Home » Archived » M2M (model-to-model transformation) » [QVTO] Object access results in DynamicEObjectImpl (EClass: Invalid_Class)
[QVTO] Object access results in DynamicEObjectImpl (EClass: Invalid_Class) [message #489655] |
Mon, 05 October 2009 09:37  |
Hi newsgroup,
I realized a strange behavior which I don't understand, maybe you guys can help me.
My transformation takes a model (instance of EMF Compare's emfdiff) as input but apparently some elements are not treated correctly:
mapping EmfDiff::DiffModel::toOtherDiffModel() : EmfDiff::DiffModel {
init {
var diffElements := self.ownedElements.allInstances(DiffElement).oclAsType(DiffE lement)
-- ->reject(oclIsTypeOf(UpdateReference)) ->reject(oclIsTypeOf(UpdateAttribute))
-- The line above removes the exception!
result.ownedElements := diffElements->map toOtherChange()->asOrderedSet();
mapping DiffElement::toOtherChange() : DiffElement {
init {
log(self.oclAsType(EObject).eClass().name + ' -> ' + self.repr());
if self.oclIsInvalid() or self.oclIsUndefined() or self.oclAsType(EObject).eClass().name.=('Invalid_Class') then
log('unreachable!')
endif;
result := object DiffGroup {}; -- here seems to be the QvtRuntimeException
-- some logging output to keep track of the transformed elements
log('> ' + self.metaClassName() + ' -> ' + result.metaClassName(), self)
The log output is the following:
ReferenceOrderChange -> The order of the values of reference eStructuralFeatures have been changed
> ReferenceOrderChange -> DiffGroup, data: The order of the values of reference eStructuralFeatures have been changed
DiffGroup -> 2 change(s) in EObject EObject
> DiffGroup -> DiffGroup, data: 2 change(s) in EObject EObject
UpdateAttribute -> org.eclipse.emf.ecore.impl.DynamicEObjectImpl@bc5681 (eClass: org.eclipse.emf.ecore.impl.EClassImpl@d35eb7 (name: Invalid_Class) (instanceClassName: null) (abstract: false, interface: false))
org.eclipse.m2m.internal.qvt.oml.evaluator.QvtRuntimeExcepti on: The feature 'null' is not a valid feature
at emfdiff2indepdiff::DiffElement::toOtherChange(ref_test.qvto: 29)
at emfdiff2indepdiff::DiffModel::toOtherDiffModel(ref_test.qvto : <Unknown>)
at emfdiff2indepdiff::main(ref_test.qvto:<Unknown>)
Which means, if I understood it correctly, that several model elements are processed correctly (ReferenceOrderChange, DiffGroup), others are not (UpdateAttribute).
At least the objects seems to be correct ("self.oclAsType(EObject).eClass().name" evaluates to "UpdateAttribute"), but for some reason it is not treated correctly but as a DynamicEObject which, I think I read in some other newsgroup posting, should represent OclVoid in this case.
Then, for some reason, a QvtRuntimeException occurs!
Any idea what went wrong here?
(my system: Eclipse 3.5, EMF 2.5.0, QVTo 2.0.1)
I put the transformation and the test model in a zip:
http://imm.dtu.dk/~pk/temp/qvto-dynamiceobject.zip
(Import -> Existing projects into workspace -> Run... -> QVTo -> ref_test)
Any help is appreciated!
Cheers
Patrick
Re: [QVTO] Object access results in DynamicEObjectImpl (EClass: Invalid_Class) [message #489828 is a reply to message #489655] |
Tue, 06 October 2009 03:36   |
Originally posted by: dvorak.radek.gmail.com
Hi Patrick,
The problem is in the Java generated 'diff' metamodel, more
precisely in the method
org.eclipse.emf.compare.diff.metamodel.impl.UpdateAttributeI mpl.toString().
