Home » Eclipse Projects » JFace » TitleAreaDialog: Widgets disposed after click on the OK-Button
TitleAreaDialog: Widgets disposed after click on the OK-Button [message #490423] Thu, 08 October 2009 11:39 Go to next message
I have a JFace TitleAreaDialog, which change some properties for a given person.
In this dialog there are some textfields and some radio-Buttons.
I generate the OK and Cancel Button in the methode createButtonsForButtonBar().
	protected void createButtonsForButtonBar(Composite parent) {
		okButton = createButton(parent, IDialogConstants.OK_ID, IDialogConstants.OK_LABEL, true);
		okButton.addSelectionListener(new SelectionAdapter() {
			public void widgetSelected(SelectionEvent e) {
				person.setName(name.getText());
				setReturnCode(OK);
				close();
		cancelButton = createButton(parent, IDialogConstants.CANCEL_ID, IDialogConstants.CANCEL_LABEL, false);
	   	cancelButton.addSelectionListener(new SelectionAdapter() {
	        setReturnCode(CANCEL);
	        close();
But the problem is, when I click the ok Button and want to set the properties for the person., all textfields, radiobuttons are disposed and I don't get any values.
What is the reason for that, and what must I changed to set the values after click on the ok-Button.
Re: TitleAreaDialog: Widgets disposed after click on the OK-Button [message #490447 is a reply to message #490423] Thu, 08 October 2009 12:43 Go to previous messageGo to next message
Originally posted by: evelyne.rien.com
You can override okPressed() like this :
* (non-Javadoc)
* @see org.eclipse.jface.dialogs.Dialog#okPressed()
protected void okPressed() {
super.okPressed();
Don't call super.okPressed() if you want to cancel validation on some
controls (empty name for example).
It works for me when i'm subclassing JFace Dialog.
BTW : like okPressed(), okCancel() is called on Cancel Button.
Evelyne.
"Michelle Davidson" <michelle.davidson@gmx.de> a
Re: TitleAreaDialog: Widgets disposed after click on the OK-Button [message #490448 is a reply to message #490447] Thu, 08 October 2009 12:47 Go to previous messageGo to next message
oups.
instead of okCancel(), read cancelPressed().
Re: TitleAreaDialog: Widgets disposed after click on the OK-Button [message #490545 is a reply to message #490448] Fri, 09 October 2009 02:18 Go to previous message
Thanks, that works fine for me.
Previous Topic:Editor with JFace Text
Next Topic:Get imagefilename for a column of a tableviewer
Current Time: Fri Jul 18 13:37:28 EDT 2025
Powered by FUDForum. Page generated in 0.07358 seconds
