Home » Eclipse Projects » JFace » isBlockSelectionModeEnabled error on code from jface(XML editor wont open anymore, revert confguration wont fx it)
icon9.gif  isBlockSelectionModeEnabled error on code from jface [message #487718] Thu, 24 September 2009 04:50 Go to next message
Hi there,
sometime yesterday, something happend with my eclipse ganymede installation. Suddenly, I cannot open XML files anymore. Eclipse tells me following code.
Using other editors still work, Reverting the configuration even 2 months back does not fix it. Switching workspaces to one, I have not used for 2 weeks does not help either.
Does anyone have an idea besides "install all plugins from ground up on a fresh packageinstall" ?
Message is :
eclipse.buildId=M20090211-1700
java.version=1.6.0_14
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
Error
Thu Sep 24 10:13:28 CEST 2009
Problems occurred when invoking code from plug-in: "org.eclipse.jface".
java.lang.NoSuchMethodError: org.eclipse.wst.sse.ui.StructuredTextEditor.isBlockSelection ModeEnabled()Z
at org.eclipse.wst.sse.ui.StructuredTextEditor$StructuredSelect ionProvider.getSelection(StructuredTextEditor.java:654)
at org.eclipse.ui.internal.editors.quickdiff.QuickDiffRestoreAc tion.getSelection(QuickDiffRestoreAction.java:137)
at org.eclipse.ui.internal.editors.quickdiff.QuickDiffRestoreAc tion.computeLine(QuickDiffRestoreAction.java:169)
at org.eclipse.ui.internal.editors.quickdiff.QuickDiffRestoreAc tion.computeEnablement(QuickDiffRestoreAction.java:122)
at org.eclipse.ui.internal.editors.quickdiff.RevertLineAction.c omputeEnablement(RevertLineAction.java:51)
at org.eclipse.ui.internal.editors.quickdiff.QuickDiffRestoreAc tion.update(QuickDiffRestoreAction.java:98)
at org.eclipse.ui.texteditor.TextEditorAction.<init>(TextEditorAction.java:49)
at org.eclipse.ui.internal.editors.quickdiff.QuickDiffRestoreAc tion. <init>(QuickDiffRestoreAction.java:56)
at org.eclipse.ui.internal.editors.quickdiff.RevertLineAction.<init >(RevertLineAction.java:44)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create Actions(AbstractDecoratedTextEditor.java:1124)
at org.eclipse.ui.editors.text.TextEditor.createActions(TextEdi tor.java:118)
at org.eclipse.wst.sse.ui.StructuredTextEditor.createActions(St ructuredTextEditor.java:1171)
at org.eclipse.ui.texteditor.AbstractTextEditor.createPartContr ol(AbstractTextEditor.java:3362)
at org.eclipse.ui.texteditor.StatusTextEditor.createPartControl (StatusTextEditor.java:53)
at org.eclipse.ui.texteditor.AbstractDecoratedTextEditor.create PartControl(AbstractDecoratedTextEditor.java:394)
at org.eclipse.wst.sse.ui.StructuredTextEditor.createPartContro l(StructuredTextEditor.java:1334)
at org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:217)
at org.eclipse.ui.part.MultiPageEditorPart.addPage(MultiPageEdi torPart.java:187)
at org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.addSourcePage(XMLMultiPageEditorPart.java:440)
at org.eclipse.wst.xml.ui.internal.tabletree.XMLMultiPageEditor Part.createPages(XMLMultiPageEditorPart.java:612)
at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(Mu ltiPageEditorPart.java:310)
at org.eclipse.ui.internal.EditorReference.createPartHelper(Edi torReference.java:661)
at org.eclipse.ui.internal.EditorReference.createPart(EditorRef erence.java:428)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(Workb enchPartReference.java:594)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:30 6)
at org.eclipse.ui.internal.presentations.PresentablePart.setVis ible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFo lder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrd er.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresen tation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelecti on(PartStack.java:1256)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.jav a:1209)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:16 08)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:499)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103 )
at org.eclipse.ui.internal.PartStack.add(PartStack.java:485)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112 )
at org.eclipse.ui.internal.EditorSashContainer.addEditor(Editor SashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorA reaHelper.java:217)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAre aHelper.java:207)
at org.eclipse.ui.internal.EditorManager.createEditorTab(Editor Manager.java:779)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:678)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:639)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched( WorkbenchPage.java:2817)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2729)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPag e.java:2721)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.j ava:2673)
at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:70)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2668)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2652)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2643)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:646)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:605)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:318)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInE ditor(EditorUtility.java:160)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:22 8)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:20 7)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchR un(SelectionDispatchAction.java:274)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(Selec tionDispatchAction.java:250)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActio nGroup.handleOpen(PackageExplorerActionGroup.java:363)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$ 5.open(PackageExplorerPart.java:603)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:820)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:48)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:17 5)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:818)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:1079)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:1183)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:263)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:257)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:297)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3823)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3422)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 549)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
icon9.gif  Re: isBlockSelectionModeEnabled error on code from jface [message #488320 is a reply to message #487718] Mon, 28 September 2009 01:42 Go to previous message
For what it's worth, I've just noticed I'm getting the exact same error. I'm working on a Java project that has an XML file in it, and I just noticed that when I opened the XML file it came up in the plain text editor and not the XML editor. The file is very simple and rarely editted, so I hadn't actually noticed I wasn't getting the syntax highlighting and other goodies of the XML editor; hence I have no idea how long this has been happening.
Anyway, I'm getting the same symptoms as the OP. My log file shows the same stack trace, and the other editors (Java and plain text) that I use are working fine. I running on the same type of system (Win32 / x86) as the OP.
One factor that could be important in this: my installed version of the XML editor and WST core / UI / XML core packages is the latest from the WTP update site (version 3.1.0), rather than the version offered by the Ganymede update site (version 3.0.4).
No idea what the problem is, and since I don't really care (I can survive without the XML editor for now) I'm not going to spend the time looking for a workaround. Just putting this out there for the record.
Matt.
[Updated on: Mon, 28 September 2009 01:44] by Moderator
Previous Topic:auto-sizing column width?
Next Topic:TreeViewer: cancelling expansion
Current Time: Sat Jul 26 19:23:56 EDT 2025
Powered by FUDForum. Page generated in 0.43872 seconds
