| cannot generate model code [message #48623] |
Fri, 15 September 2006 05:45  |
Hello everybody,
I follow the GMF tutorial but using my own model (test.mdl) instead. Problem
occurs while I right click the test.genmodel and do generate model code,
nothing happens (also no error message). It should be generate code within 3
packages (test, test.impl, test.util) right? After then, I continue to
generate edit and got an error. The error shows in below. Does anybody know
what happen? Thanks a lot.
Generate Ed&it Code
Generating edit project
Generating Java class test.test.provider.FlowDeleteCommandItemProvider
failed with an unhandled exception
InvocationTargetException
NullPointerException
Generating Java class test.test.provider.FlowCreateCommandItemProvider
Generating Java class test.test.provider.FlowReCreateCommandItemProvider
Generating Java class test.test.provider.ShapeCreateCommandItemProvider
Generating Java class test.test.provider.ShapeDeleteCommandItemProvider
Generating Java class test.test.provider.DiagramEditPartItemProvider
Meilin
| Re: cannot generate model code [message #50168 is a reply to message #50109] |
Mon, 18 September 2006 14:20   |
--------------050901060808020509080805
Meilin,
When code generation fails to generate, there typically is some
information about this in the error log. Have you looked at the error log?
In the Ecore editor, you can right click on any object and ask to
validate it but there are still many constraints not being checked,
i.e., https://bugs.eclipse.org/bugs/show_bug.cgi?id=75933 isn't done
yet. A common cause for failure is an EPackage without an nsURI or
name, or an EStructuralFeature without an eType.
exquisitus wrote:
> Hi Christian,
> Thanks for you help.
> I would like to see the warnings but it doesn't show any warning or error
> after by clicking gnerate model code.
> I also like to validate my ecore model but I can't find where the validation
> tool.
> If you don't mind, please describe more detail about validation step.
> Thank you!
> Meilin
> "Christian Barth" <dont@spam.net> ???????:eegms0$hcg$1@utils.eclipse.org...
>> Hi Meilin,
>> did you check your error log after (try to) generating the code? I guess
>> there will be some Warnings (containing a Null Pointer Exception :) ).
>> Is your model valid? You can start the validation by opening your ecore
>> model and then select "Sample Ecore Editor"->Validate in the menu.
>> I had a NPE as well. The validation tool told me that I have forgot to set
>> some values in a Reference Element. After fixing the problem I was able to
>> generate the other models and the code without any error.
>> Cheers
>> Christian
Content-Type: text/html; charset=ISO-8859-1
<html>
<head>
<title></title>
</head>
Meilin,<br>
<br>
log?<br>
<br>
i.e., <a href="https://bugs.eclipse.org/bugs/show_bug.cgi?id=75933">https://bugs.eclipse.org/bugs/show_bug.cgi?id=75933</a>
isn't done yet. A common cause for failure is an EPackage without an
nsURI or name, or an EStructuralFeature without an eType.<br>
<br>
<br>
exquisitus wrote:
<blockquote cite="mideemnfm$42d$1@utils.eclipse.org" type="cite">
<pre wrap="">Hi Christian,
tool.
Thank you!
Meilin
"Christian Barth" <a class="moz-txt-link-rfc2396E" href="mailto:dont@spam.net"><dont@spam.net></a> ???????:eegms0$hcg$1@utils.eclipse.org...
</pre>
<blockquote type="cite">
<pre wrap="">Hi Meilin,
Cheers
Christian
</pre>
</blockquote>
<pre wrap=""><!---->
</pre>
</blockquote>
<br>
</body>
</html>
--------------050901060808020509080805--
| Re: cannot generate model code [message #50345 is a reply to message #50168] |
Mon, 18 September 2006 16:02  |
I found why I can't validate my ecore because the validation feature is
enable in single object
and can't be run on the top of ecore when opening the ecore editor.
Now, I know the problem was due to one of object missing eReference.
Thank you Ed Merks !
"Ed Merks" <merks@ca.ibm.com> ???????:eemo0o$7p2$1@utils.eclipse.org...
Meilin,
When code generation fails to generate, there typically is some information
In the Ecore editor, you can right click on any object and ask to validate
it but there are still many constraints not being checked, i.e.,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=75933 isn't done yet. A
common cause for failure is an EPackage without an nsURI or name, or an
exquisitus wrote:
Hi Christian,
tool.
Thank you!
Meilin
Hi Meilin,
Cheers
Christian
FUDForum. Page generated in 0.03474 seconds
