Galileo Update Not Working - Eclipse IDE for Java EE Developers 1.2.1.20090918-0703 [message #488075] |
Fri, 25 September 2009 09:46  |
Originally posted by: andrealuciano.dessi.gmail.com
--------------020804060705000302020804
Hi all,
i'm running Galileo (Build id: 20090621-0832) under
Ubuntu 9.04 with Java(TM) SE Runtime Environment (build 1.6.0_16-b01).
My update mananger tell me to install:
Eclipse IDE for Java EE Developers 1.2.1.20090918-0703 (epp.package.jee).
But not working.
Error Log attached to this mail.
Any help?
Kind Regards, Andrea
Content-Type: text/x-log;
name="error.log"
Content-Disposition: inline;
filename="error.log"
!ENTRY org.eclipse.wst.server.core 4 0 2009-09-24 10:38:02.996
!MESSAGE Server Tomcat v6.0 Server at localhost was unable to start within 1 seconds. If the server requires more time, try increasing the timeout in the server editor.
!ENTRY org.eclipse.osgi 2 0 2009-09-24 10:52:57.627
!MESSAGE While loading class " org.eclipse.rse.ui.SystemPreferencesManager$ModelChangeListe ner ", thread "Thread[Worker-19,5,main]" timed out waiting (5000ms) for thread "Thread[main,6,main]" to finish starting bundle "org.eclipse.rse.ui_3.1.0.v200905272300 [526]". To avoid deadlock, thread "Thread[Worker-19,5,main]" is proceeding but " org.eclipse.rse.ui.SystemPreferencesManager$ModelChangeListe ner " may not be fully initialized.
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle " reference:file:plugins/org.eclipse.rse.ui_3.1.0.v20090527230 0.jar " by thread "main".
at org.eclipse.osgi.framework.internal.core.AbstractBundle.begi nStateChange(AbstractBundle.java:1073)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:278)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:376)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:452)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:405)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:393)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
at org.eclipse.rse.ui.SystemPreferencesManager$1.run(SystemPref erencesManager.java:510)
Caused by: org.eclipse.osgi.framework.internal.core.AbstractBundle$Bund leStatusException
... 15 more
Root exception:
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:01:05.342
!MESSAGE StructuredTextViewer.exception.verifyText
!STACK 0
at org.eclipse.wst.css.ui.internal.autoedit.StructuredAutoEditS trategyCSS$CompoundRegion.getType(StructuredAutoEditStrategy CSS.java:62)
at org.eclipse.wst.css.ui.internal.autoedit.StructuredAutoEditS trategyCSS.getPrevKeyRegion(StructuredAutoEditStrategyCSS.ja va:233)
at org.eclipse.wst.css.ui.internal.autoedit.StructuredAutoEditS trategyCSS.autoIndentAfterNewLine(StructuredAutoEditStrategy CSS.java:123)
at org.eclipse.wst.css.ui.internal.autoedit.StructuredAutoEditS trategyCSS.customizeDocumentCommand(StructuredAutoEditStrate gyCSS.java:154)
at org.eclipse.jface.text.TextViewer.customizeDocumentCommand(T extViewer.java:3734)
at org.eclipse.jface.text.TextViewer.handleVerifyEvent(TextView er.java:3764)
at org.eclipse.jface.text.source.projection.ProjectionViewer.ha ndleVerifyEvent(ProjectionViewer.java:1276)
at org.eclipse.wst.sse.ui.internal.StructuredTextViewer.handleV erifyEvent(StructuredTextViewer.java:706)
at org.eclipse.jface.text.TextViewer$TextVerifyListener.verifyT ext(TextViewer.java:433)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:249)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1200)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1185)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 025)
at org.eclipse.swt.custom.StyledText.modifyContent(StyledText.j ava:6602)
at org.eclipse.swt.custom.StyledText.sendKeyEvent(StyledText.ja va:7442)
at org.eclipse.swt.custom.StyledText.doContent(StyledText.java: 2441)
at org.eclipse.swt.custom.StyledText.handleKey(StyledText.java: 5814)
at org.eclipse.swt.custom.StyledText.handleKeyDown(StyledText.j ava:5839)
at org.eclipse.swt.custom.StyledText$7.handleEvent(StyledText.j ava:5541)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1212 )
at org.eclipse.swt.widgets.Widget.gtk_key_press_event(Widget.ja va:706)
at org.eclipse.swt.widgets.Control.gtk_key_press_event(Control. java:2837)
at org.eclipse.swt.widgets.Composite.gtk_key_press_event(Compos ite.java:703)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1570)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4586 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4191 )
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:75 86)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1185)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:1858)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3110)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:01:05.645
