Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » Framework for Patching EMF Models is available
Framework for Patching EMF Models is available [message #487735] Thu, 24 September 2009 05:37 Go to next message
Hi all,
1. What is it about?
The Framework for Model-independent Differences is based on EMF Compare and transforms emfdiffs to self-contained differences which can be used without the original models.
One example is creating a Patch for models - similar to what we know for text/code.
Tested so far: Ecore models, simple UML models, some domain specific EMF models.
2. Status
The first beta release has just been published. Downloads, tutorial, screencasts, and further documentation at:
http://modeldiff.imm.dtu.dk
3. Epatch vs. Model-independent Differences
Epatch is going to be part of EMF Compare as a patching mechanism.
Although both Epatches and Model-independent Differences are self-contained difference representations, they differ at least in the following points:
- Epatches describe differences exactly (and only) for the models the patch was created for whereas Model-independent Differences are more flexible and, with the use of OCL, are applicable even though the model has changed in the meanwhile.
- Epatches + Metapatches are also able to handle changes in the meta model, model-independent differences don't.
- The Model-independent Differencing Framework is a modular framework allowing different strategies for model element referencing (e.g. id- and condition-based), difference calculation, difference application, and conflict resolution.
4. Feedback wanted
If you experience any problems with our framework, if you miss some feature, or if you find the tool useful and just want to give general feedback:
please write comments on our website or contact us directly using the "Contact us" form.
Thank you for your attention, may our work be helpful for you :-)
Patrick
Re: Framework for Patching EMF Models is available [message #487743 is a reply to message #487735] Thu, 24 September 2009 06:16 Go to previous messageGo to next message
Hi Patrick,
That sounds very interesting. Can you point me to the licensing
information on your web page?
Cheers
/Eike
Patrick Könemann schrieb:
> Hi all,
> for text/code.
> EMF models.
> 2. Status
> following points:
> 4. Feedback wanted
> feedback:
> "Contact us" form.
> Patrick
Re: Framework for Patching EMF Models is available [message #487756 is a reply to message #487743] Thu, 24 September 2009 07:01 Go to previous messageGo to next message
Hi Eike,
You're right, I missed all the license information.
It will be the GPL, I'll add that as soon as possible, hopefully this week.
Best regards and thanks for your interest!
Patrick
On 24-09-2009 12:16, Eike Stepper wrote:
> Hi Patrick,
> Cheers
> /Eike
> http://thegordian.blogspot.com
> http://twitter.com/eikestepper
Re: Framework for Patching EMF Models is available [message #487766 is a reply to message #487756] Thu, 24 September 2009 07:21 Go to previous messageGo to next message
Hi Patrick,
A pity, GPL reduces the usefulness for many Eclipse users ;-(
Cheers
/Eike
> Hi Eike,
> week.
> Patrick
>> Hi Patrick,
>> Cheers
>> /Eike
Re: Framework for Patching EMF Models is available [message #487971 is a reply to message #487766] Fri, 25 September 2009 03:09 Go to previous messageGo to next message
Thank you Eike for pointing that out.
License is changed to EPL now.
Patrick
On 24-09-2009 13:21, Eike Stepper wrote:
> Hi Patrick,
> Cheers
> /Eike
>> Hi Eike,
>> week.
>> Patrick
>>> Hi Patrick,
>>> Cheers
>>> /Eike
Re: Framework for Patching EMF Models is available [message #487997 is a reply to message #487735] Fri, 25 September 2009 05:12 Go to previous messageGo to next message
Hi Patrick,
Thanks for using EMF Compare!
your model independent differences implements sounds promisingly complete
and has nice capabilities, we (EMF Compare team) will have close look to it
Cédric
Patrick Könemann wrote:
> Hi all,
> without the original models. One example is creating a Patch for models -
> similar to what we know for text/code. Tested so far: Ecore models, simple
> 2. Status
> screencasts, and further documentation at: http://modeldiff.imm.dtu.dk
> following points: - Epatches describe differences exactly (and only) for
> model has changed in the meanwhile. - Epatches + Metapatches are also able
> 4. Feedback wanted
> feedback: please write comments on our website or contact us directly
> Patrick
Re: Framework for Patching EMF Models is available [message #488010 is a reply to message #487971] Fri, 25 September 2009 05:58 Go to previous messageGo to next message
--------------020008050300000207000002
Patrick,
Now that sounds promising :). I've got a few questions on this :
1) You have a "compare and create model-independant differences" menu.
Have you taken a look at supporting the same through the Team => create
patch... menu (I don't know if it's feasible, but hey, that'd be nice ^^)?
2) EMF Compare allows comparison of whole resource sets (multiple models
with links between them, models splitted within multiple resources,
....). Do you support multiple resources patches?
3) Would you support say, comparing two versions of a metamodel,
creating the diff file, then applying the changes on instances of that
metamodel?
Laurent Goubet
Obeo
Patrick K
Re: Framework for Patching EMF Models is available [message #488013 is a reply to message #488010] Fri, 25 September 2009 06:15 Go to previous messageGo to next message
Hi Laurent,
Question below...
laurent Goubet schrieb:
> Patrick,
> metamodel?
Wouldn't that be similar to the functionality we expect from the new
Edapt proposal?
Cheers
/Eike
> Laurent Goubet
> Obeo
>> Patrick
>>> Hi Patrick,
>>> Cheers
>>> /Eike
>>>> Hi Eike,
>>>> week.
