Home » Newcomers » Newcomers » cannot connect to CVS repository
cannot connect to CVS repository [message #487964] Fri, 25 September 2009 02:04 Go to next message
For a BPEL project, I am using Eclipse Ganymede and trying to connect to the CVS repository using following details.
Connection Type : pserver
User :anonymous.
Password : <blank>
Host: dev.eclipse.org
Repository path: /cvsroot/eclipse
I am getting a error message
Error fetching resource list from repository.
Reason:
Could not connect to :pserver:anonymous@dev.eclipse.org:/cvsroot/eclipse:
cannot connect to host: Connection refused: connect.
I would appreciate you help in how do I proceed to get connected to the repository.
Re: cannot connect to CVS repository [message #488054 is a reply to message #487964] Fri, 25 September 2009 08:59 Go to previous messageGo to next message
Ravi wrote:
> Hi, For a BPEL project, I am using Eclipse Ganymede and trying to
> User :anonymous.
The user must not end with a dot. Simply paste this into the 'CVS
Repositories' view:
Dani
> Password : <blank>
> Reason:
> :pserver:mailto:anonymous@dev.eclipse.org:/cvsroot/eclipse:
> the repository.
Re: cannot connect to CVS repository [message #488063 is a reply to message #488054] Fri, 25 September 2009 09:24 Go to previous messageGo to next message
Eclipse Webmaster is currently offline Eclipse WebmasterFriend
>> User :anonymous.
> Repositories' view:
Since the error is 'Connection Refused', I doubt the problem is with the
user name.
You may have a firewall that is preventing access to port 2401 on
dev.eclipse.org. If you can open a command prompt, the following
command will be an indicator:
telnet dev.eclipse.org 2401
If you can connect, typing anything followed by (enter) should yield
this message:
cvs [pserver aborted]: bad auth protocol start
Re: cannot connect to CVS repository [message #488076 is a reply to message #488063] Fri, 25 September 2009 09:48 Go to previous messageGo to next message
>>> User :anonymous.
>> Repositories' view:
> the user name.
Well, it will definitely not work with a "anonymous." ;-)
Dani
> this message:
Re: cannot connect to CVS repository [message #488079 is a reply to message #488076] Fri, 25 September 2009 10:05 Go to previous messageGo to next message
>>>> User :anonymous.
>>> Repositories' view:
>> the user name.
> Dani
Again, if you look closely at his error message, you'll see his username
does not include a "." ;)
Re: cannot connect to CVS repository [message #488090 is a reply to message #488079] Fri, 25 September 2009 10:26 Go to previous message
>>>>> User :anonymous.
>>>> Repositories' view:
>>> the user name.
>> Dani
> username does not include a "." ;)
Indeed :-[
Dani
Previous Topic:No repository found for Galileo
Next Topic:Put breakpoint in *.so fails - "no symbol" , yet objdump shows it?
Current Time: Sat Jul 26 12:10:51 EDT 2025
Powered by FUDForum. Page generated in 1.11290 seconds
