Home » Modeling » EMF » Re: GMF & TENEO
Re: GMF & TENEO [message #490126] |
Wed, 07 October 2009 08:53  |
Hi Rafnixx,
Which version of Hibernate are you using? With Teneo 1.1.1/1.1.2 you need to use Hibernate 3.3.2 (and not 3.3.1 or earlier).
Btw, support for Teneo is given on the main EMF newsgroup which I added in the cc.
gr. Martin
rafnixx@hushmail.com wrote:
> I tried to repeat this tutorial.
> http://www.elver.org/hibernate/gmftutorial/tutorial1.html. I thought
> everything works good, but when I tried to run the example & the new
> workbench opened, I couldn't see the mindmap diagram which I made before
> the tutorial, there is an error:
> Could not open the editor: The editor class could not be instantiated.
> This usually indicates a missing no-arg constructor or that the editor's
> class name was mistyped in plugin.xml.
> org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter
> $TerminatingClassNotFoundException: An error occurred while
> automatically activating bundle
> org.eclipse.gmf.examples.mindmap.rcp.diagram (766).
> at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter
> .postFindLocalClass(EclipseLazyStarter.java:125)
> at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc
> alClass(ClasspathManager.java:449)
> at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin
> dLocalClass(DefaultClassLoader.java:211)
> at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass
> (BundleLoader.java:381)
> at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter
> nal(BundleLoader.java:457)
> at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund
> leLoader.java:410)
> leLoader.java:398)
> at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa
> dClass(DefaultClassLoader.java:105)
> at java.lang.ClassLoader.loadClass(Unknown Source)
> at org.eclipse.osgi.internal.loader.BundleLoader.loadClass(Bund
> leLoader.java:326)
> at org.eclipse.osgi.framework.internal.core.BundleHost.loadClas
> s(BundleHost.java:231)
> at org.eclipse.osgi.framework.internal.core.AbstractBundle.load
> Class(AbstractBundle.java:1193)
> at org.eclipse.core.internal.registry.osgi.RegistryStrategyOSGI
> .createExecutableExtension(RegistryStrategyOSGI.java:160)
> at org.eclipse.core.internal.registry.ExtensionRegistry.createE
> xecutableExtension(ExtensionRegistry.java:874)
> at org.eclipse.core.internal.registry.ConfigurationElement.crea
> teExecutableExtension(ConfigurationElement.java:243)
> at org.eclipse.core.internal.registry.ConfigurationElementHandl
> e.createExecutableExtension(ConfigurationElementHandle.java: 51)
> at org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi
> n.java:267)
> at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator
> .java:70)
> at org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work
> benchPlugin.java:263)
> at org.eclipse.ui.internal.registry.EditorDescriptor.createEdit
> or(EditorDescriptor.java:235)
> at org.eclipse.ui.internal.EditorManager.createPart(EditorManag
> er.java:845)
> at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi
> torReference.java:606)
> at org.eclipse.ui.internal.EditorReference.createPart(EditorRef
> erence.java:462)
> at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb
> enchPartReference.java:595)
> at org.eclipse.ui.internal.EditorAreaHelper.setVisibleEditor(Ed
> itorAreaHelper.java:271)
> at org.eclipse.ui.internal.EditorManager.setVisibleEditor(Edito
> rManager.java:1417)
> at org.eclipse.ui.internal.EditorManager$5.runWithException(Edi
> torManager.java:942)
> at org.eclipse.ui.internal.StartupThreading$StartupRunnable.run
> (StartupThreading.java:31)
> at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
> at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr
> onizer.java:134)
> at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav
> a:3855)
> at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3476)
> at org.eclipse.ui.application.WorkbenchAdvisor.openWindows(Work
> benchAdvisor.java:803)
> at org.eclipse.ui.internal.Workbench$28.runWithException(Workbe
> nch.java:1384)
> onizer.java:134)
> a:3855)
> at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2316)
> at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
> at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
> at org.eclipse.core.databinding.observable.Realm.runWithDefault
> (Realm.java:332)
> at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work
> bench.java:493)
> at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j
> ava:149)
> at org.eclipse.ui.internal.ide.application.IDEApplication.start
> (IDEApplication.java:113)
> at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips
> eAppHandle.java:194)
> at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher
> .runApplication(EclipseAppLauncher.java:110)
> .start(EclipseAppLauncher.java:79)
> at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS
> tarter.java:368)
> tarter.java:179)
> at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
> at org.eclipse.equinox.launcher.Main.basicRun(Main.java:514)
> at org.eclipse.equinox.launcher.Main.run(Main.java:1311)
> at org.eclipse.equinox.launcher.Main.main(Main.java:1287)
> Caused by: org.osgi.framework.BundleException: Exception in
> org.eclipse.gmf.examples.mindmap.rcp.diagram.part.MindmapDia
> gramEditorPlugin.start() of bundle
> at org.eclipse.osgi.framework.internal.core.BundleContextImpl.s
> tartActivator(BundleContextImpl.java:806)
> tart(BundleContextImpl.java:755)
> at org.eclipse.osgi.framework.internal.core.BundleHost.startWor
> ker(BundleHost.java:352)
> at org.eclipse.osgi.framework.internal.core.AbstractBundle.star
> t(AbstractBundle.java:280)
> at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct
> ion.java:408)
> .postFindLocalClass(EclipseLazyStarter.java:111)
> ... 58 more
> Caused by: java.lang.NoClassDefFoundError: org/hibernate/EntityNameResolver
> at org.eclipse.gmf.examples.mindmap.rcp.diagram.db.StoreControl
> ler.initializeDataStore(StoreController.java:81)
> at org.eclipse.gmf.examples.mindmap.rcp.diagram.part.MindmapDia
> gramEditorPlugin.start(MindmapDiagramEditorPlugin.java:71)
> at org.eclipse.osgi.framework.internal.core.BundleContextImpl$1
> .run(BundleContextImpl.java:783)
> at java.security.AccessController.doPrivileged(Native Method)
> tartActivator(BundleContextImpl.java:774)
> ... 63 more
> Caused by: java.lang.ClassNotFoundException:
> org.hibernate.EntityNameResolver
> nal(BundleLoader.java:494)
> leLoader.java:410)
> leLoader.java:398)
> at java.lang.ClassLoader.loadClassInternal(Unknown Source)
> ... 68 more
> When I try: File - New - Mindmap Diagram then I read: The chosen
> operation is not currently available, the same if I press the Mindmap DB
> button.
