Home » Eclipse Projects » Remote Application Platform (RAP) » Problem about Focus on Combo
Problem about Focus on Combo [message #485338] Fri, 11 September 2009 08:24 Go to next message
Originally posted by: sjungjariyanonn.fininfo.fr
I have 2 combos, the first one is filled and enabled, the second one is
empty and disabled.
There is a listener on the first one. When an item is selected, we fill
the second combo and we enable it.
Then we give the focus to the first combo but it seems that it doesn't
work. The focus remains on the second combo!
Does someone know something about it?
Thank you in advance for your help.
JUNG
Re: Problem about Focus on Combo [message #485623 is a reply to message #485338] Mon, 14 September 2009 04:18 Go to previous messageGo to next message
Hi Jung,
which version of RAP are you using? Can you provide a small snippet that
demonstrate the problem?
Best,
Ivan
JUNG wrote:
> Hi, I have 2 combos, the first one is filled and enabled, the second
> one is empty and disabled. There is a listener on the first one. When
> an item is selected, we fill the second combo and we enable it.
> work. The focus remains on the second combo! Does someone know
> something about it?
> Thank you in advance for your help. Best regards,
> JUNG
Re: Problem about Focus on Combo [message #487456 is a reply to message #485623] Wed, 23 September 2009 06:24 Go to previous messageGo to next message
Hello Ivan,
The version used is RAP 1.2.0.R.
Here is a sample code showing our problem.
At the beginning, when we select "2" in the first Combo,
the second Combo is filled and the focus remains on it.
If we select again "2", the focus is correctly put on the first Combo.
Thank you.
JUNG
public class Testtesttest
public Testtesttest()
Display display = PlatformUI.createDisplay();
final Shell shell = new Shell(display);
shell.setSize(300, 300);
shell.setLayout(new RowLayout());
shell.setText("Composite Example");
final Composite parent = new Composite(shell, SWT.NONE);
GridLayout gridLayout = new GridLayout();
gridLayout.numColumns = 4;
parent.setLayout(gridLayout);
Composite container = new Composite(parent, SWT.BORDER);
GridLayout layout = new GridLayout();
gridLayout.numColumns = 1;
container.setLayout(layout);
GridData gridData = new GridData(SWT.LEFT, SWT.FILL, true, false);
container.setLayoutData(gridData);
final Label fictif = new Label(container, SWT.NONE);
fictif.setLayoutData(gridData);
fictif.setText("test");
// First combo
final Combo combo1 = new Combo(container, SWT.NONE);
combo1.setLayoutData(gridData);
combo1.add("0");
combo1.add("1");
combo1.add("2");
final Text text = new Text(container, SWT.NONE);
text.setLayoutData(gridData);
final Combo combo2 = new Combo(container, SWT.NONE);
combo2.setLayoutData(gridData);
combo2.setEnabled(false);
combo1.addSelectionListener(new SelectionListener()
public void widgetDefaultSelected(SelectionEvent e)
// TODO Auto-generated method stub
public void widgetSelected(SelectionEvent e)
if (combo1.getSelectionIndex() == 2)
combo2.setEnabled(true);
fictif.setEnabled(false);
combo2.add("aaaaaaaaaa");
combo2.add("bbbbbbbbbbbbb");
combo2.add("cccccccccccccccccccccccccccc");
combo2.select(1);
combo2.pack();
combo1.setFocus();
shell.open();
while (!shell.isDisposed())
if (!display.readAndDispatch())
display.sleep();
display.dispose();
Re: Problem about Focus on Combo [message #487566 is a reply to message #487456] Wed, 23 September 2009 11:29 Go to previous message
Hi JUNG,
we have recently fixed the bug:
289398: [Combo] Highlighting misbehaviour while setting selection
programmatically
https://bugs.eclipse.org/bugs/show_bug.cgi?id=289398
Your problem is not reproducible any more with CVS HEAD.
Best,
Ivan
JUNG wrote:
> Hello Ivan,
> Here is a sample code showing our problem. At the beginning, when we
> select "2" in the first Combo, the second Combo is filled and the
> Thank you.
> JUNG
> // First combo
> combo1.add("0");
> combo1.add("1");
> combo1.add("2");
> @Override
> @Override
> combo2.select(1);
> combo2.pack();
> combo1.setFocus();
> shell.open();
> display.sleep();
> } display.dispose();
Previous Topic:[ANN] CVS HEAD requires new dependency
Next Topic:FileUpload
Current Time: Sat Jul 19 10:04:41 EDT 2025
Powered by FUDForum. Page generated in 0.03735 seconds
