Home » Eclipse Projects » JFace » blockOnOpen = false for Wizards(block on open can't be deactivated)
blockOnOpen = false for Wizards [message #491181] Tue, 13 October 2009 10:54 Go to next message
Hey everybody,
i'm new to developing with the eclipse api and just created a wizard, which should be modal or blockOnOpen should be set to false.
Im opening the wizard with this command / handler:
public Object execute(final ExecutionEvent event) throws ExecutionException {
		RecoveryWizard wizard = new RecoveryWizard();
		WizardDialog wizardDialog = new WizardDialog(PlatformUI.getWorkbench().getActiveWorkbenchWindow().getShell(),
			wizard);
		wizardDialog.setBlockOnOpen(false);
		wizardDialog.create();
		wizardDialog.open();
		return null;
but somehow the wizard blocks eclipse (i can't change sth in the background).
I'm using eclipse galileo.
Thanks for your help,
Henning
Re: blockOnOpen = false for Wizards [message #491285 is a reply to message #491181] Tue, 13 October 2009 20:21 Go to previous messageGo to next message
> background).
Invoking Wizard's setBlockOnOpen(boolean) method has nothing to do with
whether the opened window will be modal or not.
According to the javadocs...
true if the open not return until the window closes, and false if the
open method should return immediately
....so as you can see, this is a matter of whether open() method returns
immediately or not (i.e. whether the thread is "stalled" or not). The
modality of a dialog/window is determined by its shell's style bits.
Remy
Re: blockOnOpen = false for Wizards [message #491332 is a reply to message #491181] Wed, 14 October 2009 03:51 Go to previous messageGo to next message
So, is there a solution for opening a wizard modaly?
Re: blockOnOpen = false for Wizards [message #491338 is a reply to message #491332] Wed, 14 October 2009 04:20 Go to previous messageGo to next message
Sure there is but you need to subclass WizardDialog and in the
constructor call setShellStyle(SWT.SHELL_TRIM|SWT.APPLICATION_MODAL).
Tom
Re: blockOnOpen = false for Wizards [message #491387 is a reply to message #491181] Wed, 14 October 2009 08:24 Go to previous messageGo to next message
Hm, the constructor of WizardDialog already sets the application.modal flag:
public WizardDialog(Shell parentShell, IWizard newWizard) {
		super(parentShell);
		setShellStyle(SWT.CLOSE | SWT.MAX | SWT.TITLE | SWT.BORDER
				| SWT.APPLICATION_MODAL | SWT.RESIZE | getDefaultOrientation());
		setWizard(newWizard);
		// since VAJava can't initialize an instance var with an anonymous
		// class outside a constructor we do it here:
		cancelListener = new SelectionAdapter() {
			public void widgetSelected(SelectionEvent e) {
				cancelPressed();
also subclassing did not do the trick:
	private class ModalWizardDialog extends WizardDialog {
		public ModalWizardDialog(Shell parentShell, IWizard newWizard) {
			super(parentShell, newWizard);
			setShellStyle(SWT.SHELL_TRIM | SWT.APPLICATION_MODAL);
Re: blockOnOpen = false for Wizards [message #491398 is a reply to message #491387] Wed, 14 October 2009 08:35 Go to previous messageGo to next message
so you want it none modal? Then remove SWT.APPLICATION_MODAL and the
Shell doesn't block anything any more.
Tom
> flag:
> super(parentShell);
> cancelPressed();
Re: blockOnOpen = false for Wizards [message #491407 is a reply to message #491181] Wed, 14 October 2009 09:11 Go to previous message
Oh, i'm sorry, how stupid.
Thanks a lot for your help!
[CLOSE]
[Updated on: Wed, 14 October 2009 09:12] by Moderator
Previous Topic:Eclipse Plugin and URLClassLoader
Next Topic:Having two distinct editors in one window
Current Time: Wed Jul 23 22:18:50 EDT 2025
Powered by FUDForum. Page generated in 0.04131 seconds