> If I delete the StoreController.getInstance().initializeDataStore(); in
> the stop method of MindmapDiagramEditorPlugin.java (Initialize Teneo
> when plugin starts -
> http://www.elver.org/hibernate/gmftutorial/tutorial2.html - down on the
> side) than it works, but without DB.
> I use a empty SQL Server 2005 database and I think the jdbc driver and
> all the packeges are correct.
> What can I do - hope you can help me.
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: GMF & TENEO [message #490269 is a reply to message #490126] |
Thu, 08 October 2009 03:22   |
it's me again, than lets continue here.
I'm using Teneo 1.1.2 and Hibernate 3.3.2.GA in a seperate Plugin.
Yesterday I tried mapping with Hibernate Tools for Eclipse and its works.
Any idea why it doesn't works like in the tutorial?
I Insalled eclipse-modeling-galileo-SR1-incubation-win32.zip with Eclipse Modeling Tools 1.2.1, EMF Teneo Hibernate 1.1.2 an Hibernate Tools 3.2.4.
from CVS:
org.eclipse.gmf.examples.mindmap.edit
org.eclipse.gmf.examples.mindmap.rcp.diagram - Here I made the changes from the tutorial
I built my own Hibernate_Plugin called plugin - MANIFEST.MF
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Hibernate_Plugin
Bundle-SymbolicName: Hibernate_Plugin
Bundle-Version: 1.0.0.qualifier
Bundle-Activator: hibernate_plugin.Activator
Require-Bundle: org.eclipse.ui,
org.eclipse.core.runtime,
org.eclipse.emf.teneo;bundle-version="1.1.1",
org.eclipse.emf.teneo.annotations;bundle-version="1.1.0",
org.eclipse.emf.teneo.hibernate.mapper;bundle-version="1.1.2 ",
org.eclipse.emf.teneo.hibernate;bundle-version="1.1.2"
Bundle-ActivationPolicy: lazy
Bundle-RequiredExecutionEnvironment: JavaSE-1.6,
J2SE-1.5
Eclipse-BuddyPolicy: dependent
Import-Package: org.hibernate
Referenced Libraries:
hibernate3.jae
hibernate-testing.jar
antlr-2.7.6.jar
commons-collections-3.1.jar
dom4j-1.6.1.jar
javassist-3.9.0.GA.jar
jta-1.1.jar
slf4j-api-1.5.8.jar
sqljdbc4.jar
org.eclipse.gmf.examples.mindmap - MANIFEST.MF:
Bundle-Name: %pluginName
Bundle-SymbolicName: org.eclipse.gmf.examples.mindmap; singleton:=true
Bundle-ClassPath: .
Bundle-Vendor: %providerName
Bundle-Localization: plugin
Bundle-RequiredExecutionEnvironment: J2SE-1.5
Export-Package: org.eclipse.gmf.examples.mindmap,
org.eclipse.gmf.examples.mindmap.impl,
org.eclipse.gmf.examples.mindmap.util
Require-Bundle: org.eclipse.core.runtime,
org.eclipse.emf.ecore;visibility:=reexport,
org.eclipse.emf.ecore.xmi;visibility:=reexport,
org.eclipse.emf.teneo.hibernate;bundle-version="1.1.2";visibility:=reexport,
Hibernate_Plugin;bundle-version="1.0.0"
Eclipse-LazyStart: true
org.eclipse.gmf.examples.mindmap.rcp.diagram - MANIFEST.MF
Bundle-SymbolicName: org.eclipse.gmf.examples.mindmap.rcp.diagram; singleton:=true
Bundle-ClassPath: .
Bundle-Activator: org.eclipse.gmf.examples.mindmap.rcp.diagram.part.MindmapDia gramEditorPlugin
Export-Package: org.eclipse.gmf.examples.mindmap.rcp.diagram.edit.parts,
org.eclipse.gmf.examples.mindmap.rcp.diagram.part,
org.eclipse.gmf.examples.mindmap.rcp.diagram.providers
org.eclipse.jface,
org.eclipse.ui.views,
org.eclipse.emf.ecore,
org.eclipse.emf.ecore.xmi,
org.eclipse.emf.edit.ui,
org.eclipse.gmf.runtime.emf.core,
org.eclipse.gmf.runtime.emf.commands.core,
org.eclipse.gmf.runtime.emf.ui.properties,
org.eclipse.gmf.runtime.diagram.ui,
org.eclipse.gmf.runtime.diagram.ui.properties,
org.eclipse.gmf.runtime.diagram.ui.providers,
org.eclipse.gmf.runtime.diagram.ui.render,
org.eclipse.gmf.runtime.diagram.ui.resources.editor,
org.eclipse.gmf.examples.mindmap;visibility:=reexport,
org.eclipse.gmf.examples.mindmap.edit;visibility:=reexport,
org.eclipse.ocl.ecore;visibility:=reexport,
org.eclipse.emf.validation;visibility:=reexport,
org.eclipse.gmf.runtime.draw2d.ui;visibility:=reexport,
org.eclipse.gef;visibility:=reexport,
org.eclipse.emf.validation.ocl;visibility:=reexport
I hope anybody can help with this informations.
Re: GMF & TENEO [message #490271 is a reply to message #490126] |
Thu, 08 October 2009 03:25   |
from CVS:
J2SE-1.5
hibernate3.jae
antlr-2.7.6.jar
dom4j-1.6.1.jar
jta-1.1.jar
slf4j-api-1.5.8.jar
sqljdbc4.jar
Bundle-ClassPath: .
