Home » Eclipse Projects » Eclipse Platform » Handler doesn't work when it I make it to extend some class
Handler doesn't work when it I make it to extend some class [message #491359] Wed, 14 October 2009 06:19 Go to next message
Hi all,
I have placed a command on a view's toolbar.
I have implemented org.eclipse.core.commands.IHandler and provided it as the handler for the command and it works fine.
But this handler class should extend some other class.
As long as I keep this handler not-extended it all works fine.
But when it extends some other class the handler doesn't work.
As in no code in execute gets called.
How can I overcome this?
Is it not possible to make handler to extend some class and implement IHandler and use it as event handler for some command?
Thanks.
Re: Handler doesn't work when it I make it to extend some class [message #491371 is a reply to message #491359] Wed, 14 October 2009 07:23 Go to previous messageGo to next message
Any stack trace in the Error Log?
- Prakash
Platform UI Team, IBM
http://blog.eclipse-tips.com
Re: Handler doesn't work when it I make it to extend some class [message #491373 is a reply to message #491371] Wed, 14 October 2009 07:42 Go to previous messageGo to next message
Hi Prakash,
Here is the stack trace : http://pastebin.ca/1619123
The problem was this : Parent class from which I was trying to extend the handler didn't have a zero argument constructor.
After I added it, the execute method gets executed.
There are still questions though : Can I instantiate this handler class (extending some existing class) somewhere else in my plug-in?
Thanks.
Re: Handler doesn't work when it I make it to extend some class [message #491376 is a reply to message #491373] Wed, 14 October 2009 07:53 Go to previous messageGo to next message
You are not alone.
http://blog.eclipse-tips.com/2009/01/top-10-mistakes-in-ecli pse-plug-in.html
Yes. But do not call the IHandler methods on that class directly.
- Prakash
Re: Handler doesn't work when it I make it to extend some class [message #491405 is a reply to message #491376] Wed, 14 October 2009 09:06 Go to previous messageGo to next message
Hi Prakash,
Thanks so much. It helped.
Re: Handler doesn't work when it I make it to extend some class [message #491420 is a reply to message #491373] Wed, 14 October 2009 09:31 Go to previous message
kaprasi wrote on Wed, 14 October 2009 07:42
Hi Prakash,
As an aside, you can manage the objects that are instantiated from extensions (i.e. a "class" attribute) yourself, presuming you follow the API:
org.eclipse.core.runtime.IConfigurationElement.createExecuta bleExtension(String)
org.eclipse.core.runtime.IExecutableExtensionFactory
PW
Previous Topic:[CVS] file has been added but not commited
Next Topic:Resource conflicting rule
Current Time: Sat Jul 26 06:14:10 EDT 2025
Powered by FUDForum. Page generated in 0.05250 seconds
