Home » Modeling » EMF » Where to setIntrinsicIDToEObjectMap
| Where to setIntrinsicIDToEObjectMap [message #488822] |
Wed, 30 September 2009 08:25  |
from searching the web I learned that providing a map via
ResourceImpl.setIntrinsicIDToEObjectMap(Map)
may improve the load performance when using IDs for references (correct
me if I'm wrong).
First I wondered if there is an OPTION to get the same effect and
considered OPTION_USE_CACHED_LOOKUP_TABLE a candidate but couldn't
clarify that.
If there is no option where then is the right place to call the
setIntrinsicIDToEObjectMap method.
Normally I load the resource using:
resource = editingDomain.getResourceSet().getResource(resourceURI,
true);
And this is how I call setIntrinsicIDToEObjectMap:
if (resource instanceof ResourceImpl) {
ResourceImpl impl = (ResourceImpl) resource;
if (impl.getIntrinsicIDToEObjectMap() == null) {
impl.setIntrinsicIDToEObjectMap(new HashMap());
I guess there is no point calling setIntrinsicIDToEObjectMap after it is
already loaded like outlined above. So where could I intervene in order
to provide that HashMap before the actual loading takes place?
Thanks and Regards,
Dirk
| Re: Where to setIntrinsicIDToEObjectMap [message #489022 is a reply to message #488877] |
Thu, 01 October 2009 05:18   |
Ed Merks schrieb:
> Dirk,
> Comments below.
> Dirk Hoffmann wrote:
>> Ed Merks schrieb:
>>> Dirk,
>>> Comments below.
>>>> Hi,
>>>> (correct me if I'm wrong).
>>> Yes, it definitely will.
>>>> clarify that.
>>> No.
>>> Perhaps in the factory where the resource is first created.
>>>> true);
>>>> it is already loaded like outlined above. So where could I intervene
>>>> in order to provide that HashMap before the actual loading takes place?
>>> The factory seems best.
>> Seems reasonable, however when customizing the generated editor where
>> can I hook in my own Resource.Factory implementation without having to
>> recreate the mappings from URIs to Factories?
> The model typically registers a resource factory based on the extension
> or the content type. If you don't have one already, change the
> GenPackage settings so generate a XyzResourceFactoryImpl.#
Ah thanks for that.
Ok, changed the xyz.genmodel to produce an XyzResourceFactoryImpl and an
XyzResourceImpl. Changed the generated XyzResourceImpl to use the
HashMap when loading and respect the save and load options.
However the generated editor still uses the standard XMIResourceImpl
instead of the XyzResourceImpl. I guess the XyzResourceFactoryImpl has
to be registered somewhere with the .xyz file extension. From the book I
learned that this can be achieved with an extension point or put
directly into the code. As I want the extension to be customizable
through an Eclipse preference the extension point solution is not an
option. Maybe using "*" as the extension and checking the URIs outside
of EMF could be another solution.
So the question is. Where is the best place to do that
XyzResourceFactoryImpl registering?
Register with the Resource.Factory.Registry or with each newly created
ResourceSet?
All that resource stuff is quite confusing to me (and then there is also
the package registry).
>> All I have is the EditingDomain which I can ask to get the ResourceSet
>> which I can ask to get the Registry for Resource.Factories. But what
>> then to do with the registry - do I need to iterate through the maps
>> and replace the XMIResourceFactories with my own one (may be a generic
>> factory just wrapping the original one)?
> No. Does your model have an XyzResourceFactoryImpl yet?
>>>> Thanks and Regards,
>>>> Dirk
| Re: Where to setIntrinsicIDToEObjectMap [message #489039 is a reply to message #488877] |
Thu, 01 October 2009 05:51   |
Ed Merks schrieb:
> Dirk,
> Comments below.
>> Ed Merks schrieb:
>>> Dirk,
>>> Comments below.
>>>> Hi,
>>>> clarify that.
>>> No.
>>>> true);
Ah thanks for that.
I'm wondering why the code generator didn't generate the right code so
that the EditingDomain would be aware of the special
XyzResourceFactoryImpl. Maybe I forgot to do some adjustments or there
are "@generated NOT" preventing the generator to do the right thing.
So is there something I can do to let the generator create that code?