Bundle-ClassPath: .
org.eclipse.jface,
Re: GMF & TENEO [message #490289 is a reply to message #490271] |
Thu, 08 October 2009 04:46   |
Hi Rafnixx,
A first thing I saw, your hibernate library in the manifest below seems to have a strange name:
hibernate3.jae
instead of
hibernate3.jar
Your hibernate jar file requires teneo etc. Afaics the hibernate plugin does not need to require other plugins.
I would also reexport the hibernate plugin in the manifest.mf of the org.eclipse.gmf.examples.mindmap.
Let me know if this helped (or not ofcourse).
gr. Martin
> Tools 3.2.4.
> from CVS:
> from the tutorial
> J2SE-1.5
> Referenced Libraries: hibernate3.jae
> antlr-2.7.6.jar
> dom4j-1.6.1.jar
> jta-1.1.jar
> slf4j-api-1.5.8.jar
> sqljdbc4.jar
> Bundle-ClassPath: .
> singleton:=true
> Bundle-ClassPath: .
> Bundle-Activator:
> gramEditorPlugin
> org.eclipse.jface,
The Netherlands
Re: GMF & TENEO [message #490296 is a reply to message #490292] |
Thu, 08 October 2009 05:25   |
--------------090802060802050702000206
Hi Rafnixx,
I mean this part:
is not needed in the hibernate plugin manifest.mf.
The bundle does not need an activator either (but this is unimportant).
Also the hibernate plugin does an Import-package for org.hibernate, this shouldn't be there.
But what is needed: the hibernate plugin needs to export the hibernate java packages.
Also can you check if the hibernate jar files are present in the build.properties?
In my hibernate libraries manifest.mf the jar files are defined in the bundle-classpath in your case you use referenced
libraries (I am not sure what the difference is).
I have attached the manifest.mf/build.properties of my own hibernate plugin, I won't say you need to copy that exactly
but it can give some other pointers I did not think of.
gr. Martin
> Hi Martin,
> thx for your answer.
> hibernate3.jar was only a write error
> I reexported my hibernate plugin in manifest.mf, but allways still same
> error.
> Your wrote: Your hibernate jar file requires teneo etc. Afaics the
> I'm sorry but I don't understand what you mean and/or what should I do now.
The Netherlands
name="MANIFEST.MF"
Content-Disposition: inline;
filename="MANIFEST.MF"
TWFuaWZlc3QtVmVyc2lvbjogMS4wCkJ1bmRsZS1NYW5pZmVzdFZlcnNpb246 IDIKQnVuZGxl
LU5hbWU6ICVQbHVnaW4ubmFtZQpCdW5kbGUtU3ltYm9saWNOYW1lOiBvcmcu ZWNsaXBzZS5l
bWYudGVuZW8uaGliZXJuYXRlLmxpYnJhcmllcwpCdW5kbGUtVmVyc2lvbjog MS4xLjAucXVh
bGlmaWVyCkVjbGlwc2UtQnVkZHlQb2xpY3k6IGRlcGVuZGVudApCdW5kbGUt TG9jYWxpemF0
aW9uOiBwbHVnaW4KRXhwb3J0LVBhY2thZ2U6IAogYW50bHIsCiBhbnRsci5B U2RlYnVnLAog
YW50bHIuYWN0aW9ucy5jcHAsCiBhbnRsci5hY3Rpb25zLmNzaGFycCwKIGFu dGxyLmFjdGlv
bnMuamF2YSwKIGFudGxyLmFjdGlvbnMucHl0aG9uLAogYW50bHIuYnVpbGQs CiBhbnRsci5j
b2xsZWN0aW9ucywKIGFudGxyLmNvbGxlY3Rpb25zLmltcGwsCiBhbnRsci5k ZWJ1ZywKIGFu
dGxyLmRlYnVnLm1pc2MsCiBhbnRsci5wcmVwcm9jZXNzb3IsCiBjb20ubWNo YW5nZSwKIGNv
bS5tY2hhbmdlLmxhbmcsCiBjb20ubWNoYW5nZS51dGlsLAogY29tLm1jaGFu Z2UudjEsCiBj
b20ubWNoYW5nZS52MS5kYiwKIGNvbS5tY2hhbmdlLnYxLmRiLnNxbCwKIGNv bS5tY2hhbmdl
LnYxLmlkZW50aWNhdG9yLAogY29tLm1jaGFuZ2UudjEuaW8sCiBjb20ubWNo YW5nZS52MS5s
YW5nLAogY29tLm1jaGFuZ2UudjEudXRpbCwKIGNvbS5tY2hhbmdlLnYxLnht bCwKIGNvbS5t
Y2hhbmdlLnYyLAogY29tLm1jaGFuZ2UudjIuYXN5bmMsCiBjb20ubWNoYW5n ZS52Mi5iZWFu
