Eclipse doesn't see JMF. [message #491362] |
Wed, 14 October 2009 06:41  |
I have the following problem:
+ I using newest Eclipse 3.5.1.* and newest Java JDK and I installed newest JMF with default configuration successfully.
+ In Eclipse Editor, when I type: import javax.media.
I don't see Manager class in Default Proposals pane (I mean Intellisense) although I see it in JRE System Library folder expanded in Project Explorer.
When I typed import javax.media.Manager manually, the compiler underlined it as an error "Access restriction...".
+ I googled for that and found out a temporary solution:
http:// lkamal.blogspot.com/2008/09/eclipse-access-restriction-on-li brary.html#comment-form
but I don't like that solution because it just hide the error. I'd like to solve that problem completely without potential errors.
Help me solve these:
1) I want Manager class to appear in Proposals pane.
2) I want fix that error without configuring Errors/Warnings (I mean fix it, not hide it).
Here is image:
http://i240.photobucket.com/albums/ff22/Emerald214/media2.jp g
Thank you in advance.
[Updated on: Wed, 14 October 2009 06:42] by Moderator
FUDForum. Page generated in 0.09737 seconds
