Home » Eclipse Projects » Subversive » Connector discovery - availability
Connector discovery - availability [message #483638] Wed, 02 September 2009 07:57 Go to next message
Originally posted by: david.balazic.hermes.si.foo
Hi!
The page
http://www.polarion.com/products/svn/subversive/connector_di scovery.php
talk about Connector discovery but it does not work on my setup.
After some inspection, I see the page says "... than it was in versions
before 0.7.8.I20090808-1900". I just installed Eclipse 3.5.0 Java EE IDE
and then the subversive plugin, which is the version
0.7.8.I20090506-1500 (and Update says there is no newer version).
Are the newer releases in some pre final stage (beta, etc...) ?
Where to get them? If they are not final, is it a good idea to use them
in production?
David
My email address has a spamers-confusing addition...
Re: Connector discovery - availability [message #483703 is a reply to message #483638] Wed, 02 September 2009 11:59 Go to previous messageGo to next message
Originally posted by: daniel.thibault.drdc-rddc.gc.ca
"David Balazic" <david.balazic@hermes.si.foo> a
Re: Connector discovery - availability [message #483766 is a reply to message #483638] Wed, 02 September 2009 17:01 Go to previous messageGo to next message
I describe subversion installation for Eclipse 3.5 here:
http://www.vogella.de/articles/EclipseSubversive/article.htm l
Best regards, Lars
http://www.vogella.de/ - Eclipse plugin and Eclipse RCP Tutorials
http://www.twitter.com/vogella - vogella on Twitter
David Balažic wrote:
> Hi!
> The page
> in production?
> Regards,
> David
Re: Connector discovery - availability [message #487240 is a reply to message #483638] Tue, 22 September 2009 11:02 Go to previous messageGo to next message
Now I tried with:
- Eclipse Version: 3.4.2 Build id: M20090211-1700
- Subversive - SVN Team Provider 0.7.8I20090904-1300
Again it does not work.
After restarting Eclipse nothing happens.
After opening the SVN Repository Exploring perspective nothing.
After creating a new repo location, it complains that a connector is missing, but does not offer the installation.
David
PS: I will install the connector manually.
Re: Connector discovery - availability [message #487561 is a reply to message #487240] Wed, 23 September 2009 11:17 Go to previous messageGo to next message
Hello David,
Please, ensure that you don't have already installed connectors, if they
are(maybe old versions), delete them using p2; connectors discovery feature
is activated on first calling to Subversive after Eclipse restart if there
are no connectors features already installed. Do you have any related errors
in Error Log view?
> Now I tried with:
> Regards,
> David
Re: Connector discovery - availability [message #487574 is a reply to message #487561] Wed, 23 September 2009 11:50 Go to previous messageGo to next message
1.) What is p2?
2.) I deleted and reinstalled (unzipped, actually) Eclipse many times
3.) I installed subclipse and it works.
David
Re: Connector discovery - availability [message #487723 is a reply to message #487574] Thu, 24 September 2009 04:55 Go to previous messageGo to next message
Hello David,
As In understand you tried to install Subversive on clean/new Eclipse and it
doesn't work.
The steps are following:
1. Install Subversive from update site, e.g.
http://download.eclipse.org/technology/subversive/0.7/update -site/ (or from
archive update site) for more details please see
http://www.eclipse.org/subversive/downloads.php
2. After Subversive installed call any Subversive finctionality, e.g. open
SVN Repository Exploring perpsective and Connectors Discovery dialog should
appear, if it doesn't appear, please check any related errors in Error Log
view. Connectors Discovery dialog allows to install svn connectors.
Connectors Discovery feature is available starting from 0.7.8.I20090808-1900
version.
Note that Connectors Discovery feature depends on Equinox Provisioning
Repository bundle, you can seach for org.eclipse.equinox.p2.repository
bundle.
> 1.) What is p2?
> Regards,
> David
Re: Connector discovery - availability [message #488255 is a reply to message #483638] Sat, 26 September 2009 18:36 Go to previous messageGo to next message
I'm having similar problems, but i'm trying to move from 3.4 to 3.5 so it's an existing setup. I'm getting no svn related functionality- the <SVN Repository> explorer is empty and the projects have no svnnature -
The log shows ..
org.eclipse.team.core.TeamException: Could not instantiate provider org.eclipse.team.svn.core.svnnature for project.
I've tried numerous installs.
1. Via "Galileo" - Galileo - http://download.eclipse.org/releases/galileo and then Collaboration / Subversive and
2. as you mention above via the update URL you quote - http://download.eclipse.org/technology/subversive/0.7/update -site/
in both cases no connectors are loaded. I tried loading the connectors manually but always the same error in the .log shown above.
info:
Using the JEE version of eclipse ...
vista business .
!SESSION 2009-09-27 00:17:12.840 -----------------------------------------------
eclipse.buildId=I20090611-1540
java.version=1.6.0_15
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_CH
Framework arguments: -product org.eclipse.epp.package.jee.product
Command-line arguments: -os win32 -ws win32 -arch x86 -product org.eclipse.epp.package.jee.product -debug
[Updated on: Sat, 26 September 2009 18:38] by Moderator
Re: Connector discovery - availability [message #488861 is a reply to message #488255] Wed, 30 September 2009 10:12 Go to previous messageGo to next message
Just to say, you may have noticed I was using the Java EE Galileo package ... I ditched it and fetched the latest "classic" eclipse and since then everything works fine with subversive - including connector discovery.
Re: Connector discovery - availability [message #499215 is a reply to message #483638] Fri, 20 November 2009 08:11 Go to previous message
I recently reinstalled eclipse and this time the connector discovery worked.
I used galileo SR1 (Java EE package).
Previous Topic:Subversive & Common Navigator in RCP
Next Topic:Tricky question related to commit / check out action
Current Time: Sun Jul 27 13:41:07 EDT 2025
Powered by FUDForum. Page generated in 0.05508 seconds