cywKIGNvbS5tY2hhbmdlLnYyLmMzcDAsCiBjb20ubWNoYW5nZS52Mi5jM3Aw LmNmZywKIGNv
bS5tY2hhbmdlLnYyLmMzcDAuZmlsdGVyLAogY29tLm1jaGFuZ2UudjIuYzNw MC5pbXBsLAog
Y29tLm1jaGFuZ2UudjIuYzNwMC5qYm9zcywKIGNvbS5tY2hhbmdlLnYyLmMz cDAubWFuYWdl
bWVudCwKIGNvbS5tY2hhbmdlLnYyLmMzcDAubWJlYW4sCiBjb20ubWNoYW5n ZS52Mi5jM3Aw
LnN0bXQsCiBjb20ubWNoYW5nZS52Mi5jM3AwLnN1YnN0LAogY29tLm1jaGFu Z2UudjIuYzNw
MC51dGlsLAogY29tLm1jaGFuZ2UudjIuY2ZnLAogY29tLm1jaGFuZ2UudjIu Y29hbGVzY2Us
CiBjb20ubWNoYW5nZS52Mi5jb2RlZ2VuLAogY29tLm1jaGFuZ2UudjIuY29k ZWdlbi5iZWFu
LAogY29tLm1jaGFuZ2UudjIuY29kZWdlbi5pbnRmYywKIGNvbS5tY2hhbmdl LnYyLmRlYnVn
LAogY29tLm1jaGFuZ2UudjIuZW5jb3VudGVyLAogY29tLm1jaGFuZ2UudjIu aG9sZGVycywK
IGNvbS5tY2hhbmdlLnYyLmlvLAogY29tLm1jaGFuZ2UudjIubGFuZywKIGNv bS5tY2hhbmdl
LnYyLmxvZywKIGNvbS5tY2hhbmdlLnYyLmxvZy5qZGsxNGxvZ2dpbmcsCiBj b20ubWNoYW5n
ZS52Mi5sb2cubG9nNGosCiBjb20ubWNoYW5nZS52Mi5tYW5hZ2VtZW50LAog Y29tLm1jaGFu
Z2UudjIubmFtaW5nLAogY29tLm1jaGFuZ2UudjIucmVzb3VyY2Vwb29sLAog Y29tLm1jaGFu
Z2UudjIuc2VyLAogY29tLm1jaGFuZ2UudjIuc3FsLAogY29tLm1jaGFuZ2Uu djIuc3FsLmZp
bHRlciwKIGNvbS5tY2hhbmdlLnYyLnV0aWwsCiBjb20ubXlzcWwuamRiYywK IGNvbS5teXNx
bC5qZGJjLmV4Y2VwdGlvbnMsCiBjb20ubXlzcWwuamRiYy5leGNlcHRpb25z LmpkYmM0LAog
Y29tLm15c3FsLmpkYmMuaW50ZWdyYXRpb24uYzNwMCwKIGNvbS5teXNxbC5q ZGJjLmludGVn
cmF0aW9uLmpib3NzLAogY29tLm15c3FsLmpkYmMuaW50ZXJjZXB0b3JzLAog Y29tLm15c3Fs
LmpkYmMuamRiYzIub3B0aW9uYWwsCiBjb20ubXlzcWwuamRiYy5sb2csCiBj b20ubXlzcWwu
amRiYy5wcm9maWxlciwKIGNvbS5teXNxbC5qZGJjLnV0aWwsCiBqYXZhc3Np c3QsCiBqYXZh
c3Npc3QuYnl0ZWNvZGUsCiBqYXZhc3Npc3QuYnl0ZWNvZGUuYW5hbHlzaXMs CiBqYXZhc3Np
c3QuYnl0ZWNvZGUuYW5ub3RhdGlvbiwKIGphdmFzc2lzdC5ieXRlY29kZS5z dGFja21hcCwK
IGphdmFzc2lzdC5jb21waWxlciwKIGphdmFzc2lzdC5jb21waWxlci5hc3Qs CiBqYXZhc3Np
c3QuY29udmVydCwKIGphdmFzc2lzdC5leHByLAogamF2YXNzaXN0LnJ1bnRp bWUsCiBqYXZh
c3Npc3Quc2NvcGVkcG9vbCwKIGphdmFzc2lzdC50b29scywKIGphdmFzc2lz dC50b29scy5y
ZWZsZWN0LAogamF2YXNzaXN0LnRvb2xzLnJtaSwKIGphdmFzc2lzdC50b29s cy53ZWIsCiBq
YXZhc3Npc3QudXRpbCwKIGphdmFzc2lzdC51dGlsLnByb3h5LAogamF2YXgu cGVyc2lzdGVu
Y2UsCiBqYXZheC5wZXJzaXN0ZW5jZS5vc2dpLAogamF2YXgucGVyc2lzdGVu Y2Uuc3BpLAog
amF2YXgudHJhbnNhY3Rpb24sCiBqYXZheC50cmFuc2FjdGlvbi54YSwKIG5l dC5zZi5laGNh
Y2hlLAogbmV0LnNmLmVoY2FjaGUuYm9vdHN0cmFwLAogbmV0LnNmLmVoY2Fj aGUuY29uZmln
LAogbmV0LnNmLmVoY2FjaGUuY29uc3RydWN0cy5hc3luY2hyb25vdXMsCiBu ZXQuc2YuZWhj
YWNoZS5jb25zdHJ1Y3RzLmJsb2NraW5nLAogbmV0LnNmLmVoY2FjaGUuY29u c3RydWN0cy5j
b25jdXJyZW50LAogbmV0LnNmLmVoY2FjaGUuY29uc3RydWN0cy53ZWIsCiBu ZXQuc2YuZWhj
YWNoZS5jb25zdHJ1Y3RzLndlYi5maWx0ZXIsCiBuZXQuc2YuZWhjYWNoZS5k aXN0cmlidXRp
b24sCiBuZXQuc2YuZWhjYWNoZS5ldmVudCwKIG5ldC5zZi5laGNhY2hlLmhp YmVybmF0ZSwK
IG5ldC5zZi5laGNhY2hlLnN0b3JlLAogbmV0LnNmLmVoY2FjaGUudXRpbCwK IG9yZy5hcGFj
aGUuY29tbW9ucy5jb2xsZWN0aW9ucywKIG9yZy5hcGFjaGUuY29tbW9ucy5j b2xsZWN0aW9u
cy5iYWcsCiBvcmcuYXBhY2hlLmNvbW1vbnMuY29sbGVjdGlvbnMuYmlkaW1h cCwKIG9yZy5h
cGFjaGUuY29tbW9ucy5jb2xsZWN0aW9ucy5idWZmZXIsCiBvcmcuYXBhY2hl LmNvbW1vbnMu
Y29sbGVjdGlvbnMuY29sbGVjdGlvbiwKIG9yZy5hcGFjaGUuY29tbW9ucy5j b2xsZWN0aW9u
cy5jb21wYXJhdG9ycywKIG9yZy5hcGFjaGUuY29tbW9ucy5jb2xsZWN0aW9u cy5mdW5jdG9y
cywKIG9yZy5hcGFjaGUuY29tbW9ucy5jb2xsZWN0aW9ucy5pdGVyYXRvcnMs CiBvcmcuYXBh
Y2hlLmNvbW1vbnMuY29sbGVjdGlvbnMua2V5dmFsdWUsCiBvcmcuYXBhY2hl LmNvbW1vbnMu
