Home » Eclipse Projects » Subversive » Updated ProjectSet connector - availability
Updated ProjectSet connector - availability [message #490665] Fri, 09 October 2009 11:34 Go to next message
Does anyone know when the updated ProjectSet connector will be available?
Currently I am getting the following conflict when I try to update my
connector.
Cannot complete the install because of a conflicting dependency.
Software being installed: Subversive Integration for the CSC Project Set
Project 2.0.2.I20090116-1600
(org.polarion.eclipse.team.svn.projectset.feature.group
2.0.2.I20090116-1600)
Software currently installed: ProjectSet 3.0.0.200905051715
(com.csc.dip.projectset.feature.group 3.0.0.200905051715)
Only one of the following can be installed at once:
Projectset 3.0.0.200905051715 (com.csc.dip.projectset
3.0.0.200905051715)
com.csc.dip.projectset 2.18.0.200811141124
Cannot satisfy dependency:
(com.csc.dip.projectset.feature.group 2.18.0.200811141124)
To: com.csc.dip.projectset
To: com.csc.dip.projectset [3.0.0.200905051715]
From: Subversive Integration for the CSC Project Set Project
2.0.2.I20090116-1600 (org.polarion.eclipse.team.svn.projectset.feature.group
To: com.csc.dip.projectset.feature.group [2.18.0.200811141124,3.0.0)
Re: Updated ProjectSet connector - availability [message #491711 is a reply to message #490665] Thu, 15 October 2009 10:32 Go to previous messageGo to next message
I created the corresponding bug on tracker:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=292407
> connector.
> 3.0.0.200905051715)
> From: ProjectSet 2.18.0.200811141124
> From: ProjectSet 3.0.0.200905051715
Re: Updated ProjectSet connector - availability [message #491881 is a reply to message #491711] Fri, 16 October 2009 07:29 Go to previous messageGo to next message
Thank you, I guess I could have done that but I just assumed that the
connector lineup would have already been scheduled for the upgrade
"Igor Burilo" <igor.burilo@polarion.org> wrote in message
news:hb7bpa$bd3$1@build.eclipse.org...
> Hello,
>> connector.
>> 3.0.0.200905051715)
Re: Updated ProjectSet connector - availability [message #492218 is a reply to message #491881] Mon, 19 October 2009 09:47 Go to previous messageGo to next message
Thanks for the issue. I've already fixed this problem and updated 'update
site'. Please, try it.
>> Hello,
>>> available?
>>> connector.
>>> Set Project 2.0.2.I20090116-1600
>>> 3.0.0.200905051715)
Re: Updated ProjectSet connector - availability [message #492265 is a reply to message #492218] Mon, 19 October 2009 11:52 Go to previous messageGo to next message
Thanks download now works, however, I am still getting the
org.polarion.team.svn.core.svnnature not supported
which plugin is that defines this, I thought it would be the PSP svn
integration.
news:hbhqkq$bla$1@build.eclipse.org...
> Hello,
>>> Hello,
>>>> available?
>>>> connector.
>>>> 3.0.0.200905051715)
Re: Updated ProjectSet connector - availability [message #492629 is a reply to message #492265] Wed, 21 October 2009 03:31 Go to previous messageGo to next message
You used old version of Subversive and you need to migrate to new one, for
more details how to migrate please see:
http://www.eclipse.org/subversive/documentation/gettingStart ed/aboutSubversive/update_polarion.php
> integration.
>> Hello,
>>>> Hello,
>>>>> available?
>>>>> connector.
>>>>> 3.0.0.200905051715)
Re: Updated ProjectSet connector - availability [message #492681 is a reply to message #492629] Wed, 21 October 2009 07:25 Go to previous messageGo to next message
Igor,
Thanks, unfortunately the project set that I was trying to load was a old
project set from a previous version of Eclipse which I no longer since I
have upgraded to 3.5.
However, it was fairly easy to figure out that I had to edit the PSF file
directly and replace the line
<provider id="org.polarion.team.svn.core.svnnature">
with
<provider id="org.eclipse.team.svn.core.svnnature">
Everything seems to be okay, but just to be sure is there anything that I
may have missed.
Thanks for your help BTW.
Whatty
news:hbmdbm$1cv$1@build.eclipse.org...
> Hello,
>> integration.
>>> Hello,
>>> 'update site'. Please, try it.
>>>>> Hello,
>>>>>> available?
>>>>>> connector.
>>>>>> 3.0.0.200905051715)
Re: Updated ProjectSet connector - availability [message #512786 is a reply to message #491881] Sun, 07 February 2010 07:02 Go to previous messageGo to next message
Sorry, what exactly is an CSC ProjectSet (connector) ?
As the discussion with other colleagues around the atomicity of commits
using Subversive lead to the asumption, commits were done for each
WorkingSet in Eclipse (as it always counts "n items" in the status bar which
is exactly the number of WorkingSets) I noticed, there's not only an Eclipse
WorkingSet, but a second "SVN WorkingSet". At least when you use
Subversive.
So what's this CSC Project or WorkingSet good for?
It seems, there are more fundamental problems with Subversive at the moment
than some fancy add-ons...
Werner
Re: Updated ProjectSet connector - availability [message #512921 is a reply to message #512786] Mon, 08 February 2010 06:10 Go to previous message
Hello Werner,
Commits atomicity doesn't depend on Working Sets, e.g. if you commit two
projects from the same repository and use SVNKit connector (JavaHL doesn't
support commit atomicity) then commit will be atomic.
We have long ago integration for CSC Project Set project, please see
http://vpms.de.csc.com/projectset/
> which is exactly the number of WorkingSets) I noticed, there's not only an
> Eclipse WorkingSet, but a second "SVN WorkingSet". At least when you use
> Subversive.
> moment than some fancy add-ons...
> Werner
Previous Topic:svn:keyword check setting into subversion
Next Topic:Linking Subversion repository at source-folder level
Current Time: Sun Oct 26 00:11:18 EDT 2025
Powered by FUDForum. Page generated in 0.04201 seconds
