Home » Modeling » EMF » Recurring EMF Problem What Causes This?
Recurring EMF Problem What Causes This? [message #488728] Tue, 29 September 2009 19:30 Go to next message
All,
I keep encountering a problem with EMF, which more than once I thought I fixed only to have it crop up again. Can any give me some insight into what is likely to be causing this?
The line of my code that provokes the error is:
ScenarioPackage pkgScenario = ScenarioPackage.eINSTANCE;
The code in question executes correctly from within eclipse but not from an executable jar file. All the dependencies necessary for EMF seem to be included in the jar. The ScenarioPackage and all its ilk were generated from an XSD.
I create my jar using the eclipse export wizard basing it on a working launch configuration. I do get a series of warnings complaining about duplicate entries, but these don't ever seem to be a problem.
Thanks in advance.
Error dump:
Exception in thread "main" java.lang.ExceptionInInitializerError
at qq.mob.utility.mr.UtService.getInstance(UtService.java:68)
at qq.mob.stage.mr.StageDriver.main(StageDriver.java:25)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.apache.hadoop.util.RunJar.main(RunJar.java:156)
Caused by: java.lang.UnsupportedOperationException
at org.eclipse.emf.ecore.impl.MinimalEObjectImpl.eBasicAdapters (MinimalEObjectImpl.java:292)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotifi cationRequired(BasicNotifierImpl.java:261)
at org.eclipse.emf.ecore.impl.EFactoryImpl.basicSetEPackage(EFa ctoryImpl.java:142)
at org.eclipse.emf.ecore.impl.EFactoryImpl.eInverseAdd(EFactory Impl.java:670)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eInverseAdd(Basi cEObjectImpl.java:1407)
at org.eclipse.emf.ecore.impl.EPackageImpl.setEFactoryInstance( EPackageImpl.java:382)
at org.eclipse.emf.ecore.impl.EPackageImpl.<init>(EPackageImpl.java:181)
at qq.mob.scenario.impl.ScenarioPackageImpl.<init>(ScenarioPackageImpl.java:92)
at qq.mob.scenario.impl.ScenarioPackageImpl.init(ScenarioPackag eImpl.java:118)
at qq.mob.scenario.ScenarioPackage.<clinit>(ScenarioPackage.java:60)
... 7 more
Re: Recurring EMF Problem What Causes This? [message #488769 is a reply to message #488728] Wed, 30 September 2009 04:22 Go to previous messageGo to next message
--------------090607000900050802040106
Geoffry,
Comments below.
Geoffry Roberts wrote:
> All,
Initializing the package...
> Thanks in advance.
> Error dump:
> at
> ssorImpl.java:39)
> at
> at java.lang.reflect.Method.invoke(Method.java:597)
> at
> at
If you look at the source code for this, what might you deduce?
For me eNotificationRequired looks like this:
public boolean eNotificationRequired()
return eBasicHasAdapters() && eDeliver();
which should call this method in MinimalEObjectImpl:
protected boolean eBasicHasAdapters()
return hasField(ADAPTER);
Yet for you it's calling eBasicAdapters which indeed is not supported:
protected BasicEList<Adapter> eBasicAdapters()
throw new UnsupportedOperationException();
What does that suggest as the source of the problem?
> at
> ctoryImpl.java:142)
> at
> Impl.java:670)
> at
> at
> at
> at
> at
> eImpl.java:118)
> at
> ... 7 more
Content-Type: text/html; charset=UTF-8
<html>
<head>
<meta content="text/html;charset=UTF-8" http-equiv="Content-Type">
</head>
Geoffry,<br>
<br>
Comments below.<br>
<br>
<blockquote cite="mid:h9u59r$1m4$1@build.eclipse.org" type="cite">All,
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
Initializing the package...<br>
<blockquote cite="mid:h9u59r$1m4$1@build.eclipse.org" type="cite"><br>
<br>
<br>
<br>
<br>
Thanks in advance.