Y29sbGVjdGlvbnMubGlzdCwKIG9yZy5hcGFjaGUuY29tbW9ucy5jb2xsZWN0 aW9ucy5tYXAs
CiBvcmcuYXBhY2hlLmNvbW1vbnMuY29sbGVjdGlvbnMuc2V0LAogb3JnLmRv bTRqLAogb3Jn
LmRvbTRqLmJlYW4sCiBvcmcuZG9tNGouZGF0YXR5cGUsCiBvcmcuZG9tNGou ZG9tLAogb3Jn
LmRvbTRqLmR0ZCwKIG9yZy5kb200ai5pbywKIG9yZy5kb200ai5qYXhiLAog b3JnLmRvbTRq
LnJ1bGUsCiBvcmcuZG9tNGoucnVsZS5wYXR0ZXJuLAogb3JnLmRvbTRqLnN3 aW5nLAogb3Jn
LmRvbTRqLnRyZWUsCiBvcmcuZG9tNGoudXRpbCwKIG9yZy5kb200ai54cGF0 aCwKIG9yZy5k
b200ai54cHAsCiBvcmcuZ2p0Lm1tLm15c3FsLAogb3JnLmhpYmVybmF0ZSwK IG9yZy5oaWJl
cm5hdGUuYWN0aW9uLAogb3JnLmhpYmVybmF0ZS5hbm5vdGF0aW9ucywKIG9y Zy5oaWJlcm5h
dGUuYW5ub3RhdGlvbnMuY29tbW9uLAogb3JnLmhpYmVybmF0ZS5hbm5vdGF0 aW9ucy5jb21t
b24uYW5ub3RhdGlvbmZhY3RvcnksCiBvcmcuaGliZXJuYXRlLmFubm90YXRp b25zLmNvbW1v
bi5yZWZsZWN0aW9uLAogb3JnLmhpYmVybmF0ZS5hbm5vdGF0aW9ucy5jb21t b24ucmVmbGVj
dGlvbi5qYXZhLAogb3JnLmhpYmVybmF0ZS5hbm5vdGF0aW9ucy5jb21tb24u cmVmbGVjdGlv
bi5qYXZhLmdlbmVyaWNzLAogb3JnLmhpYmVybmF0ZS5hbm5vdGF0aW9ucy5j b21tb24udXRp
bCwKIG9yZy5oaWJlcm5hdGUuYnl0ZWNvZGUsCiBvcmcuaGliZXJuYXRlLmJ5 dGVjb2RlLmNn
bGliLAogb3JnLmhpYmVybmF0ZS5ieXRlY29kZS5qYXZhc3Npc3QsCiBvcmcu aGliZXJuYXRl
LmJ5dGVjb2RlLnV0aWwsCiBvcmcuaGliZXJuYXRlLmNhY2hlLAogb3JnLmhp YmVybmF0ZS5j
YWNoZS5hY2Nlc3MsCiBvcmcuaGliZXJuYXRlLmNhY2hlLmVudHJ5LAogb3Jn LmhpYmVybmF0
ZS5jYWNoZS5pbXBsLAogb3JnLmhpYmVybmF0ZS5jYWNoZS5pbXBsLmJyaWRn ZSwKIG9yZy5o
aWJlcm5hdGUuY2FjaGUuamJjMiwKIG9yZy5oaWJlcm5hdGUuY2FjaGUuamJj Mi5hY2Nlc3Ms
CiBvcmcuaGliZXJuYXRlLmNhY2hlLmpiYzIuYnVpbGRlciwKIG9yZy5oaWJl cm5hdGUuY2Fj
aGUuamJjMi5jb2xsZWN0aW9uLAogb3JnLmhpYmVybmF0ZS5jYWNoZS5qYmMy LmVudGl0eSwK
IG9yZy5oaWJlcm5hdGUuY2FjaGUuamJjMi5xdWVyeSwKIG9yZy5oaWJlcm5h dGUuY2FjaGUu
amJjMi50aW1lc3RhbXAsCiBvcmcuaGliZXJuYXRlLmNhY2hlLmpiYzIudXRp bCwKIG9yZy5o
aWJlcm5hdGUuY2ZnLAogb3JnLmhpYmVybmF0ZS5jZmcuYW5ub3RhdGlvbnMs CiBvcmcuaGli
ZXJuYXRlLmNmZy5hbm5vdGF0aW9ucy5yZWZsZWN0aW9uLAogb3JnLmhpYmVy bmF0ZS5jZmcu
c2VhcmNoLAogb3JnLmhpYmVybmF0ZS5jbGFzc2ljLAogb3JnLmhpYmVybmF0 ZS5jb2xsZWN0
aW9uLAogb3JnLmhpYmVybmF0ZS5jb25uZWN0aW9uLAogb3JnLmhpYmVybmF0 ZS5jb250ZXh0
LAogb3JnLmhpYmVybmF0ZS5jcml0ZXJpb24sCiBvcmcuaGliZXJuYXRlLmRp YWxlY3QsCiBv
cmcuaGliZXJuYXRlLmRpYWxlY3QuZnVuY3Rpb24sCiBvcmcuaGliZXJuYXRl LmRpYWxlY3Qu
bG9jaywKIG9yZy5oaWJlcm5hdGUuZWpiLAogb3JnLmhpYmVybmF0ZS5lamIu Y29ubmVjdGlv
biwKIG9yZy5oaWJlcm5hdGUuZWpiLmV2ZW50LAogb3JnLmhpYmVybmF0ZS5l amIuaW5zdHJ1
bWVudCwKIG9yZy5oaWJlcm5hdGUuZWpiLnBhY2thZ2luZywKIG9yZy5oaWJl cm5hdGUuZWpi
LnRyYW5zYWN0aW9uLAogb3JnLmhpYmVybmF0ZS5lamIudXRpbCwKIG9yZy5o aWJlcm5hdGUu
ZW5naW5lLAogb3JnLmhpYmVybmF0ZS5lbmdpbmUubG9hZGluZywKIG9yZy5o aWJlcm5hdGUu
ZW5naW5lLnF1ZXJ5LAogb3JnLmhpYmVybmF0ZS5lbmdpbmUucXVlcnkuc3Fs LAogb3JnLmhp
YmVybmF0ZS5lbmdpbmUudHJhbnNhY3Rpb24sCiBvcmcuaGliZXJuYXRlLmV2 ZW50LAogb3Jn
LmhpYmVybmF0ZS5ldmVudC5kZWYsCiBvcmcuaGliZXJuYXRlLmV4Y2VwdGlv biwKIG9yZy5o
aWJlcm5hdGUuaHFsLAogb3JnLmhpYmVybmF0ZS5ocWwuYW50bHIsCiBvcmcu aGliZXJuYXRl
LmhxbC5hc3QsCiBvcmcuaGliZXJuYXRlLmhxbC5hc3QuZXhlYywKIG9yZy5o aWJlcm5hdGUu
aHFsLmFzdC50cmVlLAogb3JnLmhpYmVybmF0ZS5ocWwuYXN0LnV0aWwsCiBv cmcuaGliZXJu
YXRlLmhxbC5jbGFzc2ljLAogb3JnLmhpYmVybmF0ZS5pZCwKIG9yZy5oaWJl cm5hdGUuaWQu
ZW5oYW5jZWQsCiBvcmcuaGliZXJuYXRlLmlkLmluc2VydCwKIG9yZy5oaWJl cm5hdGUuaW1w
bCwKIG9yZy5oaWJlcm5hdGUuaW50ZXJjZXB0LAogb3JnLmhpYmVybmF0ZS5p bnRlcmNlcHQu