>>>> Patrick
>>>>> Hi Patrick,
>>>>> Cheers
>>>>> /Eike
Re: Framework for Patching EMF Models is available [message #488022 is a reply to message #488010] Fri, 25 September 2009 06:56 Go to previous messageGo to next message
Hi Laurent,
Sounds reasonable, we'll have a look at that.
Not yet.
It is not our primary goal to support multiple resources (yet), and we don't have any resources for that at the moment.
Still, it is an important issue and I would like to see that feature in the future.
> metamodel?
Nope.
Afaik there are at least two approaches dealing with that:
http://www.uni-koblenz-landau.de/koblenz/fb4/institute/ueber greifend/sre/conferences/wsr/wsr2009/eyshold.pdf
http://www2.computer.org/portal/web/csdl/doi/10.1109/CVSM.20 09.5071722
In the long run, it would of course be nice to have..
Best regards
Patrick
Re: Framework for Patching EMF Models is available [message #488037 is a reply to message #488022] Fri, 25 September 2009 08:21 Go to previous messageGo to next message
--------------010509020207020105070206
Patrick,
Thanks for the answers, I was kind of expecting 3) to be 'no' :p. Edapt
(currently, COPE) is planned to answer this need, but a basic migration
through patches would have been nice ^^.
Cheers!
Laurent Goubet
Obeo
Patrick K
Re: Framework for Patching EMF Models is available [message #489920 is a reply to message #487735] Tue, 06 October 2009 09:44 Go to previous message
Hi all,
we had some compatibility issues with the latest version of EMF Compare 1.0.1, because ReferenceOrderChanges were not recognized by our tool.
The bug is fixed now and a new Release is available at http://modeldiff.imm.dtu.dk (note that we kept the major version 1.0.1 to adapt the version number of EMF Compare).
Cheers
Patrick
On 24-09-2009 11:37, Patrick Könemann wrote:
> Hi all,
> text/code.
> models.
> 2. Status
> following points:
> 4. Feedback wanted
> feedback:
> "Contact us" form.
> Patrick
Re: Framework for Patching EMF Models is available [message #621388 is a reply to message #487735] Thu, 24 September 2009 06:16 Go to previous message
Hi Patrick,
Cheers
/Eike
> Hi all,
> for text/code.
> EMF models.
> 2. Status
> following points:
> 4. Feedback wanted
> feedback:
> "Contact us" form.
> Patrick
Re: Framework for Patching EMF Models is available [message #621389 is a reply to message #487743] Thu, 24 September 2009 07:01 Go to previous message
Hi Eike,
Patrick
> Hi Patrick,
> Cheers
> /Eike
Re: Framework for Patching EMF Models is available [message #621390 is a reply to message #487756] Thu, 24 September 2009 07:21 Go to previous message
Hi Patrick,
Cheers
/Eike
> Hi Eike,
> week.
> Patrick
>> Hi Patrick,
>> Cheers
>> /Eike
Re: Framework for Patching EMF Models is available [message #621395 is a reply to message #487766] Fri, 25 September 2009 03:09 Go to previous message
Patrick
> Hi Patrick,
> Cheers
> /Eike
>> Hi Eike,
>> week.
>> Patrick
>>> Hi Patrick,
>>> Cheers
>>> /Eike
Re: Framework for Patching EMF Models is available [message #621396 is a reply to message #487735] Fri, 25 September 2009 05:12 Go to previous message
Hi Patrick,
Cédric
> Hi all,
> 2. Status
> 4. Feedback wanted
> Patrick
Re: Framework for Patching EMF Models is available [message #621397 is a reply to message #487971] Fri, 25 September 2009 05:58 Go to previous message
Patrick,
metamodel?
Laurent Goubet
Obeo
Patrick K
Re: Framework for Patching EMF Models is available [message #621398 is a reply to message #488010] Fri, 25 September 2009 06:15 Go to previous message
Hi Laurent,
Question below...
> Patrick,
> metamodel?
Edapt proposal?
Cheers
/Eike
> Laurent Goubet
> Obeo
>> Patrick
>>> Hi Patrick,
>>> Cheers
>>> /Eike
>>>> Hi Eike,
>>>> week.
>>>> Patrick
>>>>> Hi Patrick,
>>>>> Cheers
>>>>> /Eike
Re: Framework for Patching EMF Models is available [message #621399 is a reply to message #488010] Fri, 25 September 2009 06:56 Go to previous message
Hi Laurent,
Not yet.
> metamodel?
Nope.
Best regards
Patrick
Re: Framework for Patching EMF Models is available [message #621400 is a reply to message #488022] Fri, 25 September 2009 08:21 Go to previous message
Patrick,
Cheers!
Laurent Goubet
Obeo
Patrick K
Re: Framework for Patching EMF Models is available [message #621431 is a reply to message #487735] Tue, 06 October 2009 09:44 Go to previous message
Hi all,
Cheers
Patrick
> Hi all,
> text/code.
> models.
> 2. Status
> following points:
> 4. Feedback wanted
> feedback:
> "Contact us" form.
> Patrick
Previous Topic:Problem using jet.compile ANT task
Next Topic:EEF code generation failed
Current Time: Sun Jul 27 04:18:56 EDT 2025
Powered by FUDForum. Page generated in 0.07156 seconds
