Home » Eclipse Projects » Eclipse Platform » My osgi.framework.extensions got deleted from the config.ini by eclipse
My osgi.framework.extensions got deleted from the config.ini by eclipse [message #485987] Tue, 15 September 2009 15:51 Go to next message
Hey,
Our plug-in extends osgi.framework.extensions. In our plug-in installer
which contains both our plug-in and eclipse 3.5, we managed to add a line
"osgi.framework.extensions=net.xxx.xxx.hook" to the config.ini file, so
users do not need to manually add it. However, after the first time
eclipse starts up, our hook was removed. The config.ini has a line on the
top saying:
"#This configuration file was written by:
org.eclipse.equinox.internal.frameworkadmin.equinox.EquinoxF wConfigFileParser "
If we manually add it back, and then our hook works. It seem when eclipse
starts up for the first time, it checks something. Can anyone tell me how
to solve this problem? Everything worked fine in 3.4.
Thanks.
Re: My osgi.framework.extensions got deleted from the config.ini by eclipse [message #486212 is a reply to message #485987] Wed, 16 September 2009 14:42 Go to previous messageGo to next message
Anyone have any idea about this issue? Thanks.
Re: My osgi.framework.extensions got deleted from the config.ini by eclipse [message #487808 is a reply to message #485987] Thu, 24 September 2009 09:36 Go to previous messageGo to next message
Anyone can help on this issue? Thanks.
Re: My osgi.framework.extensions got deleted from the config.ini by eclipse [message #490202 is a reply to message #485987] Wed, 07 October 2009 15:20 Go to previous messageGo to next message
Re: My osgi.framework.extensions got deleted from the config.ini by eclipse [message #491588 is a reply to message #485987] Thu, 15 October 2009 03:55 Go to previous message
Great !! Some else has the same issue. I have exactly the same issue with p2. Shocked I guess posting this in p2 news group will help.
Please let me know if you get any answers
Ravi (v.r.sankar@gmail.com)
Previous Topic:Resource conflicting rule
Next Topic:Execute console commands, show output in console view
Current Time: Sat Jul 26 21:49:05 EDT 2025
Powered by FUDForum. Page generated in 0.05172 seconds