Y2dsaWIsCiBvcmcuaGliZXJuYXRlLmludGVyY2VwdC5qYXZhc3Npc3QsCiBv cmcuaGliZXJu
YXRlLmpkYmMsCiBvcmcuaGliZXJuYXRlLmpkYmMudXRpbCwKIG9yZy5oaWJl cm5hdGUuam14
LAogb3JnLmhpYmVybmF0ZS5sb2FkZXIsCiBvcmcuaGliZXJuYXRlLmxvYWRl ci5jb2xsZWN0
aW9uLAogb3JnLmhpYmVybmF0ZS5sb2FkZXIuY3JpdGVyaWEsCiBvcmcuaGli ZXJuYXRlLmxv
YWRlci5jdXN0b20sCiBvcmcuaGliZXJuYXRlLmxvYWRlci5jdXN0b20uc3Fs LAogb3JnLmhp
YmVybmF0ZS5sb2FkZXIuZW50aXR5LAogb3JnLmhpYmVybmF0ZS5sb2FkZXIu aHFsLAogb3Jn
LmhpYmVybmF0ZS5sb2IsCiBvcmcuaGliZXJuYXRlLm1hcHBpbmcsCiBvcmcu aGliZXJuYXRl
Lm1ldGFkYXRhLAogb3JnLmhpYmVybmF0ZS5wYXJhbSwKIG9yZy5oaWJlcm5h dGUucGVyc2lz
dGVyLAogb3JnLmhpYmVybmF0ZS5wZXJzaXN0ZXIuY29sbGVjdGlvbiwKIG9y Zy5oaWJlcm5h
dGUucGVyc2lzdGVyLmVudGl0eSwKIG9yZy5oaWJlcm5hdGUucHJldHR5LAog b3JnLmhpYmVy
bmF0ZS5wcm9wZXJ0eSwKIG9yZy5oaWJlcm5hdGUucHJveHksCiBvcmcuaGli ZXJuYXRlLnBy
b3h5LmRvbTRqLAogb3JnLmhpYmVybmF0ZS5wcm94eS5tYXAsCiBvcmcuaGli ZXJuYXRlLnBy
b3h5LnBvam8sCiBvcmcuaGliZXJuYXRlLnByb3h5LnBvam8uY2dsaWIsCiBv cmcuaGliZXJu
YXRlLnByb3h5LnBvam8uamF2YXNzaXN0LAogb3JnLmhpYmVybmF0ZS5zZWN1 cmUsCiBvcmcu
aGliZXJuYXRlLnNxbCwKIG9yZy5oaWJlcm5hdGUuc3RhdCwKIG9yZy5oaWJl cm5hdGUudG9v
bC5oYm0yZGRsLAogb3JnLmhpYmVybmF0ZS50b29sLmluc3RydW1lbnQsCiBv cmcuaGliZXJu
YXRlLnRvb2wuaW5zdHJ1bWVudC5jZ2xpYiwKIG9yZy5oaWJlcm5hdGUudG9v bC5pbnN0cnVt
ZW50LmphdmFzc2lzdCwKIG9yZy5oaWJlcm5hdGUudHJhbnNhY3Rpb24sCiBv cmcuaGliZXJu
YXRlLnRyYW5zZm9ybSwKIG9yZy5oaWJlcm5hdGUudHVwbGUsCiBvcmcuaGli ZXJuYXRlLnR1
cGxlLmNvbXBvbmVudCwKIG9yZy5oaWJlcm5hdGUudHVwbGUuZW50aXR5LAog b3JnLmhpYmVy
bmF0ZS50eXBlLAogb3JnLmhpYmVybmF0ZS51c2VydHlwZSwKIG9yZy5oaWJl cm5hdGUudXRp
bCwKIG9yZy5oc3FsZGIsCiBvcmcuaHNxbGRiLmluZGV4LAogb3JnLmhzcWxk Yi5qZGJjLAog
b3JnLmhzcWxkYi5saWIsCiBvcmcuaHNxbGRiLmxpYi5qYXZhLAogb3JnLmhz cWxkYi5yZXNv
dXJjZXMsCiBvcmcuaHNxbGRiLnJvd2lvLAogb3JnLmhzcWxkYi5zY3JpcHRp bywKIG9yZy5o
c3FsZGIuc3RvcmUsCiBvcmcuaHNxbGRiLnR5cGVzLAogb3JnLmhzcWxkYi51 dGlsCkJ1bmRs
ZS1SZXF1aXJlZEV4ZWN1dGlvbkVudmlyb25tZW50OiBKMlNFLTEuNQpCdW5k bGUtVmVuZG9y
OiAlUGx1Z2luLnByb3ZpZGVyTmFtZQpCdW5kbGUtQ2xhc3NQYXRoOiBhbnRs ci0yLjcuNi5q
YXIsCiBjM3AwLTAuOS4xLmphciwKIGNvbW1vbnMtY29sbGVjdGlvbnMtMy4x LmphciwKIGRv
bTRqLTEuNi4xLmphciwKIGVoY2FjaGUtMS4yLjMuamFyLAogaGliZXJuYXRl LWFubm90YXRp
b25zLmphciwKIGhpYmVybmF0ZS1jb21tb25zLWFubm90YXRpb25zLmphciwK IGhpYmVybmF0
ZS1lbnRpdHltYW5hZ2VyLmphciwKIGhpYmVybmF0ZTMuamFyLAogaHNxbGRi LmphciwKIGph
dmFzc2lzdC0zLjkuR0EuamFyLAogamF2YXgucGVyc2lzdGVuY2VfMS45OS4w LmphciwKIGp0
YS0xLjEuamFyLAogbXlzcWwtY29ubmVjdG9yLWphdmEtNS4xLjYtYmluLmph ciwKIHNsZjRq
LWFwaS0xLjUuOC5qYXIsCiBzbGY0ai1ub3AtMS41LjguamFyLAogamF2YXNz aXN0LTMuOS4w
LkdBLmphciwKIGxvZzRqLTEuMi44LmphciwKIHNsZjRqLWxvZzRqMTItMS41 LjguamFyCg==
name="build.properties"
filename="build.properties"
YmluLmluY2x1ZGVzID0gTUVUQS1JTkYvLFwKICAgICAgICAgICAgICAgcmVh ZG1lLnR4dCxc
CiAgICAgICAgICAgICAgIGFudGxyLTIuNy42LmphcixcCiAgICAgICAgICAg ICAgIGhpYmVy
bmF0ZS1hbm5vdGF0aW9ucy5qYXIsXAogICAgICAgICAgICAgICBoaWJlcm5h dGUtZW50aXR5
bWFuYWdlci5qYXIsXAogICAgICAgICAgICAgICBjM3AwLTAuOS4xLmphcixc CiAgICAgICAg
ICAgICAgIGVoY2FjaGUtMS4yLjMuamFyLFwKICAgICAgICAgICAgICAgaHNx bGRiLmphcixc
CiAgICAgICAgICAgICAgIGFib3V0Lmh0bWwsXAogICAgICAgICAgICAgICBj b3B5cmlnaHQu
dHh0LFwKICAgICAgICAgICAgICAgZXBsLXYxMC5odG1sLFwKICAgICAgICAg ICAgICAgbGlj