<br>
<br>
Error dump:
<br>
<br>
<br>
<br>
<br>
<br>
ssorImpl.java:39)
<br>
<br>
<br>
<br>
<br>
<br>
<br>
<br>
</blockquote>
If you look at the source code for this, what might you deduce?<br>
<br>
For me eNotificationRequired looks like this:<br>
<blockquote>  public boolean eNotificationRequired()<br>
  {<br>
    return eBasicHasAdapters() &amp;&amp; eDeliver();<br>
  }<br>
</blockquote>
which should call this method in MinimalEObjectImpl:<br>
<blockquote>  @Override<br>
  protected boolean eBasicHasAdapters()<br>
  {<br>
    return hasField(ADAPTER);<br>
  }<br>
</blockquote>
Yet for you it's calling eBasicAdapters which indeed is not supported:<br>
  protected BasicEList&lt;Adapter&gt; eBasicAdapters()<br>
  {<br>
    throw new UnsupportedOperationException();<br>
  }<br>
</blockquote>
What does that suggest as the source of the problem?<br>
ctoryImpl.java:142)
<br>
Impl.java:670)
<br>
<br>
<br>
       at
org.eclipse.emf.ecore.impl.EPackageImpl.&lt;init&gt; (EPackageImpl.java:181)
<br>
       at
qq.mob.scenario.impl.ScenarioPackageImpl.&lt;init&gt ;(ScenarioPackageImpl.java:92)
<br>
eImpl.java:118)
<br>
       at
qq.mob.scenario.ScenarioPackage.&lt;clinit&gt;(Scena rioPackage.java:60)
<br>
       ... 7 more
<br>
<br>
</blockquote>
</body>
</html>
--------------090607000900050802040106--
Re: Recurring EMF Problem What Causes This? [message #488904 is a reply to message #488728] Wed, 30 September 2009 12:25 Go to previous messageGo to next message
Ed,
Your response indicates that the answer is right under my nose and it may well be. But I'm not getting it. Perhaps I'm hung on the fact that when I run this from within eclipse, it works and when I run from a jar whose export was based on that same launch configuration, it fails.
The only thing I can conclude is there is some kind of dependency missing from the jar. If so, it must be a run time dependency because things are compiling. If so, why is the jar not being created properly?
Sorry, but something, something obvious no doubt, is getting past me.
Re: Recurring EMF Problem What Causes This? [message #488926 is a reply to message #488728] Wed, 30 September 2009 13:51 Go to previous messageGo to next message
All,
What follows is a progress note not a definitive solution.
First a quick bit of background. I am writing a MapReduce job to run under Hadoop 0.20.0. I want to use a bit of my own legacy code that is based in EMF to drive the whole mapred business. It seems the error I'm encountering only occurs when I include either of the following two libraries:
commons-cli-2.0-SNAPSHOT.jar
commons-codec-1.3.jar
Both of these are distributed with Hadoop and the MapReduce plugin automatically includes them as Reference Libraries when you use its wizard to set up a MapReduce project. Clearly, these two jars are not playing well with EMF--add 'em in, failure; take 'em out, success. It's just like that.
The question remains, does an MR job really need all these jars or does the wizard take the kitchen sink approach when doing its includes.
For my next trick, I'll try running the job for real and see if it goes.
Re: Recurring EMF Problem What Causes This? [message #489013 is a reply to message #488904] Thu, 01 October 2009 04:26 Go to previous message
Geoffry,
When a stack trace shows different behavior than the expected source
code you can generally assume that the binary code you're actually
executing didn't derive from that source. In other words,
BasicNotifierImpl.eNotificationRequired should call eBasicHasAdapters()
but in your case it's calling eBasicAdapters() which to me says you're
using an other version of org.eclipse.emf.common*.jar with a newer
version of org.eclipse.emf.ecore*.jar. Check the versions of all your
jars and if that doesn't reveal an obvious problem, check all the jars
that they don't embed EMF classes.
> Ed,
Previous Topic:[Teneo] DuplicateMappingException
Next Topic:Where to setIntrinsicIDToEObjectMap
Current Time: Sat Jul 19 01:56:11 EDT 2025
Powered by FUDForum. Page generated in 0.03566 seconds
