Home » Eclipse Projects » Rich Client Platform (RCP) » Project Explorer and Markers(Questioning plugins or registrations necessary to restore missing markers in the project explorer)
Project Explorer and Markers [message #490805] Sat, 10 October 2009 20:49 Go to next message
I'm using Project Explorer in an RCP application. When launching a run configuration with some 1,000 platform plugins enabled, the problem markers appear correctly in the project explorer. However, when running with my desired 100-plugin target definition, the markers do not appear and there is no evidence in the console or logs that any bundles failed to resolve or that anything else yielded an exception. In both cases the problems are correctly reported in the problems view, so we know they were generated.
The workbench advisor is registering adapters through the IDE class at initialization using org.eclipse.ui.ide.IDE.registerAdapters(). It is also doing the project explorer image loading work-around to load the IDEInternalWorkbenchImages, so the folder icons and such appear correctly in the project explorer and problems view in both situations.
Nevertheless, the makers on files and projects do not appear when using the smaller collection of plugins. Is there something else that needs to be registered or loaded? What plugin is responsible for these markers?
Using the latest from 3.5.1. The problem occurs on both Windows Vista and Mac OS X.
Re: Project Explorer and Markers [message #495747 is a reply to message #490805] Thu, 05 November 2009 16:39 Go to previous messageGo to next message
Hi Matt,
I just ran into the same problem. If you enable the plugin
org.eclipse.jdt.ui and all required plugins, than the markers work. If
you disable only this plugin, they do no longer work. For me, that is
very unfortunate, as I do not want to have JDT enabled.
Hope it helps you.
Markus
> and Mac OS X.
Re: Project Explorer and Markers [message #495767 is a reply to message #495747] Thu, 05 November 2009 18:41 Go to previous message
Hi Matt,
I also found the classes in JDT UI where the stuff is implemented:
org.eclipse.jdt.internal.ui.viewsupport.ProblemMarkerManager
org.eclipse.jdt.ui.ProblemsLabelDecorator
I think the best solution for me is to clone them into my RCP.
Markus
Markus Herrmannsdörfer schrieb:
> Hi Matt,
> Hope it helps you.
> Cheers,
> Markus
>> view, so we know they were generated. The workbench advisor is
>> situations. Nevertheless, the makers on files and projects do not
>> responsible for these markers? Using the latest from 3.5.1. The
Previous Topic:TableViewer scrollbar problem
Next Topic:Upgrading product fails?
Current Time: Sat Jul 26 00:23:00 EDT 2025
Powered by FUDForum. Page generated in 0.02852 seconds