ZW5zZS5odG1sLFwKICAgICAgICAgICAgICAgbW9kZWxpbmczMi5wbmcsXAog ICAgICAgICAg
ICAgICBwbHVnaW4ucHJvcGVydGllcyxcCiAgICAgICAgICAgICAgIG15c3Fs LWNvbm5lY3Rv
ci1qYXZhLTUuMS42LWJpbi5qYXIsXAogICAgICAgICAgICAgICBoaWJlcm5h dGUtY29tbW9u
cy1hbm5vdGF0aW9ucy5qYXIsXAogICAgICAgICAgICAgICBoaWJlcm5hdGUz LmphcixcCiAg
ICAgICAgICAgICAgIGphdmF4LnBlcnNpc3RlbmNlXzEuOTkuMC5qYXIsXAog ICAgICAgICAg
ICAgICBqdGEtMS4xLmphcixcCiAgICAgICAgICAgICAgIHNsZjRqLWFwaS0x LjUuOC5qYXIs
XAogICAgICAgICAgICAgICBzbGY0ai1ub3AtMS41LjguamFyLFwKICAgICAg ICAgICAgICAg
amF2YXNzaXN0LTMuOS4wLkdBLmphcixcCiAgICAgICAgICAgICAgIGNvbW1v bnMtY29sbGVj
dGlvbnMtMy4xLmphcixcCiAgICAgICAgICAgICAgIGRvbTRqLTEuNi4xLmph cixcCiAgICAg
ICAgICAgICAgIGxvZzRqLTEuMi44LmphcixcCiAgICAgICAgICAgICAgIHNs ZjRqLWxvZzRq
MTItMS41LjguamFyCmphcnMuZXh0cmEuY2xhc3NwYXRoID0gYW50bHItMi43 LjYuamFyLFwK
ICAgICAgICAgICAgICAgICAgICAgICBjM3AwLTAuOS4xLmphcixcCiAgICAg ICAgICAgICAg
ICAgICAgICAgY29tbW9ucy1jb2xsZWN0aW9ucy0zLjEuamFyLFwKICAgICAg ICAgICAgICAg
ICAgICAgICBkb200ai0xLjYuMS5qYXIsXAogICAgICAgICAgICAgICAgICAg ICAgIGVoY2Fj
aGUtMS4yLjMuamFyLFwKICAgICAgICAgICAgICAgICAgICAgICBoaWJlcm5h dGUtYW5ub3Rh
dGlvbnMuamFyLFwKICAgICAgICAgICAgICAgICAgICAgICBoaWJlcm5hdGUt Y29tbW9ucy1h
bm5vdGF0aW9ucy5qYXIsXAogICAgICAgICAgICAgICAgICAgICAgIGhpYmVy bmF0ZTMuamFy
LFwKICAgICAgICAgICAgICAgICAgICAgICBoc3FsZGIuamFyLFwKICAgICAg ICAgICAgICAg
ICAgICAgICBqYXZheC5wZXJzaXN0ZW5jZV8xLjk5LjAuamFyLFwKICAgICAg ICAgICAgICAg
ICAgICAgICBqdGEtMS4xLmphcixcCiAgICAgICAgICAgICAgICAgICAgICAg bXlzcWwtY29u
bmVjdG9yLWphdmEtNS4xLjYtYmluLmphcixcCiAgICAgICAgICAgICAgICAg ICAgICAgaGli
ZXJuYXRlLWVudGl0eW1hbmFnZXIuamFyLFwKICAgICAgICAgICAgICAgICAg ICAgICBqYXZh
c3Npc3QtMy45LjAuR0EuamFyLFwKICAgICAgICAgICAgICAgICAgICAgICBz bGY0ai1hcGkt
MS41LjguamFyLFwKICAgICAgICAgICAgICAgICAgICAgICBzbGY0ai1ub3At MS41LjguamFy
CmphdmFjU291cmNlPTEuNQpqYXZhY1RhcmdldD0xLjUK
--------------090802060802050702000206--
Re: GMF & TENEO [message #491151 is a reply to message #491142] |
Tue, 13 October 2009 09:24   |
Hi Rafnixx,
When use a mapping file then Teneo does not generate a mapping in-memory anymore. And in your case you generate a
mapping file for mindmap.ecore but not for notation.ecore (the GMF ecore file), also GMF extends ecore so you also need
to generate a mapping file for the Ecore Package.
You can select multiple ecore when manually creating an ecore file. However, it can be easier to do the following:
create a hbdatastore as described in the tutorial (so without using a mapping file and using the annotations.xml),
initialize it and then call dataStore.getMappingXML() to get the hbm mapping and then store this hbm mapping somewhere
and use that as the mapping file. In this way you get a complete mapping file with all the cases covered.
gr. Marti
> Hello again,
> I want to use a manually generated mapping file. I created the
> hibernate.hbm.xml with right click on mindmap.ecore file. I added
> props.setProperty(PersistenceOptions.USE_MAPPING_FILE,"true "); in the
> StoreController.java, copied the file to
> org.eclipse.gmf.examples.mindmap.rcp.diagram.src and changed the
> build.properties. Whe I try to open an new DB Editor, I got
> org.hibernate.hql.ast.QuerySyntaxException: Diagram is not mapped [from
> Diagram]