In such cases it's always good to check the 'Error Log View',
where you can find:
java.lang.IllegalArgumentException: The feature 'null' is not a valid
feature
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eOpenGet(BasicEO bjectImpl.java:1064)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1017)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1005)
at
org.eclipse.emf.ecore.impl.BasicEObjectImpl.eGet(BasicEObjec tImpl.java:1000)
at
org.eclipse.emf.compare.diff.metamodel.impl.UpdateAttributeI mpl.toString(UpdateAttributeImpl.java:61)
at java.lang.String.valueOf(String.java:2826)
at
org.eclipse.m2m.internal.qvt.oml.stdlib.OclAnyOperations$1.i nvoke(OclAnyOperations.java:60)
at
org.eclipse.m2m.internal.qvt.oml.ast.env.QvtOperationalEvalu ationEnv.callOperation(QvtOperationalEvaluationEnv.java:155)
What QVTO should do better is to return Invalid from Object::repr()
operation and
log an exception thrown, as this StdLib operation delegates to a
traditionally
user overridden operation.
/Radek
On Mon, 05 Oct 2009 15:37:33 +0200, Patrick Könemann <pk@imm.dtu.dk> wrote:
> Hi newsgroup,
> can help me.
> init {
> var diffElements :=
> init {
> log('unreachable!')
> endif;
> QvtRuntimeException
> self)
> false))
> at
> ref_test)
> Cheers
> Patrick
Re: [QVTO] Object access results in DynamicEObjectImpl (EClass: Invalid_Class) [message #489861 is a reply to message #489828] |
Tue, 06 October 2009 05:52   |
Hi Radek,
this is very interesting, thank you for pointing that out!
The transformation actually works if I remove all "EObject::repr()" and "EObject::metaClassName()" calls.
However.. That means that I cannot write this useful information into the log anymore.
I see two solutions:
1. Fixing the IllegalArgumentException in the model java code (but for some strange reason I cannot reproduce the exception outsite the transformation..)
2. Catching this error in the transformation - is that possible? I read something about try-catch in the Eclipsecon 2008 slides, p. 32.
Thanks again!
Patrick
On 06-10-2009 09:36, radek dvorak wrote:
> Hi Patrick,
> where you can find:
> feature
> at
> at
> at
> at
> at
> at
> at
> operation and
> traditionally
> Regards,
> /Radek
>> Hi newsgroup,
>> can help me.
>> init {
>> var diffElements :=
>> init {
>> log('unreachable!')
>> endif;
>> QvtRuntimeException
>> UpdateAttribute ->
>> at
>> ref_test)
>> Cheers
>> Patrick
Re: [QVTO] Object access results in DynamicEObjectImpl (EClass: Invalid_Class) [message #489870 is a reply to message #489861] |
Tue, 06 October 2009 06:53   |
Hi Patrick,
1. Whatever better handling of such situations by QVTO does not solve the
problem.
Object::toString() throwing a runtime exception is just bad.
Use debugger, set a breakpoint to
and launch another eclipse instance to execute your transf, you will
see the
the details.
2. No try-catch at the moment. It would not help either, as you have
no QVT typed exception to catch here.
What QVTO can do is to return Invalid and log the exception caught, hoping
someone
will notice that. This would be more fault tolerant and can be delivered
in a maintenance build,
which you can install. It will come later, potentially with other fixes as
Galileo SR2.
Raise bugzilla, if you want to to get it ;)
You can write a useful info to the log but with a useful Java code ;).
Try using your custom toString operation and redirect for AttributeChange
instances
to something safe.
helper DiffElement::myRepr() : String {
return self.repr();
helper AttributeChange::myRepr() : String {
return "my safe details";
Also, use
emfdiff.objects()[DiffModel]
instead of
// allInstances() is non-std and legacy addition to Stdlib
emfdiff.rootObjects().allInstances(DiffModel).oclAsType(Diff Model)
Avoid
better check using OclAny::oclIsInvalid()
I can see your models produce validation problems, also a good thing to
check.
/Radek
On Tue, 06 Oct 2009 11:52:37 +0200, Patrick Könemann <pk@imm.dtu.dk> wrote:
> Hi Radek,
> the log anymore.
> transformation..)
> Thanks again!
> Patrick
>> Hi Patrick,
>> where you can find:
>> feature
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> operation and
>> traditionally
>> Regards,
>> /Radek
>> wrote:
>>> Hi newsgroup,
>>> can help me.
>>> init {
>>> var diffElements :=
>>> init {
>>> log('unreachable!')
