Home » Modeling » Epsilon » Recursive operation - use of Sequence.add()
Recursive operation - use of Sequence.add() [message #489990] |
Tue, 06 October 2009 14:41  |
Originally posted by: c.k.holmes.lboro.ac.uk
Hello All,
I'm not sure if this is a bug or just my own stupidity. I have the
following recursive operation (interspersed with print statements):
operation BusAttributes navigateToRoot() : Sequence(Signal) {
var next : BusAttributes;
var sig : Signal := self.ownedBy;
'-----'.println();
sig.asString().println();
'-----'.println();
if(self.isRoot()) {
('stop on ' + sig.asString()).println();
return Sequence{sig};
} else {
var result : Sequence(Signal) := Sequence{};
next := self.getWhole().getBusAttributes();
('again on ' + next.asString()).println();
'-----'.println();
result := next.navigateToRoot();
('result = ' + result).println();
('sig = ' + sig.asString()).println();
return result.add(sig);
The operation recursively navigates an object hierarchy from leaf to
root, building up a sequence of the leaves visited that are (should then
be) returned. The following is a sanitised execution trace taken from
the console window:
Signal: <SigA>
again on BusAttributesType2: <BusAttB>
Signal: <SigB>
again on BusAttributesType1: <BusAttC>
Signal: <SigC>
again on BusAttributesType2: <BusAttD>
Signal: <SigD>
again on BusAttributesType1: <BusAttE>
Signal: <SigE>
again on BusAttributesType1: <BusAttF>
Signal: <SigF>
again on BusAttributesType1: <BusAttG>
Signal: <SigG>
stop on Signal: <SigG>
result = Sequence {Signal [name=<SigG>]}
sig = Signal: <SigF>
result =
sig = Signal: <SigE>
Method 'add' not found
(C:\EclipseWorkspaces\InterfaceControlDocument\InterfaceCont rolDocument\Operations\BusAttributes.eol@34:18)
It can be seen that <SigF> has not been added to result, and indeed
result now appears to be null rather than the Sequence expected, hence
the error reported by the system in trying to apply the add operation.
If the code of the operation is modified slightly such that we do this
within the 'else' branch:
'-----'.println();
result.add(sig);
return result;
i.e. we replace the line:
with:
result.add(sig);
return result;
then the operation runs successfully:
result = Sequence {Signal [name=<SigG>], Signal [name=<SigF>]}
result = Sequence {Signal [name=<SigG>], Signal [name=<SigF>], Signal
[name=<SigE>]}
etc.
Placing brackets around (result.add(sig)) has no effect. Is this a bug,
or am I doing something wrong?
Best Wishes
Chris
Re: Recursive operation - use of Sequence.add() [message #489991 is a reply to message #489990] |
Tue, 06 October 2009 14:49   |
Hi Chris,
This happens because the add() method is void, so
adds sig to result and then returns the returned value of add() which is
null.
Dimitris
Chris Holmes wrote:
> Hello All,
> '-----'.println();
> '-----'.println();
> if(self.isRoot()) {
> } else {
> '-----'.println();
> the console window:
> Signal: <SigA>
> Signal: <SigB>
> Signal: <SigC>
> Signal: <SigD>
> Signal: <SigE>
> Signal: <SigF>
> Signal: <SigG>
> result =
> '-----'.println();
> result.add(sig);
> return result;
> with:
> result.add(sig);
> return result;
> [name=<SigE>]}
> etc.
> Best Wishes
> Chris
Spread the word: http://www.eclipse.org/gmt/epsilon/spreadtheword
Follow Epsilon on Twitter: http://twitter.com/epsilonews
Re: Recursive operation - use of Sequence.add() [message #490072 is a reply to message #489991] |
Wed, 07 October 2009 03:55  |
Hi Dimitris,
OK, thanks ... I should have used 'including' doh!:
if(self.isRoot()) {
} else {
return next.navigateToRoot().including(sig);
Best Wishes
Chris
Dimitris Kolovos wrote:
> Hi Chris,
> null.
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hello All,
>> '-----'.println();
>> '-----'.println();
>> if(self.isRoot()) {
>> } else {
>> '-----'.println();
>> then be) returned. The following is a sanitised execution trace taken
>> from the console window:
>> Signal: <SigA>
>> Signal: <SigB>
>> Signal: <SigC>
>> Signal: <SigD>
>> Signal: <SigE>
>> Signal: <SigF>
>> Signal: <SigG>
>> result =
>> '-----'.println();
>> result.add(sig);
>> return result;
>> with:
>> result.add(sig);
>> return result;
>> [name=<SigE>]}
>> etc.
>> bug, or am I doing something wrong?
>> Best Wishes
>> Chris
Re: Recursive operation - use of Sequence.add() [message #581478 is a reply to message #489990] |
Hi Chris,
null.
Dimitris
Chris Holmes wrote:
> Hello All,
> '-----'.println();
> '-----'.println();
> if(self.isRoot()) {
> } else {
> '-----'.println();
> the console window:
> Signal: <SigA>
> Signal: <SigB>
> Signal: <SigC>
> Signal: <SigD>
> Signal: <SigE>
> Signal: <SigF>
> Signal: <SigG>
> result =
> '-----'.println();
> result.add(sig);
> return result;
> with:
> result.add(sig);
> return result;
> [name=<SigE>]}
> etc.
> Best Wishes
> Chris
Re: Recursive operation - use of Sequence.add() [message #581520 is a reply to message #489991] |
Hi Dimitris,
if(self.isRoot()) {
} else {
Best Wishes
Chris
> Hi Chris,
> null.
> Cheers,
> Dimitris
> Chris Holmes wrote:
>> Hello All,
>> '-----'.println();
>> '-----'.println();
>> if(self.isRoot()) {
>> } else {
>> '-----'.println();
>> Signal: <SigA>
>> Signal: <SigB>
>> Signal: <SigC>
>> Signal: <SigD>
>> Signal: <SigE>
>> Signal: <SigF>
>> Signal: <SigG>
>> result =
>> '-----'.println();
>> result.add(sig);
>> return result;
>> with:
>> result.add(sig);
>> return result;
>> [name=<SigE>]}
>> etc.
>> Best Wishes
>> Chris
Current Time: Wed Jul 23 12:37:53 EDT 2025
Powered by FUDForum. Page generated in 0.38699 seconds
