Home » Archived » ATF » Static JS Classes not in the Outline view
Static JS Classes not in the Outline view [message #490873] Mon, 12 October 2009 02:50 Go to next message
Hello All,
I have a JS file which contains few static classes as well as non static ones.But the static classes are not shown in the outline view.Is it the limitation with the JSTD?.
Please provide your inputs here.
Thanks and Regards,
Saurav
Re: Static JS Classes not in the Outline view [message #490888 is a reply to message #490873] Mon, 12 October 2009 05:23 Go to previous messageGo to next message
hi Saurav,
the best place to ask this question is WTP newsgroup (JSDT is part of
WTP). I have added it in the To field.
saurav wrote:
> Hello All,
> Thanks and Regards,
> Saurav
Re: Static JS Classes not in the Outline view [message #491018 is a reply to message #490888] Mon, 12 October 2009 15:37 Go to previous messageGo to next message
Jacek Pospychala wrote:
> hi Saurav,
> saurav wrote:
>> Hello All,
Which version are you using, and do you have an example?
Nitin Dahyabhai
Eclipse WTP Source Editing
IBM Rational
Re: Static JS Classes not in the Outline view [message #491186 is a reply to message #490873] Tue, 13 October 2009 11:06 Go to previous message
Hi Nitin,
Please find the details below and the code snippet below.
Eclipse
Version: 3.4.2
Build id: M20090211-1700
JSDT core plug-in : 1.0.014
test.ui.saurav = function () {
test.ui.saurav.prototype.object = function() {
	var height=20;
if you press ctrl-o on the above code outline shows the classes.But try with the below code
test.ui.saurav.object = function() {
	var height=20;
Outline shows nothinh since the class is a static one.
Please let me know if i am missing something and provide your inputs here.
Thanks and Regards,
Saurav
[Updated on: Tue, 13 October 2009 11:06] by Moderator
Re: Static JS Classes not in the Outline view [message #561707 is a reply to message #490888] Mon, 12 October 2009 15:37 Go to previous message
> hi Saurav,
> saurav wrote:
>> Hello All,
Nitin Dahyabhai
IBM Rational
Previous Topic:ATF documentation
Next Topic:Static JS Classes not in the Outline view
Current Time: Thu Jul 24 22:58:58 EDT 2025
Powered by FUDForum. Page generated in 0.23834 seconds
