Home » Eclipse Projects » Standard Widget Toolkit (SWT) » Text and Highlighter
Text and Highlighter [message #489249] Fri, 02 October 2009 02:08 Go to next message
I have a SWT Text and if the textfield is empty i want a text hint e.g. "Enter firstname". When the textfield get the focus or the user enter a text. the hint should be disable.
How could I do this?
thx
Re: Text and Highlighter [message #489403 is a reply to message #489249] Fri, 02 October 2009 16:15 Go to previous messageGo to next message
Are you saying the hint text would appear within the text field but with a
different appearance? If so, Text does not provide a way to just set a text
hint and have it automatically managed, but implementing this in your app
should not be difficult. Set the Text's hint text with a different
foreground colour and font, and remove it when the Text receives a FocusIn
(and possibly put it back if the Text is empty when it receives a FocusOut).
If this is not what you were asking then please follow up here with a little
more description.
Grant
"SirWayne" <dennis.m@web.de> wrote in message
news:ha45ck$61p$1@build.eclipse.org...
> Hello,
> thx
Re: Text and Highlighter [message #489452 is a reply to message #489403] Sat, 03 October 2009 04:36 Go to previous messageGo to next message
I know this solution, but in my opinion i find this soultion bad, because if you call getText() you get the hint text and thats wrong(textfield is empty) and make problems.
Look at the attachment this is a FilteredTree with Highlighter.
Re: Text and Highlighter [message #489665 is a reply to message #489452] Mon, 05 October 2009 10:03 Go to previous messageGo to next message
The attachment doesn't seem to have made it.
I know the solution that was provided is a bit hacky, but if there isn't
pre-canned or native support available for something then a solution like
this is sometimes the only choice. The getText() case would be handled by
having a property like "isActuallyEmpty" on the Text, which would be updated
to True/False by the listeners as needed. Regarding FilteredTree, since swt
Trees don't provide pre-canned support for this either, the FilteredTree
implementation is probably doing something similar to the Text suggestion.
Grant
news:ha72eh$52c$1@build.eclipse.org...
Re: Text and Highlighter [message #489770 is a reply to message #489665] Mon, 05 October 2009 16:29 Go to previous messageGo to next message
package test;
import org.eclipse.jface.viewers.TreeViewer;
import org.eclipse.swt.SWT;
import org.eclipse.swt.events.DisposeEvent;
import org.eclipse.swt.events.DisposeListener;
import org.eclipse.swt.events.FocusAdapter;
import org.eclipse.swt.events.FocusEvent;
import org.eclipse.swt.events.ModifyEvent;
import org.eclipse.swt.events.ModifyListener;
import org.eclipse.swt.events.MouseAdapter;
import org.eclipse.swt.events.MouseEvent;
import org.eclipse.swt.events.MouseMoveListener;
import org.eclipse.swt.events.MouseTrackListener;
import org.eclipse.swt.events.SelectionAdapter;
import org.eclipse.swt.events.SelectionEvent;
import org.eclipse.swt.graphics.Color;
import org.eclipse.swt.graphics.Image;
import org.eclipse.swt.graphics.Point;
import org.eclipse.swt.layout.GridData;
import org.eclipse.swt.layout.GridLayout;
import org.eclipse.swt.widgets.Composite;
import org.eclipse.swt.widgets.Control;
import org.eclipse.swt.widgets.Label;
import org.eclipse.swt.widgets.Text;
public class MyText extends Composite {
     * The filter text widget to be used by this tree. This value may be
     * <code>null</code> if there is no filter widget, or if the controls have
     * not yet been created.
    protected Text filterText;
     * The control representing the clear button for the filter text entry. This
     * value may be <code>null</code> if no such button exists, or if the
     * controls have not yet been created.
     * @since 3.5
    protected Control clearButtonControl;
     * The Composite on which the filter controls are created. This is used to
     * set the background color of the filter controls to match the surrounding
     * controls.
    protected Composite filterComposite;
     * The text to initially show in the filter text control.
    protected String initialText = ""; //$NON-NLS-1$
     * The parent composite of the filtered tree.
     * @since 3.3
    protected Composite parent;
     * Image descriptor for enabled clear button.
    private static final String CLEAR_ICON = "icons/clear.gif"; //$NON-NLS-1$
     * Image descriptor for disabled clear button.
    private static final String DISABLED_CLEAR_ICON = "icons/clear_co.gif"; //$NON-NLS-1$
     * Create a new instance of the receiver.
     * @param parent
     *            the parent <code>Composite</code>
     * @param treeStyle
     *            the style bits for the <code>Tree</code>
     * @param filter
     *            the filter to be used
     * @param useNewLook
     *            <code>true</code> if the new 3.5 look should be used
     * @since 3.5
    public MyText(Composite parent, int style) {
        super(parent, style);
        this.parent = parent;
        init();
     * Create the filtered tree.
