Home » Eclipse Projects » Standard Widget Toolkit (SWT) » size och swt labels
size och swt labels [message #489751] Mon, 05 October 2009 14:57 Go to next message
Is there a way to make a swt label to change the size of it self depending on the font, textsize and the length of the text connected to the label? I know that this is possible to a Swing Jlabel, but is this possible to a swt label?
Re: size och swt labels [message #489944 is a reply to message #489751] Tue, 06 October 2009 10:43 Go to previous messageGo to next message
If you are not using a layout in the Label's parent then use Control.pack()
to set its size to its preferred size based on its content.
If you are using a layout in the Label's parent then re-layout the parent
(Composite.layout()).
Grant
<larsk7@gmail.com> wrote in message news:hadfih$5b3$1@build.eclipse.org...
label?
Re: size och swt labels [message #490208 is a reply to message #489944] Wed, 07 October 2009 16:23 Go to previous messageGo to next message
I havent tried this yet but it looks great. Thanks!
Grant Gayed wrote on Tue, 06 October 2009 10:43
Grant
label?
Re: size och swt labels [message #490432 is a reply to message #489751] Thu, 08 October 2009 11:55 Go to previous messageGo to next message
I tried this now, and it seems to resize depending on the content. Smile
But. Is it possible to get the size that the label is gonna get directly after that the size has been changed? I wrote a test application where I want the correct size to be written in the other label without being forced to push the button one more time which I have to do now.
Is this possible? I just want to know how big the label is gonna get when it is drawed on the screen.
I haven't tried to used a layout yet, can that make it easier to get the size?
Thanks in advance!
package swtlabeltest;
import org.eclipse.swt.widgets.*;
import org.eclipse.swt.SWT;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.graphics.Font;
import org.eclipse.swt.graphics.FontData;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.events.SelectionListener;
import org.eclipse.swt.widgets.Button;
import org.eclipse.swt.widgets.Shell;
import org.eclipse.swt.widgets.Text;
public class Main
    public static void main(String[] args)
        final Display display = new Display();
        final Shell shell = new Shell(display);
        final Button button = new Button(shell, SWT.PUSH);
        button.setBounds(340, 150, 140, 40);
        button.setText("Change Size");
        final Text text = new Text(shell, SWT.BORDER);
        text.setBounds(100, 150, 140, 40);
        text.setText("12");
        final Label label = new Label(shell, SWT.MEDIUM);
        label.setLocation(540, 150);
        label.setBackground(new Color(display, 127, 178, 127));
        final Label labelOutput = new Label(shell, SWT.MEDIUM);
        labelOutput.setBounds(100, 350, 240, 100);
        labelOutput.setBackground(new Color(display, 127, 178, 127));
        button.addSelectionListener(new SelectionListener()
            public void widgetSelected(SelectionEvent event)
                label.setText("LabelSize: " + label.getSize().x + " " + label.getSize().y);
                Font fonten = new Font(display, new FontData("Arial", new Integer(text.getText()).intValue(), SWT.BOLD));
                label.pack();
                label.setFont(fonten);
                labelOutput.setText("Size: " + label.getSize() + "\r\nBounds: " + label.getBounds() + "");
                label.pack();
            public void widgetDefaultSelected(SelectionEvent event)
        shell.open();
        while (!shell.isDisposed())
            if (!display.readAndDispatch())
                display.sleep();
        display.dispose();
Re: size och swt labels [message #490497 is a reply to message #489751] Thu, 08 October 2009 16:23 Go to previous messageGo to next message
My mistake!
I seem to have written some errors in my code. I wrote the output to soon.
My code is now as follows and it works!:
                Font font = new Font(display, new FontData("Arial", new Integer(text2.getText()).intValue(), SWT.BOLD));
                label.pack();
                labelOutput.setText("size: " + label2.getSize() + "\r\nborderWidth: " + label2.getBorderWidth() + "\r\nbounds: " + label2.getBounds() + "");
Re: size och swt labels [message #491247 is a reply to message #490497] Tue, 13 October 2009 14:46 Go to previous message
You can use Control.computeSize(SWT.DEFAULT,SWT.DEFAULT) to get the
preferred size of a Control based on its content without actually changing
its bounds to this.
Grant
<larsk7@gmail.com> wrote in message news:halhn9$n22$1@build.eclipse.org...
> My mistake!
> @Override
> label.pack();
Previous Topic:problem whit load image
Next Topic:Re: [BUG?] Performance problem with TreeViewers under Windows XP
Current Time: Sat Jul 26 07:51:06 EDT 2025
Powered by FUDForum. Page generated in 0.06310 seconds