>>> endif;
>>> QvtRuntimeException
>>> self)
>>> UpdateAttribute ->
>>> at
>>> ref_test)
>>> Cheers
>>> Patrick
Re: [QVTO] Object access results in DynamicEObjectImpl (EClass: Invalid_Class) [message #489888 is a reply to message #489870] |
Tue, 06 October 2009 08:33   |
Hi Radek,
Please see comments inline.
Best regards
Patrick
On 06-10-2009 12:53, radek dvorak wrote:
> Hi Patrick,
> 1. Whatever better handling of such situations by QVTO does not solve the problem.
> and launch another eclipse instance to execute your transf, you will see the
> the details.
That works, thanks!
> What QVTO can do is to return Invalid and log the exception caught, hoping someone
> will notice that. This would be more fault tolerant and can be delivered in a maintenance build,
> which you can install. It will come later, potentially with other fixes as Galileo SR2.
I guess it's not that urgent..
> Try using your custom toString operation and redirect for AttributeChange instances
> to something safe.
> return self.repr();
That is helpful! Thanks a lot!
> Also, use
> instead of
The point is that "DiffModels" might not be direct children of the emfdiff object:
emfdiff
+ diffResourceSet
+ diffModel1
+ diffModel2
As far as I see it, "emfdiff.objects()[DiffModel]" only returns direct children of the specified type?
> Avoid
Sure, that was just for debugging.. ;-)
> check.
My fault.. I renamed the project which made some EMF references invalid.
Fixing that didn't change anything in the result though.
> Regards,
> /Radek
>> Hi Radek,
>> the log anymore.
>> transformation..)
>> Thanks again!
>> Patrick
>>> Hi Patrick,
>>> where you can find:
>>> feature
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> at
>>> operation and
>>> traditionally
>>> Regards,
>>> /Radek
>>> wrote:
>>>> Hi newsgroup,
>>>> can help me.
>>>> init {
>>>> var diffElements :=
>>>> init {
>>>> log('unreachable!')
>>>> endif;
>>>> QvtRuntimeException
>>>> self)
>>>> UpdateAttribute ->
>>>> at
>>>> ref_test)
>>>> Cheers
>>>> Patrick
Re: [QVTO] Object access results in DynamicEObjectImpl (EClass: Invalid_Class) [message #489900 is a reply to message #489888] |
Tue, 06 October 2009 08:53   |
> emfdiff object:
> emfdiff
> + diffResourceSet
> + diffModel1
> + diffModel2
'emfdiff' is your input model, objects() will return all instances of that
type
in the whole model.
8.3.5.1 objects
Model::objects() : Set(Element)
Returns the list of the objects in the model extent.
When thinking about querying children of an object,
see Element::subobjects() : Set(Element), Element::allSubobjects() :
Set(Element), etc.
>> Avoid
>> check.
>> Regards,
>> /Radek
>> wrote:
>>> Hi Radek,
>>> the log anymore.
>>> transformation..)
>>> Thanks again!
>>> Patrick
>>>> Hi Patrick,
>>>> where you can find:
>>>> feature
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> operation and
>>>> traditionally
>>>> Regards,
>>>> /Radek
>>>> wrote:
>>>>> Hi newsgroup,
>>>>> guys
>>>>> can help me.
>>>>> as
>>>>> init {
>>>>> var diffElements :=
>>>>> init {
>>>>> log('unreachable!')
>>>>> endif;
>>>>> QvtRuntimeException
>>>>> self)
>>>>> UpdateAttribute ->
>>>>> at
>>>>> elements
>>>>> ref_test)
>>>>> Cheers
>>>>> Patrick
Re: [QVTO] Object access results in DynamicEObjectImpl (EClass: Invalid_Class) [message #489915 is a reply to message #489900] |
Tue, 06 October 2009 09:31  |
> 8.3.5.1 objects
> Set(Element), etc.
Great! :-)
The problem was that I tried to use objects() also on model elements (not only the model itself)..
But allSubobjects() is exactly what I needed!
Actually I found even other interesting methods in the ocl spec :-)
Thanks again!
Patrick
Current Time: Sat Aug 30 12:38:38 EDT 2025
Powered by FUDForum. Page generated in 0.08534 seconds