     * @param treeStyle
     * @param filter
     * @since 3.3
    protected void init() {
        createControl(parent);
        setInitialText("InitialText");
        setFont(parent.getFont());
     * Create the filtered tree's controls. Subclasses should override.
     * @param parent
     * @param treeStyle
    protected void createControl(Composite parent) {
        GridLayout layout = new GridLayout();
        layout.marginHeight = 0;
        layout.marginWidth = 0;
        setLayout(layout);
        setLayoutData(new GridData(SWT.FILL, SWT.FILL, true, true));
        filterComposite = new Composite(this, SWT.BORDER);
        filterComposite.setBackground(getDisplay().getSystemColor(
                SWT.COLOR_LIST_BACKGROUND));
        GridLayout filterLayout = new GridLayout(2, false);
        filterLayout.marginHeight = 0;
        filterLayout.marginWidth = 0;
        filterComposite.setLayout(filterLayout);
        filterComposite.setFont(parent.getFont());
        createFilterControls(filterComposite);
        filterComposite.setLayoutData(new GridData(SWT.FILL, SWT.BEGINNING,
                true, false));
     * Create the filter controls. By default, a text and corresponding tool bar
     * button that clears the contents of the text is created. Subclasses may
     * override.
     * @param parent
     *            parent <code>Composite</code> of the filter controls
     * @return the <code>Composite</code> that contains the filter controls
    protected Composite createFilterControls(Composite parent) {
        createFilterText(parent);
        createClearTextNew(parent);
        if (clearButtonControl != null) {
            // initially there is no text to clear
            clearButtonControl.setVisible(false);
        return parent;
    protected void updateToolbar(boolean visible) {
            clearButtonControl.setVisible(visible);
     * Creates the filter text and adds listeners. This method calls
     * {@link #doCreateFilterText(Composite)} to create the text control.
     * Subclasses should override {@link #doCreateFilterText(Composite)} instead
     * of overriding this method.
     * @param parent
     *            <code>Composite</code> of the filter text
    protected void createFilterText(Composite parent) {
        filterText = doCreateFilterText(parent);
        filterText.addModifyListener(new ModifyListener() {
            public void modifyText(ModifyEvent e) {
                if (filterText.getText().length() > 0) {
                    updateToolbar(true);
                } else {
                    updateToolbar(false);
        filterText.addFocusListener(new FocusAdapter() {
             * (non-Javadoc)
             * @see
             *  org.eclipse.swt.events.FocusListener#focusLost(org.eclipse.s wt
             * .events.FocusEvent)
            public void focusGained(FocusEvent e) {
             * (non-Javadoc)
             * @see
             *  org.eclipse.swt.events.FocusAdapter#focusLost(org.eclipse.sw t
            public void focusLost(FocusEvent e) {
                if (filterText.getText().equals(initialText)) {
                    setFilterText(""); //$NON-NLS-1$
        filterText.addMouseListener(new MouseAdapter() {
             * (non-Javadoc)
             * @see
             *  org.eclipse.swt.events.MouseAdapter#mouseDown(org.eclipse.sw t
             * .events.MouseEvent)
            public void mouseDown(MouseEvent e) {
                    // XXX: We cannot call clearText() due to
                    // [url]https://bugs.eclipse.org/bugs/show_bug.cgi?id=260664[/url]
        // if we're using a field with built in cancel we need to listen for
        // default selection changes (which tell us the cancel button has been
        // pressed)
        if ((filterText.getStyle() & SWT.ICON_CANCEL) != 0) {
            filterText.addSelectionListener(new SelectionAdapter() {
                 * (non-Javadoc)
                 * @see
                 *  org.eclipse.swt.events.SelectionAdapter#widgetDefaultSelecte d
                 * (org.eclipse.swt.events.SelectionEvent)
                public void widgetDefaultSelected(SelectionEvent e) {
                    if (e.detail == SWT.ICON_CANCEL)
                        clearText();
        GridData gridData = new GridData(SWT.FILL, SWT.CENTER, true, false);
        // if the text widget supported cancel then it will have it's own
        // integrated button. We can take all of the space.
            gridData.horizontalSpan = 2;
        filterText.setLayoutData(gridData);
     * Creates the text control for entering the filter text. Subclasses may
     * override.
     * @param parent
     *            the parent composite
     * @return the text widget
     * @since 3.3
    protected Text doCreateFilterText(Composite parent) {
        return new Text(parent, SWT.SINGLE | SWT.ICON_CANCEL);
     * Set the background for the widgets that support the filter text area.
