Home » Archived » BIRT » problem with BIRT charts(preview and catual does not match)
problem with BIRT charts [message #490896] Mon, 12 October 2009 05:56 Go to next message
when I tried to create a chart I can view the preview results(sample database that comes with the plugin) and when I finish creating the chart the chart doe not contain my dataset and displays a default one.(in chart preview this works fine..)
I am confused as to what wud the problem......?? when I checked the preview button on the report layout it says "tehre are errors evaluvating "new date()" eventho none of my data set has date field.itz just type of vehicles and orders...
im confused.....and wud apprciate a qucik reply frm u or anyone...
thx again...and hope to c a reply soon.
Re: problem with BIRT charts [message #490965 is a reply to message #490896] Mon, 12 October 2009 11:37 Go to previous messageGo to next message
Can you give some more details on how you are running the report? What
version of BIRT etc?
Jason
Re: problem with BIRT charts [message #491101 is a reply to message #490965] Tue, 13 October 2009 05:27 Go to previous messageGo to next message
hi,
thx for the reply.All I am doing in following the tutorial in the book "Field guide to reporting in BIRT" (second edition,by Diaana Peh and co) chapter 17(Using Chart)
I hv BIRT installed as a plugin on top of Zend Studio and the Zend studio update manager tells me the version is as follows
BIRT Chart Runtime Feature 2.3.0
BIRT reposrt designer framework 2.2.2
(none of them can be updatable via Zend Studio Update Manager as it says there are no update available eventho obviosly there is--I dont know whay it says so...)
(i hv attached the complete screenshot of the version info)
but rest of tutorials I hv tried works fine including Crosstab.so I beleive its just a plugin for chart that causing the problem....chart is in SVG format.
it preview it appears all ok as the book says but the moment I apply finish in the chart creation wizard just a default one appears not one witht he dataset I gave.
I tried it with different dataset and the problem is same....
Re: problem with BIRT charts [message #491195 is a reply to message #491101] Tue, 13 October 2009 11:25 Go to previous message
Can you log a request at the Zend site? It definitely looks like a
version mismatch. You may want to download the allinone for 2.2.2 or
the latest version of birt and try it.
Jason
> hi,
> whay it says so...)
> in SVG format.
Previous Topic:how to improve performance
Next Topic:Crosstab report stopped working
Current Time: Sun Sep 07 21:09:56 EDT 2025
Powered by FUDForum. Page generated in 0.04074 seconds
