Home » Eclipse Projects » Eclipse Platform » Galileo Update Not Working - Eclipse IDE for Java EE Developers 1.2.1.20090918-0703
Galileo Update Not Working - Eclipse IDE for Java EE Developers 1.2.1.20090918-0703 [message #488075] Fri, 25 September 2009 09:46 Go to next message
Originally posted by: andrealuciano.dessi.gmail.com
--------------020804060705000302020804
Hi all,
i'm running Galileo (Build id: 20090621-0832) under
Ubuntu 9.04 with Java(TM) SE Runtime Environment (build 1.6.0_16-b01).
My update mananger tell me to install:
Eclipse IDE for Java EE Developers 1.2.1.20090918-0703 (epp.package.jee).
But not working.
Error Log attached to this mail.
Any help?
Kind Regards, Andrea
Content-Type: text/x-log;
name="error.log"
Content-Disposition: inline;
filename="error.log"
!ENTRY org.eclipse.wst.server.core 4 0 2009-09-24 10:38:02.996
!MESSAGE Server Tomcat v6.0 Server at localhost was unable to start within 1 seconds. If the server requires more time, try increasing the timeout in the server editor.
!ENTRY org.eclipse.osgi 2 0 2009-09-24 10:52:57.627
!MESSAGE While loading class " org.eclipse.rse.ui.SystemPreferencesManager$ModelChangeListe ner ", thread "Thread[Worker-19,5,main]" timed out waiting (5000ms) for thread "Thread[main,6,main]" to finish starting bundle "org.eclipse.rse.ui_3.1.0.v200905272300 [526]". To avoid deadlock, thread "Thread[Worker-19,5,main]" is proceeding but " org.eclipse.rse.ui.SystemPreferencesManager$ModelChangeListe ner " may not be fully initialized.
!STACK 0
org.osgi.framework.BundleException: State change in progress for bundle " reference:file:plugins/org.eclipse.rse.ui_3.1.0.v20090527230 0.jar " by thread "main".
at org.eclipse.osgi.framework.internal.core.AbstractBundle.begi nStateChange(AbstractBundle.java:1073)
at org.eclipse.osgi.framework.internal.core.AbstractBundle.star t(AbstractBundle.java:278)
at org.eclipse.osgi.framework.util.SecureAction.start(SecureAct ion.java:408)
at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter .postFindLocalClass(EclipseLazyStarter.java:111)
at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLoc alClass(ClasspathManager.java:449)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.fin dLocalClass(DefaultClassLoader.java:211)
at org.eclipse.osgi.internal.loader.BundleLoader.findLocalClass (BundleLoader.java:376)
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInter nal(BundleLoader.java:452)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:405)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(Bund leLoader.java:393)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loa dClass(DefaultClassLoader.java:105)
at java.lang.ClassLoader.loadClass(ClassLoader.java:252)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:320 )
at org.eclipse.rse.ui.SystemPreferencesManager$1.run(SystemPref erencesManager.java:510)
Caused by: org.eclipse.osgi.framework.internal.core.AbstractBundle$Bund leStatusException
... 15 more
Root exception:
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:01:05.342
!MESSAGE StructuredTextViewer.exception.verifyText
!STACK 0
at org.eclipse.wst.css.ui.internal.autoedit.StructuredAutoEditS trategyCSS$CompoundRegion.getType(StructuredAutoEditStrategy CSS.java:62)
at org.eclipse.wst.css.ui.internal.autoedit.StructuredAutoEditS trategyCSS.getPrevKeyRegion(StructuredAutoEditStrategyCSS.ja va:233)
at org.eclipse.wst.css.ui.internal.autoedit.StructuredAutoEditS trategyCSS.autoIndentAfterNewLine(StructuredAutoEditStrategy CSS.java:123)
at org.eclipse.wst.css.ui.internal.autoedit.StructuredAutoEditS trategyCSS.customizeDocumentCommand(StructuredAutoEditStrate gyCSS.java:154)
at org.eclipse.jface.text.TextViewer.customizeDocumentCommand(T extViewer.java:3734)
at org.eclipse.jface.text.TextViewer.handleVerifyEvent(TextView er.java:3764)
