Home » Eclipse Projects » Eclipse Platform » [DataBinding] How to enforce the selection after an update/recalculation of a ComputedList?
[DataBinding] How to enforce the selection after an update/recalculation of a ComputedList? [message #489740] Mon, 05 October 2009 13:42 Go to next message
Originally posted by: am.andreasmeissner.de
I have the following problem. I'm using a ComboViewer with an
ObservableListContentProvider and a ComputedList as input.
The update of the ComboViewer's input works fine (based on another
ComboViewer's selection). However, I have problems to enforce a default
selection of the updated ComboViewer after the ComputedList was newly
calculated. In my case I would like to simply pre-select the first
element in the ComboViewer afterwards.
What's the best approach to do so?
Thanks!
Andreas
Re: [DataBinding] How to enforce the selection after an update/recalculation of a ComputedList? [message #490505 is a reply to message #489740] Thu, 08 October 2009 16:36 Go to previous messageGo to next message
Hi Andreas,
if you always have the same ComputeList as viewer input and you
want to set the viewer's selection to the first element whenever
the ComputedList changes, you might do so using the ControlUpdater
class (note that this is provisional API but it's been around for
quite some while). You would then do something like the following:
final ComboViewer viewer = ...;
final ComputedList inputList = ...;
viewer.setContentProvider(new ObservableListContentProvider());
viewer.setInput(inputList);
new ControlUpdater(viewer.getControl()) {
protected void updateControl() {
if (!inputList.isEmpty()) {
viewer.setSelection(new StructuredSelection(inputList.get(0)));
I hope this helps.
Ovidio
Andreas Meißner wrote:
> Thanks!
> Cheers,
> Andreas
Re: [DataBinding] How to enforce the selection after an update/recalculation of a ComputedList? [message #490535 is a reply to message #490505] Fri, 09 October 2009 00:53 Go to previous messageGo to next message
Thanks, for the hint! Unfortunately we're not allowed to use internal
code in our project.
However, I will keep an eye on this class .. maybe it's becoming public
API in the future and I can use it in other projects.
BTW, right now I'm using a little ugly hack to solve my problem by
starting a delayed UIJob inside the ComputedList that updates the
control afterwards if necessary. Not nice but it works.
Thanks again.
Andreas
Ovidio Mallo schrieb:
> Hi Andreas,
> I hope this helps.
> Regards,
> Ovidio
>> Hi,
>> default selection of the updated ComboViewer after the ComputedList
>> was newly calculated. In my case I would like to simply pre-select the
>> first element in the ComboViewer afterwards.
>> Thanks!
>> Cheers,
>> Andreas
Re: [DataBinding] How to enforce the selection after an update/recalculation of a ComputedList? [message #490705 is a reply to message #490535] Fri, 09 October 2009 14:31 Go to previous message
Andreas,
note that the ControlUpdater class is not internal but simply
provisional.
Anyhow, in your case, a simple change listener on the ComputedList would
essentially do the same like what the ControlUpdater class does.
Maybe something like the following would already be enough?
inputList.addListChangeListener(new IListChangeListener() {
public void handleListChange(ListChangeEvent event) {
if (!viewer.getControl().isDisposed() && !inputList.isEmpty()) {
// React on changes.
// Initialize the selection once.
I think that this code is pretty equivalent to the previous one using
the ControlUpdater class. Maybe this would already work for you. You
might also want to detach the listener when disposing your UI.
Ovidio
> Thanks again.
> Andreas
>> Hi Andreas,
>> I hope this helps.
>> Regards,
>> Ovidio
>>> Hi,
>>> the first element in the ComboViewer afterwards.
>>> Thanks!
>>> Cheers,
>>> Andreas
Previous Topic:How to make Browser.setText to show the XHTML?
Next Topic:Installed Features Versions
Current Time: Wed Jul 23 11:29:46 EDT 2025
Powered by FUDForum. Page generated in 0.05492 seconds
