[PDE Build] Ant customcallback not working when plugin is packaged [message #487230] |
Tue, 22 September 2009 10:15  |
--------------030902070909000907080600
i got some troubles to have my pde build working.
Here is my problem :
i need to post compile files when i want to export my project as plugin.
so i created a customcallback build file, and referenced it in my
build.properties file.
this custom call back file calls a task that resides in another plugin,
says builderplugin.
so my task looks like this :
<target name="post.compile.@dot">
<taskdef name="mytask" classname="org.eclipse.BuilderTask">
</taskdef>
<mytask project="." target="${target.folder}"/>
</target>
i packaged the Buildertask inside a jar inside the builderplugin.
Now, when i tried to export my project with the customcallback, it only
works in runtime environment, with the builderplugin in workspace.
in a fresh install, with the builderplugin installed, it does not work,
i got the following :
[subant] Failure for target 'post.compile.@dot' of:
/tmp/build/N200909221546/eclipse/plugins/org.eclipse.emf.eef .codegen/build.acceleo
[build] [subant] The following error occurred while executing
this line:
[build] [subant]
/tmp/build/N200909221546/eclipse/plugins/org.eclipse.emf.eef .codegen/build.acceleo:80:
taskdef class org.eclipse.BuilderTask cannot be found
Any hints ?
thanks
name="stephane_bouchet.vcf"
filename="stephane_bouchet.vcf"
begin:vcard
fn;quoted-printable:St=C3=A9phane Bouchet
n;quoted-printable:Bouchet;St=C3=A9phane
org:Obeo
adr;quoted-printable:;;;Rez=C3=A9;;44400;France
email;internet:stephane.bouchet@obeo.fr
x-mozilla-html:FALSE
version:2.1
end:vcard
--------------030902070909000907080600--
Re: [PDE Build] Ant customcallback not working when plugin is packaged [message #487625 is a reply to message #487230] |
Wed, 23 September 2009 15:19   |
The org.eclipse.ant.core.antRunner application that PDE/Build runs in
will automatically setup classpaths for ant contributions that are
declared using an extension point.
If you don't already, try having your builderplugin define this
extension point, something like:
<extension point="org.eclipse.ant.core.antTasks">
<antTask
library="builderplugin-ant.jar"
name="mytask"
class="org.eclipse.BuilderTask" />
</extension>
In this case, since the antRunner sets everything up for you, you
probably won't even need the <taskdef/>
-Andrew
Stéphane Bouchet wrote:
> says builderplugin.
> </taskdef>
> </target>
> this line:
> [build] [subant]
> Any hints ?
> thanks
Re: [PDE Build] Ant customcallback not working when plugin is packaged [message #488104 is a reply to message #487625] |
Fri, 25 September 2009 10:54  |
--------------080206050600050208060502
Hi Andrew,
thanks for the pointers.
Actually, i moved into something different, that is to call my custom
builder with <eclipse.incrementalBuild /> task.
it works better ;)
Andrew Niefer a
FUDForum. Page generated in 0.29082 seconds