at org.eclipse.jface.text.source.projection.ProjectionViewer.ha ndleVerifyEvent(ProjectionViewer.java:1276)
at org.eclipse.wst.sse.ui.internal.StructuredTextViewer.handleV erifyEvent(StructuredTextViewer.java:706)
at org.eclipse.jface.text.TextViewer$TextVerifyListener.verifyT ext(TextViewer.java:433)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:249)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1176)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1200)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1185)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:1 025)
at org.eclipse.swt.custom.StyledText.modifyContent(StyledText.j ava:6602)
at org.eclipse.swt.custom.StyledText.sendKeyEvent(StyledText.ja va:7442)
at org.eclipse.swt.custom.StyledText.doContent(StyledText.java: 2441)
at org.eclipse.swt.custom.StyledText.handleKey(StyledText.java: 5814)
at org.eclipse.swt.custom.StyledText.handleKeyDown(StyledText.j ava:5839)
at org.eclipse.swt.custom.StyledText$7.handleEvent(StyledText.j ava:5541)
at org.eclipse.swt.widgets.Widget.sendKeyEvent(Widget.java:1212 )
at org.eclipse.swt.widgets.Widget.gtk_key_press_event(Widget.ja va:706)
at org.eclipse.swt.widgets.Control.gtk_key_press_event(Control. java:2837)
at org.eclipse.swt.widgets.Composite.gtk_key_press_event(Compos ite.java:703)
at org.eclipse.swt.widgets.Widget.windowProc(Widget.java:1570)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4586 )
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4191 )
at org.eclipse.swt.internal.gtk.OS._gtk_main_do_event(Native Method)
at org.eclipse.swt.internal.gtk.OS.gtk_main_do_event(OS.java:75 86)
at org.eclipse.swt.widgets.Display.eventProc(Display.java:1185)
at org.eclipse.swt.internal.gtk.OS._g_main_context_iteration(Na tive Method)
at org.eclipse.swt.internal.gtk.OS.g_main_context_iteration(OS. java:1858)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3110)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:01:05.645
!STACK 0
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:17:39.870
!STACK 0
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:17:39.989
!STACK 0
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:17:41.269
!STACK 0
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:19:06.757
!STACK 0
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:19:06.902
!STACK 0
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:20:20.902
!STACK 0
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:20:21.037
!STACK 0
!ENTRY org.eclipse.wst.sse.ui 4 4 2009-09-24 12:20:21.213
!STACK 0
!ENTRY org.eclipse.help.base 4 0 2009-09-24 13:33:21.580
!MESSAGE An error occured while pre-processing help XHTML document "/org.eclipse.jpt.doc.user/task_inheritance.htm" for search indexing
!STACK 0
at com.sun.org.apache.xerces.internal.dom.DeferredDocumentImpl. setChunkIndex(DeferredDocumentImpl.java:1944)
at com.sun.org.apache.xerces.internal.dom.DeferredDocumentImpl. appendChild(DeferredDocumentImpl.java:644)
at com.sun.org.apache.xerces.internal.parsers.AbstractDOMParser .characters(AbstractDOMParser.java:1191)
at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator. characters(XMLDTDValidator.java:862)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 463)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:807)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:737)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:107)
at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(D OMParser.java:225)
at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl. parse(DocumentBuilderImpl.java:283)
at org.eclipse.help.internal.dynamic.DocumentReader.read(Docume ntReader.java:56)
at org.eclipse.help.internal.dynamic.XMLProcessor.process(XMLPr ocessor.java:49)
at org.eclipse.help.internal.xhtml.DynamicXHTMLProcessor.proces s(DynamicXHTMLProcessor.java:76)