     * @param background
     *            background <code>Color</code> to set
    public void setBackground(Color background) {
        super.setBackground(background);
     * Create the button that clears the text.
     * @param parent
     *            parent <code>Composite</code> of toolbar button
    private void createClearTextNew(Composite parent) {
        // only create the button if the text widget doesn't support one
        // natively
        if ((filterText.getStyle() & SWT.ICON_CANCEL) == 0) {
            final Image inactiveImage = Activator.getImageDescriptor(
                    DISABLED_CLEAR_ICON).createImage();
            final Image activeImage = Activator.getImageDescriptor(CLEAR_ICON)
                    .createImage();
            final Image pressedImage = new Image(getDisplay(), activeImage,
                    SWT.IMAGE_GRAY);
            final Label clearButton = new Label(parent, SWT.NONE);
            clearButton.setLayoutData(new GridData(SWT.BEGINNING, SWT.CENTER,
                    false, false));
            clearButton.setImage(inactiveImage);
             clearButton.setBackground(parent.getDisplay().getSystemColor (
            clearButton.setToolTipText("Tooltip");
            clearButton.addMouseListener(new MouseAdapter() {
                private MouseMoveListener fMoveListener;
                    clearButton.setImage(pressedImage);
                    fMoveListener = new MouseMoveListener() {
                        private boolean fMouseInButton = true;
                        public void mouseMove(MouseEvent e) {
                            boolean mouseInButton = isMouseInButton(e);
                            if (mouseInButton != fMouseInButton) {
                                fMouseInButton = mouseInButton;
                                clearButton
                                        .setImage(mouseInButton ? pressedImage
                                                : inactiveImage);
                    clearButton.addMouseMoveListener(fMoveListener);
                public void mouseUp(MouseEvent e) {
                    if (fMoveListener != null) {
                        clearButton.removeMouseMoveListener(fMoveListener);
                        fMoveListener = null;
                        clearButton.setImage(mouseInButton ? activeImage
                                : inactiveImage);
                        if (mouseInButton) {
                            clearText();
                            filterText.setFocus();
                private boolean isMouseInButton(MouseEvent e) {
                    Point buttonSize = clearButton.getSize();
                    return 0 <= e.x && e.x < buttonSize.x && 0 <= e.y
                            && e.y < buttonSize.y;
            clearButton.addMouseTrackListener(new MouseTrackListener() {
                public void mouseEnter(MouseEvent e) {
                    clearButton.setImage(activeImage);
                public void mouseExit(MouseEvent e) {
                public void mouseHover(MouseEvent e) {
            clearButton.addDisposeListener(new DisposeListener() {
                public void widgetDisposed(DisposeEvent e) {
                    inactiveImage.dispose();
                    pressedImage.dispose();
            this.clearButtonControl = clearButton;
     * Clears the text in the filter text widget.
    protected void clearText() {
     * Set the text in the filter control.
     * @param string
    protected void setFilterText(String string) {
        if (filterText != null) {
            filterText.setText(string);
            selectAll();
     * Get the filter text for the receiver, if it was created. Otherwise return
     * <code>null</code>.
     * @return the filter Text, or null if it was not created
    public Text getFilterControl() {
        return filterText;
     * Convenience method to return the text of the filter control. If the text
     * widget is not created, then null is returned.
     * @return String in the text, or null if the text does not exist
    protected String getFilterString() {
        return filterText != null ? filterText.getText() : null;
     * Set the text that will be shown until the first focus. A default value is
     * provided, so this method only need be called if overriding the default
     * initial text is desired.
     * @param text
     *            initial text to appear in text field
    public void setInitialText(String text) {
        initialText = text;
            filterText.setMessage(text);
            if (filterText.isFocusControl()) {
                setFilterText(initialText);
            } else {
                getDisplay().asyncExec(new Runnable() {
                    public void run() {
                        if (!filterText.isDisposed()
                                && filterText.isFocusControl()) {
        } else {
     * Select all text in the filter text field.
    protected void selectAll() {
            filterText.selectAll();
     * Get the initial text for the receiver.
     * @return String
    protected String getInitialText() {
        return initialText;
[Updated on: Mon, 05 October 2009 16:31] by Moderator
Re: Text and Highlighter [message #490474 is a reply to message #489770] Thu, 08 October 2009 14:20 Go to previous message
Ok setMessage(text) is enough for a highlighter
Previous Topic:SWT/AWT-bridge on MacOS 10.6
Next Topic:In TextViewer, not able to position cursor
Current Time: Sun Nov 09 21:58:08 EST 2025
Powered by FUDForum. Page generated in 0.04798 seconds