!STACK 0
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:17:39.870
!STACK 0
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:17:39.989
!STACK 0
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:17:41.269
!STACK 0
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:19:06.757
!STACK 0
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:19:06.902
!STACK 0
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:20:20.902
!STACK 0
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:20:21.037
!STACK 0
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:20:21.213
!STACK 0
!ENTRY org.eclipse.help.base 4 0 2009-09-24 13:33:21.580
!MESSAGE An error occured while pre-processing help XHTML document "/org.eclipse.jpt.doc.user/task_inheritance.htm" for search indexing
!STACK 0
at com.sun.org.apache.xerces.internal.dom.DeferredDocumentImpl. setChunkIndex(DeferredDocumentImpl.java:1944)
at com.sun.org.apache.xerces.internal.dom.DeferredDocumentImpl. appendChild(DeferredDocumentImpl.java:644)
at com.sun.org.apache.xerces.internal.parsers.AbstractDOMParser .characters(AbstractDOMParser.java:1191)
at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator. characters(XMLDTDValidator.java:862)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 463)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:807)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:737)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:107)
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(D OMParser.java:225)
at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl. parse(DocumentBuilderImpl.java:283)
at org.eclipse.help.internal.dynamic.DocumentReader.read(Docume ntReader.java:56)
at org.eclipse.help.internal.dynamic.XMLProcessor.process(XMLPr ocessor.java:49)
at org.eclipse.help.internal.xhtml.DynamicXHTMLProcessor.proces s(DynamicXHTMLProcessor.java:76)
at org.eclipse.help.internal.search.XHTMLSearchParticipant.prep rocess(XHTMLSearchParticipant.java:103)
at org.eclipse.help.search.XMLSearchParticipant.addDocument(XML SearchParticipant.java:301)
at org.eclipse.help.internal.search.HTMLSearchParticipant.addDo cument(HTMLSearchParticipant.java:51)
at org.eclipse.help.internal.search.SearchIndex.addDocument(Sea rchIndex.java:219)
at org.eclipse.help.internal.search.IndexingOperation.addDocume nts(IndexingOperation.java:252)
at org.eclipse.help.internal.search.IndexingOperation.addNewDoc uments(IndexingOperation.java:159)
at org.eclipse.help.internal.search.IndexingOperation.execute(I ndexingOperation.java:106)
at org.eclipse.help.internal.search.LocalSearchManager.updateIn dex(LocalSearchManager.java:620)
at org.eclipse.help.internal.search.LocalSearchManager.ensureIn dexUpdated(LocalSearchManager.java:594)
at org.eclipse.help.internal.search.federated.IndexerJob.run(In dexerJob.java:31)
!ENTRY org.eclipse.help.base 4 0 2009-09-24 13:33:29.752
!MESSAGE An error occured while pre-processing help XHTML document "/org.eclipse.jpt.doc.user/reference013.htm" for search indexing
!STACK 0
!ENTRY org.eclipse.help.base 4 0 2009-09-24 13:33:30.519
!MESSAGE An error occured while pre-processing help XHTML document "/org.eclipse.jpt.doc.user/task_mapping.htm" for search indexing
!STACK 0
Re: Galileo Update Not Working - Eclipse IDE for Java EE Developers 1.2.1.20090918-0703 [message #488429 is a reply to message #488188] |
Mon, 28 September 2009 11:47  |
Phillipus ha scritto:
> a.dessi wrote:
>> Andrew Niefer:
>>> The update for the Eclipse IDE failed because the metadata for the
>>> update was prematurely made public before the actual jars were
>>> available.
>>> Basically, the update isn't quite ready yet,
>>> The bug tracking this is
>>> https://bugs.eclipse.org/bugs/show_bug.cgi?id=290471
>>> I would expect things to work once the release is actually ready and
>>> all the jars and artifacts are synced to all the eclipse mirrors.
>>> This could be a few hours or a day, not quite sure.
>>> -Andrew
>> Oh nice to hear isnt just my Eclipse :)
>> So we'll wait for the right update.
>> Thank You, Andrea
> The thing is, this P2 rubbish has never worked properly.
mhhh still not working. :\
!SESSION 2009-09-28 17:43:26.180
eclipse.buildId=I20090611-1540
java.version=1.6.0_16
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=it_IT
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os linux -ws gtk -arch x86 -product
!ENTRY org.eclipse.equinox.p2.engine 4 4 2009-09-28 17:45:28.579
!MESSAGE An error occurred while collecting items to be installed
FUDForum. Page generated in 0.10713 seconds
