Home » Modeling » M2T (model-to-text transformation) » Check editor problems
Check editor problems [message #488442] Mon, 28 September 2009 12:58 Go to next message
Originally posted by: ML1984.gmx.de
Hi there,
I am experiencing trouble with the Check editor. I defined a Check file,
referencing a Xtend file. Although both files are accessible via class
path and there is a proper 'extension' declaration in the Check file,
the editor complains about not found operations:
"Couldn't find operation 'isNullOrEmpty(ecore::EString)'
for type 'tgg::Node'"
In fact, there is no operation for this type, but 'isNullOrEmpty' is
declared in the Xtend file. Interestingly, the check file works
properly, i.e. 'isNullOrEmpty' is called.
Am I doing something wrong?
Is this a bug in the editor?
How can the above problem be solved (for me)?
There are additional errors, but I think they are already filed as bugs
in: https://bugs.eclipse.org/bugs/show_bug.cgi?id=262258
Mark
PS. I am using Eclipse Modeling Tools SR1 with Xtext/Xpand 0.7.2.
Re: Check editor problems [message #488453 is a reply to message #488442] Mon, 28 September 2009 13:41 Go to previous messageGo to next message
Hi Mark,
did you try to restart Eclipse? The editor messes things up if you open
and close projects that are on the classpath of the project that
contains the check / xpand files. Maybe there are other situations that
reveal this bug as well.
Sebastian
Mark L. schrieb:
> Hi there,
> Cheers,
> Mark
Re: Check editor problems [message #488550 is a reply to message #488453] Tue, 29 September 2009 04:38 Go to previous messageGo to next message
Hi Sebastian,
I tried to restart Eclipse several times. All of the 12 errors remain :(
Any other suggestions?
Mark
> Hi Mark,
> Regards,
> Sebastian
Re: Check editor problems [message #488563 is a reply to message #488453] Tue, 29 September 2009 05:08 Go to previous messageGo to next message
I should mention an important detail:
The errors ('operation not found...') only appear on pure Xtend
extensions, i.e. non Java extensions.
May the force be with you!
Mark
> Hi Mark,
> Regards,
> Sebastian
Re: Check editor problems [message #488575 is a reply to message #488563] Tue, 29 September 2009 06:19 Go to previous messageGo to next message
What does your *.ecore file look like?
Do you refer to ecore.ecore using a platform:resource/ URI?
Sven
> Mark
>> Hi Mark,
>> open and close projects that are on the classpath of the project that
>> that reveal this bug as well.
>> Regards,
>> Sebastian
Re: Check editor problems [message #488584 is a reply to message #488575] Tue, 29 September 2009 06:44 Go to previous messageGo to next message
Hi Sven.
It includes only one package, but references a further meta model, which
references Ecore.ecore. All namespace URIs start with http://, I think
there is nothing odd.
Ecore.ecore is referenced via
platform:/plugin/org.eclipse.emf.ecore/model/Ecore.ecore
Mark
Re: Check editor problems [message #488869 is a reply to message #488584] Wed, 30 September 2009 10:43 Go to previous messageGo to next message
Xpand assumes that ecore files reference Ecore.ecore by its nsURI.
If you change the resource uri with ecore's nsURI it should work.
Sven
Re: Check editor problems [message #489308 is a reply to message #488869] Fri, 02 October 2009 07:20 Go to previous message
Hi Sven.
Thanks, that solved the 'operation not found' issue.
Errors for conversions from Java types to ECore types remain.
Bug: https://bugs.eclipse.org/bugs/show_bug.cgi?id=262258
Mark
Previous Topic:Share Xpand templates
Next Topic:[xPand] No protected region resolver configured
Current Time: Wed Jul 23 19:06:57 EDT 2025
Powered by FUDForum. Page generated in 0.05661 seconds
