Home » Eclipse Projects » Rich Client Platform (RCP) » How to create a RCP programatically?
How to create a RCP programatically? [message #488883] Wed, 30 September 2009 10:56 Go to next message
I've been able to create an RCP by using a .product file where I specify
the features and plugins I want to include in the final product. I've used
the "Eclipse Product export wizard" that can be launched directly using the
multipage editor available for .product files (Product Configuration
editor). My question is the following:
Is it possible to do something like this (I mean something similar to what
the wizard does)? I've thought of checking the method
"performFinish" of the class "BaseExportWizard" of
"org.eclipse.pde.internal.ui.wizards.exports" just to see how it's done by
the editor, but everything is "internal" so I've realized the export wizard
is not intended to be launched by anyone other than the editor itself. What
can I do?
Any suggestion will be highly appreciated :-)
Thanks in advance.
Mario
Re: How to create a RCP programatically? [message #489133 is a reply to message #488883] Thu, 01 October 2009 11:05 Go to previous messageGo to next message
If your goal is to do a headless build, there are mechanisms to do this;
it's done through PDE Build and is fairly complex. Google can help you get
started.
As far as I know, the Eclipse product export wizard is using PDE Build under
the hood.
James
"Mario Cervera" <mcervera@pros.upv.es> wrote in message
news:h9vrj0$9rc$1@build.eclipse.org...
> used the "Eclipse Product export wizard" that can be launched directly
> using the multipage editor available for .product files (Product
> Configuration editor). My question is the following:
> wizard is not intended to be launched by anyone other than the editor
> itself. What can I do?
> Thanks in advance.
> Mario
Re: How to create a RCP programatically? [message #489154 is a reply to message #489133] Thu, 01 October 2009 12:03 Go to previous messageGo to next message
I know the wizard is usgin PDE Build under the hood ... the problem is that
I'd like to invoke that functionality too but I can't because all the code
is internal :-( ... there must be a way to export an RCP programatically but
I don't know how
Mario
"James Peltzer" <jpeltzer@rossvideo.com> escribi
Re: How to create a RCP programatically? [message #489406 is a reply to message #489154] Fri, 02 October 2009 16:37 Go to previous messageGo to next message
If you know how to set up a headless build for your product, then you can consider programmatically generating those files in a temporary folder somewhere. And then running pde.build against that.
Consider something like:
//get pde.build template properties file
Bundle pdeBuild = Platform.getBundle("org.eclipse.pde.build");
URL templateProperties = FileLocator.find(pdeBuild, new Path("templates/headless-build/build.properties"));
//load the template properties, add the properties you need to change, and store the properties somewhere
Properties builderProperties = new Properties();
builderProperties.load( templateProperties.openStream());
builderProperties.put(...);
builderProperties.store(...);
//find the pde.build main build.xml
URL buildXML = FileLocator.find(pdeBuild, new Path("scripts/productBuild/productBuild.xml"));
String buildXMLPath = FileLocator.toFileURL(buildXML).getPath();
//run ant on the productBuild.xml
AntRunner runner = new AntRunner(); //from org.eclipse.ant.core
//just like the ant command line
String [] args = new String [] { "-buildfile", buildXmlPath, "-Dbuilder=" + tempFolder, ... };
runner.run((Object) args);
The PDE/Build junit tests do a lot of this kind of thing. You could look at them as an example. The code is in cvs host: dev.eclipse.org, repository path: /cvsroot/eclipse, project: pde/build/org.eclipse.pde.build.tests
Re: How to create a RCP programatically? [message #489827 is a reply to message #489406] Tue, 06 October 2009 03:38 Go to previous message
Thanks a lot :D, that looks like what I was looking for. I'll try it soon.
Mario
"Andrew Niefer" <aniefer@ca.ibm.com> escribi
Previous Topic:How to receive events for ViewPart
Next Topic:eSWT
Current Time: Sat Jul 26 03:56:50 EDT 2025
Powered by FUDForum. Page generated in 0.08584 seconds
