Home » Eclipse Projects » EGit / JGit » java.io.FileNotFoundException when checking out a branch
java.io.FileNotFoundException when checking out a branch [message #491174] Tue, 13 October 2009 10:24 Go to next message
Originally posted by: hillner.informatik.uni-leipzig.de
when I try to checkout a branch using the following code ...
private void loadBranch(String refName) throws IOException {
Commit commit = repo.mapCommit(refName);
Tree tree = commit.getTree();
GitIndex index = repo.getIndex();
new WorkDirCheckout(repo, repo.getWorkDir(), index, tree).checkout();
index.write();
repo.writeSymref(Constants.HEAD, refName);
.... I sometimes get a FileNotFoundException with a stack trace like the
following:
java.io.FileNotFoundException:
D:\Stanley\SHK\AMOR\runtime-EclipseApplication\voldemort\src \java\voldemort\serialization\VoldemortOperation.java
(Zugriff verweigert) --> Access denied
at java.io.FileOutputStream.open(Native Method)
at java.io.FileOutputStream.<init>(Unknown Source)
at org.eclipse.jgit.lib.GitIndex.checkoutEntry(GitIndex.java:84 5)
at
org.eclipse.jgit.lib.WorkDirCheckout$1.visitEntry(WorkDirChe ckout.java:176)
at org.eclipse.jgit.lib.IndexTreeWalker.visitEntry(IndexTreeWal ker.java:160)
at org.eclipse.jgit.lib.IndexTreeWalker.walk(IndexTreeWalker.ja va:127)
at org.eclipse.jgit.lib.IndexTreeWalker.walk(IndexTreeWalker.ja va:107)
at
org.eclipse.jgit.lib.WorkDirCheckout.checkoutOutIndexNoHead( WorkDirCheckout.java:179)
at org.eclipse.jgit.lib.WorkDirCheckout.checkout(WorkDirCheckou t.java:136)
at
de.modelrepository.test.git.GitFileHistory.loadBranch(GitFil eHistory.java:139)
at de.modelrepository.test.git.GitFileHistory.<init>(GitFileHistory.java:42)
at de.modelrepository.test.git.GitFileHistory.main(GitFileHisto ry.java:167)
This error occurs often but by chance. Everytime the affected file is
another and I can't figure out what the reason may be.
Re: java.io.FileNotFoundException when checking out a branch [message #491175 is a reply to message #491174] Tue, 13 October 2009 10:38 Go to previous messageGo to next message
> index.write();
> following:
Missing parent directory? Maybe WorkDirCheckout isn't always creating
the leading path like it should?
I don't know, I'm not very familiar with WorkDirCheckout... I haven't
looked at or called that code in years.
Re: java.io.FileNotFoundException when checking out a branch [message #491182 is a reply to message #491175] Tue, 13 October 2009 10:54 Go to previous messageGo to next message
No, the parent directory (repo.getWorkDir()) is created everytime similar.
Or do you think about another parent?
"Shawn Pearce" <spearce@spearce.org> schrieb im Newsbeitrag
news:hb23dh$vp8$1@build.eclipse.org...
>> index.write();
>> following:
> Missing parent directory? Maybe WorkDirCheckout isn't always creating the
Re: java.io.FileNotFoundException when checking out a branch [message #491262 is a reply to message #491182] Tue, 13 October 2009 16:35 Go to previous messageGo to next message
I was thinking about the parent directory of the file...
So does
exist when this fails like this? Is the directory maybe not writable?
Re: java.io.FileNotFoundException when checking out a branch [message #491409 is a reply to message #491262] Wed, 14 October 2009 09:04 Go to previous messageGo to next message
OK, for any reason today everthing works like it should.
Maybe this is because I restarted eclipse or my system.
I didn't change anything at all. strange...Windows ^^
Nevertheless thank you for your replies, nice to have a bit support :)
Another question:
Is there any further documentation of JGit/EGit except the small
tutorial and the javadoc in the source?
And Is there an update site where I can get the org.eclipse.jgit plugins
(not the spearce-packages -> beacause of the dependencies)?
news:hb2oa3$mg1$1@build.eclipse.org...
>> similar.
> So does
Re: java.io.FileNotFoundException when checking out a branch [message #491432 is a reply to message #491409] Wed, 14 October 2009 10:41 Go to previous message
No. We want to move the tutorial from code.google.com to the Eclipse
Wiki under the EGit directory, and we'd certainly appreciate help from
folks who understand a bit of JGit to help us document it further.
Jonas did a nice job with the bit he did write, but docs are far down on
everyone's priority list. :-\
> plugins (not the spearce-packages -> beacause of the dependencies)?
Not yet. Actually there is a Maven depot at code.google.com/p/egit/
which now also has an org.eclipse.jgit namespace. But I wouldn't
encourage using it just yet...
We're hoping to release a JGit/EGit 0.6.0-M1 near the end of the month,
and have the build artifacts available through the Eclipse download site
and mirrors. Those would be built against the JARs from Eclipse Orbit.
Re: java.io.FileNotFoundException when checking out a branch [message #574663 is a reply to message #491174] Tue, 13 October 2009 10:38 Go to previous message
> index.write();
> following:
Re: java.io.FileNotFoundException when checking out a branch [message #574699 is a reply to message #491175] Tue, 13 October 2009 10:54 Go to previous message
>> index.write();
>> following:
Re: java.io.FileNotFoundException when checking out a branch [message #574715 is a reply to message #491182] Tue, 13 October 2009 16:35 Go to previous message
So does
Re: java.io.FileNotFoundException when checking out a branch [message #574777 is a reply to message #491262] Wed, 14 October 2009 09:04 Go to previous message
Another question:
>> similar.
> So does
Re: java.io.FileNotFoundException when checking out a branch [message #574801 is a reply to message #491409] Wed, 14 October 2009 10:41 Go to previous message
Previous Topic:How create Git repository from Eclipse project?
Next Topic:symlinks under git repository are tagged for removal at each commit
Current Time: Thu Nov 06 12:43:02 EST 2025
Powered by FUDForum. Page generated in 0.05180 seconds
