Allow to resize row header width [message #487727] |
Thu, 24 September 2009 04:58  |
Is it possible to allow users to resize row header width? Right now we can
just set it at design time and there is no API to allow users to resize it
at runtime.
Mustufa
Re: Allow to resize row header width [message #488325 is a reply to message #488156] |
Mon, 28 September 2009 02:52  |
Hi Tom,
Any idea when this feature will be available in Nebula? We are using Nebula
in our project and getting near to the completion date. This feature may
become a show stopper for us. We would be highly grateful if this could be
implemented as early as possible.
Thanking in advance.
Mustufa
"Mustufa Kasidwala" <m.kasid@gmail.com> wrote in message
news:h9iuf0$9bq$1@build.eclipse.org...
> Done.
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=290575
> Mustufa
> "Tom Schindl" <tom.schindl@bestsolution.at> wrote in message
> news:h9ise6$t62$1@build.eclipse.org...
>> Not as far as I know so you need to file a feature request
>> Mustufa Kasidwala schrieb:
>>> Thanks Tom,
>>> I can see that there is an API Grid#setItemHeaderWidth to adjust row
>>> header
>>> width. But this is only useful at design time. Do you know if there is
>>> some
>>> API (a boolean property maybe) which I can use so that the users can
>>> adjust
>>> the width at runtime using mouse ?
>>> If no, then is there a feature request raised for this?
Re: Allow to resize row header width [message #598268 is a reply to message #487727] |
Fri, 25 September 2009 06:25  |
IIRC there's API to set it but no lister code.
Tom
> at runtime.
Re: Allow to resize row header width [message #598289 is a reply to message #488018] |
Fri, 25 September 2009 12:09  |
Thanks Tom,
I can see that there is an API Grid#setItemHeaderWidth to adjust row header
width. But this is only useful at design time. Do you know if there is some
API (a boolean property maybe) which I can use so that the users can adjust
Mustufa
news:h9i5rm$ohp$2@build.eclipse.org...
> Tom
>> Hi,
>> can
>> it
>> at runtime.
Re: Allow to resize row header width [message #598304 is a reply to message #488140] |
Fri, 25 September 2009 12:51  |
> Thanks Tom,
Re: Allow to resize row header width [message #598316 is a reply to message #488156] |
Hi Tom,
Mustufa
> Done.
> Mustufa
>>> Thanks Tom,
>>> header
>>> some
>>> adjust
FUDForum. Page generated in 0.05557 seconds