at org.eclipse.help.internal.search.XHTMLSearchParticipant.prep rocess(XHTMLSearchParticipant.java:103)
at org.eclipse.help.search.XMLSearchParticipant.addDocument(XML SearchParticipant.java:301)
at org.eclipse.help.internal.search.HTMLSearchParticipant.addDo cument(HTMLSearchParticipant.java:51)
at org.eclipse.help.internal.search.SearchIndex.addDocument(Sea rchIndex.java:219)
at org.eclipse.help.internal.search.IndexingOperation.addDocume nts(IndexingOperation.java:252)
at org.eclipse.help.internal.search.IndexingOperation.addNewDoc uments(IndexingOperation.java:159)
at org.eclipse.help.internal.search.IndexingOperation.execute(I ndexingOperation.java:106)
at org.eclipse.help.internal.search.LocalSearchManager.updateIn dex(LocalSearchManager.java:620)
at org.eclipse.help.internal.search.LocalSearchManager.ensureIn dexUpdated(LocalSearchManager.java:594)
at org.eclipse.help.internal.search.federated.IndexerJob.run(In dexerJob.java:31)
!ENTRY org.eclipse.help.base 4 0 2009-09-24 13:33:29.752
!MESSAGE An error occured while pre-processing help XHTML document "/org.eclipse.jpt.doc.user/reference013.htm" for search indexing
!STACK 0
!ENTRY org.eclipse.help.base 4 0 2009-09-24 13:33:30.519
!MESSAGE An error occured while pre-processing help XHTML document "/org.eclipse.jpt.doc.user/task_mapping.htm" for search indexing
!STACK 0
Re: Galileo Update Not Working - Eclipse IDE for Java EE Developers 1.2.1.20090918-0703 [message #488096 is a reply to message #488075] Fri, 25 September 2009 10:39 Go to previous messageGo to next message
The update for the Eclipse IDE failed because the metadata for the
update was prematurely made public before the actual jars were available.
Basically, the update isn't quite ready yet,
The bug tracking this is
https://bugs.eclipse.org/bugs/show_bug.cgi?id=290471
I would expect things to work once the release is actually ready and all
the jars and artifacts are synced to all the eclipse mirrors. This could
be a few hours or a day, not quite sure.
-Andrew
a.dessi wrote:
> Hi all,
> But not working.
> Any help?
Re: Galileo Update Not Working - Eclipse IDE for Java EE Developers 1.2.1.20090918-0703 [message #488105 is a reply to message #488096] Fri, 25 September 2009 10:55 Go to previous messageGo to next message
Andrew Niefer:
> -Andrew
Oh nice to hear isnt just my Eclipse :)
So we'll wait for the right update.
Thank You, Andrea
Re: Galileo Update Not Working - Eclipse IDE for Java EE Developers 1.2.1.20090918-0703 [message #488188 is a reply to message #488105] Fri, 25 September 2009 15:23 Go to previous messageGo to next message
Originally posted by: phillipus.nowhere.net
a.dessi wrote:
> Andrew Niefer:
>> all the jars and artifacts are synced to all the eclipse mirrors. This
>> could be a few hours or a day, not quite sure.
>> -Andrew
> Thank You, Andrea
The thing is, this P2 rubbish has never worked properly.
Re: Galileo Update Not Working - Eclipse IDE for Java EE Developers 1.2.1.20090918-0703 [message #488429 is a reply to message #488188] Mon, 28 September 2009 11:47 Go to previous message
Phillipus ha scritto:
> a.dessi wrote:
>> Andrew Niefer:
>>> available.
>>> This could be a few hours or a day, not quite sure.
>>> -Andrew
>> Thank You, Andrea
mhhh still not working. :\
!SESSION 2009-09-28 17:43:26.180
eclipse.buildId=I20090611-1540
java.version=1.6.0_16
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=it_IT
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os linux -ws gtk -arch x86 -product
!ENTRY org.eclipse.equinox.p2.engine 4 4 2009-09-28 17:45:28.579
!MESSAGE An error occurred while collecting items to be installed
Previous Topic:Difference in compilation between ECJ and Javac - BCEL fails to return class fileset
Next Topic:Cell Editing (Table) -- no cell-editor visible?
Current Time: Sat Jul 26 21:17:09 EDT 2025
Powered by FUDForum. Page generated in 0.04914 seconds
