Update results in error [message #490549] |
Fri, 09 October 2009 02:21  |
If I update my svn project I get the message:
Some resources were not updated.
svn: Processing REPORT request response failed: XML document structures
must start and end within the same entity. (/svn/!svn/vcc/default)
svn: REPORT request failed on '/svn/!svn/vcc/default'
It looks like the update was succesful. Any idea what could cause the
error message?
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
Re: Update results in error [message #491646 is a reply to message #491248] |
Thu, 15 October 2009 07:38   |
Hello Lars,
It seems this issues relates to svn connector you use. Probably it depends
on connection speed, network settings or something like this. Could you
please try to make update with another connector(SVNKit, JavaHL or with
another connector version)?
> Hi Jorg,
> I'm using SVN 1.6.
> I'm not sure what you mean with your question "Post comment hooks in the
> repo?". Can you please clarify?
> Best regards, Lars
> Jorg Thonnes wrote:
>> Hi Lars,
>> SVN Version? Post comment hooks in the repo?
>> I have never seen such messages.
>> Cheers, Jorg
>> On 10/09/09 08:21, Lars Vogel wrote:
>>> Hi,
>>> error message?
>>> Best regards, Lars
Re: Update results in error [message #491838 is a reply to message #491646] |
Fri, 16 October 2009 02:28   |
Hi Igor,
thanks. I believe I solved this issue. The project I tried to
synchronize was deleted on the server and then I tried to synchronize I
got this strange error.
Best regards, Lars
Igor Burilo wrote:
> Hello Lars,
>> Hi Jorg,
>> I'm using SVN 1.6.
>> Best regards, Lars
>> Jorg Thonnes wrote:
>>> Hi Lars,
>>> Cheers, Jorg
>>>> Hi,
>>>> error message?
>>>> Best regards, Lars
FUDForum. Page generated in 0.25170 seconds
