Home » Modeling » M2T (model-to-text transformation) » How to define Xtend method like: collection.retainAll(e|expression with e) ?(I want to define in Xtend a method that modify the content of a list according to a boolean expression.)
How to define Xtend method like: collection.retainAll(e|expression with e) ? [message #491384] Wed, 14 October 2009 08:17 Go to next message
I want to define in Xtend a method that modify the content of a list according to a boolean expression applied to each element in the list.
Basically, I want to be able to define in Xtend a method that:
* takes a boolean expression as argument (like Collection.select)
* actually modify the provided collection (and returns Void)
I want to call this Xtend method from an Xpand template of this kind:
create Set[MyType] result getXYZ(MyOtherType this) :
result.retainAll(e|e.associationFromMyType == this);
And I don't know how to define such a parameter in Xtend:
Void retainAll(Collection this, ??? conditionArgument) :
let temp = this.select(conditionArgument) :
?set this to temp?;
Is this any possible?
Re: How to define Xtend method like: collection.retainAll(e|expression with e) ? [message #491388 is a reply to message #491384] Wed, 14 October 2009 08:19 Go to previous messageGo to next message
Hi C,
the higher order collection functions are hardcoded. It is currently not
possible to declare and implement something similar in your own extensions.
Sorry for inconvenience,
Sebastian
> ?set this to temp?;
Re: How to define Xtend method like: collection.retainAll(e|expression with e) ? [message #491391 is a reply to message #491388] Wed, 14 October 2009 08:35 Go to previous messageGo to next message
Hi Sebastian, thanks for fast answer.
Would it be possible then to subclass the java code that implements it?
What is the Java class that implements the high order collection functions?
Cédric
Re: How to define Xtend method like: collection.retainAll(e|expression with e) ? [message #491509 is a reply to message #491391] Wed, 14 October 2009 16:25 Go to previous message
It's not possible to introduce new higher order functions, since
you'ld have to extend the parser.
Maybe
result.removeAll(result.select(e|e.associationFromMyType != this));
is sufficient?
Sven
> Cheers,
> Cédric
Previous Topic:JET as part of Java
Next Topic:How to implement <jet.compile2> using customBuildCallbacks.xml
Current Time: Sun Jul 27 04:02:33 EDT 2025
Powered by FUDForum. Page generated in 0.03415 seconds
