Create an "Application Desktop Toolbar" with RCP? [message #489797] |
Mon, 05 October 2009 21:05  |
I'm trying to write an application which will be anchored to the bottom of the Windows desktop ... basically behave like the Windows taskbar. The appplication window must be anchored to the bottom of the window (above the taskbar) and effectively reduce the size of Windows desktop that's available for other applications. When a user maximizes a different application window it should not end up behind or on top of my application window but up next to it.
Here's the MSFT Definition:
An application desktop toolbar(also called an appbar) is a window that is similar to the Microsoft Windows taskbar. It is anchored to an edge of the screen, and it typically contains buttons that give the user quick access to other applications and windows. The system prevents other applications from using the desktop area occupied by an appbar.
Anyone know if something like this is possible with RCP?
Steve
FUDForum. Page generated in 0.03861 seconds
