[QVTo] runtime operation resolution [message #487295] |
Tue, 22 September 2009 13:04  |
I have started using QVTo in our application and I wasn't able
to understand if QVTo supported runtime polymorphism for
operations, the way Java does.
Basically I have inheritance in my model and I want to define
a mappning operation on the base type and also the subtype.
I want that at the time of executing the transformation, QVTo
should decide the correct operation to execute depending
on the type of the model object.
Also is it possible that I contribute the mapping operation
of the sub-type in another transformation, that is contributed
through the QVTo transformation extension point, and QVTo
will still be able to resolve this?
Re: [QVTo] runtime operation resolution [message #487323 is a reply to message #487295] |
Tue, 22 September 2009 14:37   |
Originally posted by: dvorak.radek.gmail.com
Hi dhiraj,
See comments in-lined bellow.
/Radek
> I want that at the time of executing the transformation, QVTo should
Yes, QVTO supports this. The OMG specification refers to this as virtual
invocation
semantics. See section '8.2.1.15 MappingOperation' for details,
specifically
the paragraph 'Executing a mapping operation'.
> through the QVTo transformation extension point, and QVTo will still be
Yes, you can do it with QVTO, if you extend the transformation where you
want
to contribute a mapping for a specific type.
See OMG specification, section '8.2.1.1 OperationalTransformation', there
are examples
about extending imported transformation at the end of the section.
Beware of signature compatibility of the extending and extended
transformations.
Note, it generally works for any imported transformation (the extension
point just publishes
a qvto compilation unit (file) under a known qualified name, which can be
imported).
Re: [QVTo] runtime operation resolution [message #487457 is a reply to message #487449] |
Wed, 23 September 2009 06:28  |
Hi dhiraj,
- virtual invocation is supported since 1.0.0
- extending transformation is supported since 2.0.0
I recommend to switch to the latest 2.0.0 release as we have made a
significant
step forward.
/Radek
On Wed, 23 Sep 2009 12:02:19 +0200, Dhiraj <dhiraj@gmail.com> wrote:
> Hi Radek,
> Thanks for the detailed information. But is this available in QVTO 1.0?
> I tried writing a transformation which extends another transformation,
> and the QVTO editor shows a warning saying 'Transformation model usages
> not supported'.
> Does this mean that the QVTO 1.0 runtime does not support this facility?
FUDForum. Page generated in 0.28366 seconds
