Home » Modeling » UML2 Tools » UML elements already stereotyped in the palette to drag and drop onto the editor
UML elements already stereotyped in the palette to drag and drop onto the editor [message #483657] Wed, 02 September 2009 09:48 Go to next message
Originally posted by: mavieni_nando.yahoo.it
Hi All,
I'm working on a project that will extend UML2Tools. I need help for:
a) use existing uml2tools functionality (primarily the class and component
diagram at the moment)
b) extend uml2tools functionality to add elements described using
stereotypes (for instance a class element already stereotyped with a
custom stereotype). these components will be added to the palette so that
the they can be dragged and dropped onto the editor.
c) not alter uml2tools code so that future versions of uml2tools can be
used without affecting the extension and not requiring recoding of the
extension.
This should obviously take place in a new plugin. I've looked at the
examples in the help files (like helloworld etc) but have not worked out
how to extend plugins like uml2tools.
Please could someone describe how I should set up a plugin to do all this?
thanks in advance,
regards,
Nando
Re: UML elements already stereotyped in the palette to drag and drop onto the editor [message #487792 is a reply to message #483657] Thu, 24 September 2009 08:46 Go to previous message
Answered in http://www.eclipse.org/forums/index.php?t=msg&th=154409& amp;start=0&S=f7b27c8747b32c7bc3b2fa2c38eedfcf
Re: UML elements already stereotyped in the palette to drag and drop onto the editor [message #624878 is a reply to message #483657] Thu, 24 September 2009 08:46 Go to previous message
Previous Topic:After "Create association to..." the propery disappears
Next Topic:Re: UML2 Class Diagram q
Current Time: Fri Jul 25 08:36:19 EDT 2025
Powered by FUDForum. Page generated in 0.07745 seconds