Anyway I changed the editor's piece of code responsible for the creation
of the EditingDomain like this:
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getResourceFactoryRegistry().getExtensionToFacto ryMap()
.put(Resource.Factory.Registry.DEFAULT_EXTENSION,
new XyzResourceFactory());
editingDomain = new AdapterFactoryEditingDomain(adapterFactory,
commandStack, resourceSet);
I guess the XyzResourceFactoryImpl could also be registered somewhere
option unless using "*" as the extension and checking the URIs outside
of EMF.
So the question is: What is actually considered the best place to
register the XyzResourceFactoryImpl?
ResourceSet?
>>>> Thanks and Regards,
>>>> Dirk
| Re: Where to setIntrinsicIDToEObjectMap [message #489047 is a reply to message #489039] |
Thu, 01 October 2009 07:14   |
Dirk,
Comments below.
> Ed Merks schrieb:
>> Dirk,
>> Comments below.
>>> Ed Merks schrieb:
>>>> Dirk,
>>>> Comments below.
>>>>> Hi,
>>>>> clarify that.
>>>> No.
>>>>> true);
>>>>> intervene in order to provide that HashMap before the actual
>>> where can I hook in my own Resource.Factory implementation without
>>> having to recreate the mappings from URIs to Factories?
>> extension or the content type. If you don't have one already, change
>> the GenPackage settings so generate a XyzResourceFactoryImpl.#
> Ah thanks for that.
The plugin.xml doesn't regenerate so you have to delete it to update it
to include the registration for the newly generated factory.
> creation of the EditingDomain like this:
You won't need that if it's registered.
> of EMF.
> ResourceSet?
>>> ResourceSet which I can ask to get the Registry for
>>> Resource.Factories. But what then to do with the registry - do I
>>> need to iterate through the maps and replace the
>>> XMIResourceFactories with my own one (may be a generic factory just
>>>>> Thanks and Regards,
>>>>> Dirk
| Re: Where to setIntrinsicIDToEObjectMap [message #489052 is a reply to message #489047] |
Thu, 01 October 2009 07:28   |
Ed Merks schrieb:
> Dirk,
> Comments below.
>> Ed Merks schrieb:
>>> Dirk,
>>> Comments below.
>>>> Ed Merks schrieb:
>>>>> Dirk,
>>>>> Comments below.
>>>>>> Hi,
>>>>>> clarify that.
>>>>> No.
>>>>>> true);
>> Ah thanks for that.
Ok, deleted the plugin.xml to try that out and yes its there.
Unfortunately the generator also replaced the MANIFEST file with the
generated version. It should check for the existance of the files
individually. Working with EMF 2.2.5.
>> of EMF.
>> ResourceSet?
>>>>>> Thanks and Regards,
>>>>>> Dirk
| Re: Where to setIntrinsicIDToEObjectMap [message #489053 is a reply to message #489052] |
Thu, 01 October 2009 07:37  |
Dirk,
Comments below.
> Ed Merks schrieb:
>> Dirk,
>> Comments below.
>>> Ed Merks schrieb:
>>>> Dirk,
>>>> Comments below.
>>>>> Ed Merks schrieb:
>>>>>> Dirk,
>>>>>> Comments below.
>>>>>>> Hi,
>>>>>>> and considered OPTION_USE_CACHED_LOOKUP_TABLE a candidate but
>>>>>>> couldn't clarify that.
>>>>>> No.
>>>>>>> true);
>>>>>>> after it is already loaded like outlined above. So where could I
>>>> change the GenPackage settings so generate a XyzResourceFactoryImpl.#
>>> Ah thanks for that.
>>> and an
>> it to include the registration for the newly generated factory.
An initially empty EMF plugin project needs a manifest to be considered
correct by PDE so we're often faced with this situation. In any case,
Eclipse has a nice local history and it's simple to replace a file with
an earlier version...
>>> so that the EditingDomain would be aware of the special
>>> there are "@generated NOT" preventing the generator to do the right
>>> thing.
>>> of EMF.
>>> ResourceSet?
>>> also
>>>>>>> Thanks and Regards,
>>>>>>> Dirk
Current Time: Thu Nov 06 01:18:57 EST 2025
Powered by FUDForum. Page generated in 0.05486 seconds
