Home » Modeling » Epsilon » Visibility of link when i click group element in the diagram
icon9.gif  Visibility of link when i click group element in the diagram [message #490176] Wed, 07 October 2009 12:24 Go to next message
@gmf.node(figure="ellipse",label = "name")
class group extends Element {
@gmf.link(source.decoration="rhomb",target.decoration="rhomb ")
ref Element[*] members;
Each element can be connected to a group.
Once you create a group, I see links to it colleges only when I click on the group.
I just deselect the group that the links were not more visible.
How do I make this?
thanks
marco
Re: Visibility of link when i click group element in the diagram [message #490189 is a reply to message #490176] Wed, 07 October 2009 13:46 Go to previous messageGo to next message
Hi Marco,
This sounds strange. Could you please provide a minimal complete .emf
that demonstrates this?
Dimitris
> the group.
> How do I make this?
> thanks
> marco
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Visibility of link when i click group element in the diagram [message #490452 is a reply to message #490189] Thu, 08 October 2009 13:09 Go to previous messageGo to next message
@namespace(uri="http://dually/a0", prefix="A0")
@gmf(foo="bar")
package A0;
enum LinkNavigability {
bidirectional = 0;
unidirectional = 1;
@gmf.link(source="from",target="to")
abstract class Link extends Element{
attr LinkNavigability navigability;
ref InteractionPoint[1] from;
ref InteractionPoint[1] to;
ref Component fromContext;
ref Component toContext;
@gmf.node(figure="rectangle",label="name")
abstract class Component extends Element{
@gmf.compartment(foo="bar")
val InteractionPoint[*] points;
@gmf.node(figure="rectangle", size="20,20", label="name",
label.placement="external", label.icon="false")
class InteractionPoint extends Element{
class SAcomponent extends Component {
@gmf.node(figure="rounded",label="name")
class SAconnector extends Component {
@gmf.compartment(foo="bar", collapsible="false")
val SAcomponent subSAcomponent;
@gmf.link(target.decoration="rhomb",source.decoration="rhomb ")
class SABinding extends Link {
@gmf.link(target.decoration="arrow")
class SAChannel extends Link {
@gmf.link(target.decoration="rhomb")
class Element {
attr String name;
attr String description;
@gmf.diagram (foo="bar")
class A0Spec extends Element {
val Element[*] elements;
I created a metamodel easier but with the same features as mine.
regards marco
Re: Visibility of link when i click group element in the diagram [message #490524 is a reply to message #490452] Thu, 08 October 2009 19:11 Go to previous messageGo to next message
Hi Marco,
I can't reproduce this. I can create a Group and
SAComponents/SAConnectors, draw Members links between them and the links
are visible regardless of whether the Group is selected or not...
BTW, I had to remove an extra space from
to make this work.
Dimitris
> @gmf(foo="bar")
> package A0;
> bidirectional = 0;
> unidirectional = 1;
> class Element {
> attr String name;
> regards marco
Re: Visibility of link when i click group element in the diagram [message #490728 is a reply to message #490524] Fri, 09 October 2009 17:12 Go to previous messageGo to next message
I'm sorry you saw after that was the extra space in that row.
I did not understand if you tell me that you can not realize what it takes me.
you can do what I need?
Click on a group and display the links with him and just make the issue disappear links.
I hope there's a way to solve this problem.
thanks
marco
Re: Visibility of link when i click group element in the diagram [message #490743 is a reply to message #490728] Fri, 09 October 2009 21:14 Go to previous message
Hi Marco,
Could you possibly prepare a screencast (e.g. using www.srceenr.com)
that illustrates the problem? I'm still not convinced that we're talking
about the same problem so this might help...
Dimitris
> takes me.
> disappear links.
> thanks
> marco
Re: Visibility of link when i click group element in the diagram [message #581598 is a reply to message #490176] Wed, 07 October 2009 13:46 Go to previous message
Hi Marco,
Dimitris
> the group.
> How do I make this?
> thanks
> marco
Re: Visibility of link when i click group element in the diagram [message #581761 is a reply to message #490189] Thu, 08 October 2009 13:09 Go to previous message
@gmf(foo="bar")
package A0;
bidirectional = 0;
unidirectional = 1;
class Element {
attr String name;
regards marco
Re: Visibility of link when i click group element in the diagram [message #581776 is a reply to message #581761] Thu, 08 October 2009 19:11 Go to previous message
Hi Marco,
to make this work.
Dimitris
> @gmf(foo="bar")
> package A0;
> bidirectional = 0;
> unidirectional = 1;
> class Element {
> attr String name;
> regards marco
Re: Visibility of link when i click group element in the diagram [message #581804 is a reply to message #490524] Fri, 09 October 2009 17:12 Go to previous message
thanks
marco
Re: Visibility of link when i click group element in the diagram [message #581848 is a reply to message #490728] Fri, 09 October 2009 21:14 Go to previous message
Hi Marco,
Dimitris
> takes me.
> disappear links.
> thanks
> marco
Previous Topic:Null Pointer Exception when invoking .asOrderedSet in EOL query
Next Topic: Link property with 4 field...i don't set all [URGENT]
Current Time: Sat Jul 26 19:22:15 EDT 2025
Powered by FUDForum. Page generated in 0.06396 seconds
