen to delete contents while deleting the project
Current Time: Mon Jul 21 05:55:10 EDT 2025
Powered by FUDForum. Page generated in 0.06061 seconds
