Removing actions from Subversive view pop-up menu [message #485289] |
Fri, 11 September 2009 04:31  |
My objective is (trying) to disable some Action contributions in the
pop-up menu of a contributed view, all by the same plugin (Subversive).
I used the Subversive Capability and it disabled a lot of UI
contributions, but not these actions in context menus. Subversive plugin
adds directly these actions in the pop-up menu and does not define any
"ActionDefinitionId".
I integrate this plugin in my application and use some "team" views
(History and Synchronize), but I don't need its SVN actions contributions
in menus because I've redefined my proper actions (commands) in my proper
sub-menu and then calling the Subversive API, the job is done.
So, I need to remove the unnecessary SVN actions added by the Subversive
plugin in the pop-up menu of one view.
Is there a workbench API to do that ?
Should I associate the Actions to "Command Ids" and they will be disabled
by the Capability ? But how can I get these actions to set their
"ActionDefinitionId" ?
In cross posted this article in the eclipse.platform forum.
Thanks you for your help.
JM.D
Re: Removing actions from Subversive view pop-up menu [message #487714 is a reply to message #485289] |
Thu, 24 September 2009 04:41   |
Hello Jean-Marie,
In what view do you want to disable Subversive actions, e.g. Synchronize,
History etc.? For completeness, please provide some names of actions you
want to disable.
> plugin in the pop-up menu of one view. Is there a workbench API to do that
> ? Should I associate the Actions to "Command Ids" and they will be
> disabled by the Capability ? But how can I get these actions to set their
> JM.D
FUDForum. Page generated in 0.05800 seconds
