Home » Eclipse Projects » Eclipse 4 » BundleContext - ServiceTracker
BundleContext - ServiceTracker [message #488244] Sat, 26 September 2009 11:57 Go to next message
In E4 - RCP application, how to get the instance of BundleContext so that it
can be used in ServiceTracker.
Or is there a different way to get the instance of ServiceTracker instead of
ServiceTracker oSTEventAdmin = new ServiceTracker(bundlecontext,
EventAdmin.class.getName(), null);
My Objective is to get the EventAdmin service in E4.
- Walter.
Re: BundleContext - ServiceTracker [message #488392 is a reply to message #488244] Mon, 28 September 2009 10:11 Go to previous messageGo to next message
For the simple cases, you can just ask your part IEclipseContext (the topmost application context talks to OSGi).
ex: context.get(EventAdmin.class.getName())
Otherwise you need your context to set up your ServiceTracker yourself: org.osgi.framework.FrameworkUtil (1.3) can get your Bundle if you don't have an activator
PW
Re: BundleContext - ServiceTracker [message #489326 is a reply to message #488392] Fri, 02 October 2009 09:04 Go to previous messageGo to next message
Hi Paul,
Context is null
Bundle oB = org.osgi.framework.FrameworkUtil.getBundle ( oClass ) ;
System.out.println ( "Bundle: " + oB ) ;
System.out.println ( "BundleContext: " + oB.getBundleContext ( ) ) ;
Output
Bundle: com.javacraft.trader_1.0.0.qualifier [66]
BundleContext: null
Any idea why the context is null ?
Best Regards,
Walter G. Prabhakar.
"Paul Webster" <pwebster@ca.ibm.com> wrote in message
news:h9qg5p$uol$1@build.eclipse.org...
> have an activator
> PW
> Paul Webster
> http://wiki.eclipse.org/Platform_Command_Framework
> http://wiki.eclipse.org/Command_Core_Expressions
> http://wiki.eclipse.org/Menu_Contributions
Re: BundleContext - ServiceTracker [message #489658 is a reply to message #489326] Mon, 05 October 2009 09:50 Go to previous messageGo to next message
Walter wrote on Fri, 02 October 2009 09:04
Hi Paul,
Context is null
Output
BundleContext: null
Has that bundle been started yet? See the javadoc for getBundleContext() which explains when it will return null.
PW
Re: BundleContext - ServiceTracker [message #563525 is a reply to message #488244] Mon, 28 September 2009 10:11 Go to previous messageGo to next message
PW
Paul Webster
Re: BundleContext - ServiceTracker [message #563595 is a reply to message #563525] Fri, 02 October 2009 09:04 Go to previous messageGo to next message
Hi Paul,
Context is null
Output
BundleContext: null
Best Regards,
> have an activator
> PW
> Paul Webster
Re: BundleContext - ServiceTracker [message #563615 is a reply to message #489326] Mon, 05 October 2009 09:50 Go to previous message
> Hi Paul,
> Context is null
> Output
> BundleContext: null
PW
Paul Webster
Previous Topic:converting existing rcp application to e4 based
Next Topic:Why is it that on double click on view tab , it doesn't expand
Current Time: Sun Jul 27 23:02:40 EDT 2025
Powered by FUDForum. Page generated in 0.08539 seconds