> I think the problem is in StoreController.java:
> public static final URI DATABASE_URI =
> URI.createURI("hbxml://?dsname=mindmap&query1=from Map&query2=from
> Diagram");
> What should I change?
The Netherlands
Re: GMF & TENEO [message #492889 is a reply to message #492883] |
Thu, 22 October 2009 04:53   |
Hi Rafnixx,
Sorry I have not yet had time to debug your issue locally. Yes maybe cascade="all" is to strict, also because
view.element is not a containment association. Instead of removing it completely can you try setting it as follows:
cascade="persist, merge, save-update, evict, replicate, lock, refresh"
(so basically except delete).
gr. Martin
> I found the error im my mapping file.
> <subclass name="org.eclipse.gmf.runtime.notation.impl.ViewImpl"
> entity-name="View" abstract="true" lazy="false" extends="EModelElement"
> discriminator-value="View">
> <meta attribute="eclassName">View</meta>
> <meta
> attribute="epackage">http://www.eclipse.org/gmf/runtime/1.0.2/notation</meta>
> <property name="visible" lazy="false" insert="true"
> update="true" not-null="false" unique="false" type="boolean">
> <column not-null="false" unique="false" name="`visible`"/>
> </property>
> <property name="type" lazy="false" insert="true" update="true"
> not-null="false" unique="false" type="java.lang.String">
> <column not-null="false" unique="false" name="`type`"/>
> </property>
> <list name="children" lazy="true" cascade="all,delete-orphan">
> <key update="true" foreign-key="view_children">
> <column name="`view_children_e_id`" not-null="false"
> unique="false"/>
> </key>
> <list-index column="`view_children_idx`"/>
> <one-to-many entity-name="Node"/>
> </list>
> <list name="styles" lazy="true" cascade="all,delete-orphan">
> <key update="true" foreign-key="view_styles">
> <column name="`view_styles_e_id`" not-null="false"
> unique="false"/>
> </key>
> <list-index column="`view_styles_idx`"/>
> <one-to-many entity-name="Style"/>
> </list>
> <any id-type="long" meta-type="string" name="element"
> cascade="all">
> <column not-null="false" unique="false" name="`element_type`"/>
> <column not-null="false" unique="false" name="`element_id`"/>
> </any>
> </subclass>
> The solution was to delete the cascade="all"
The Netherlands
Re: GMF & TENEO [message #507160 is a reply to message #507151] |
Tue, 12 January 2010 05:47  |
It is not one call, you would need to write some more code to get it all working.
Afaics you should write some querying logic to check for updates. I would add an update timestamp to each type. Then
write logic to efficiently check if an object has changed since your last updated time (as the object is in memory you
have it there). As this logic uses the currently loaded objects it is best to put this logic in the hibernateresource.
Then if an object has changed use .refresh to refresh it.
The above is just some generic ideas. I think it is best if you try it out (check the code of the HibernateResource) and
come back with specific questions if you have any.
gr. Martin
> OK, and from where should I call this function in your opinion?
The Netherlands
Current Time: Sat Jul 26 11:02:45 EDT 2025
Powered by FUDForum. Page generated in 0.11794 seconds
