Home » Language IDEs » PHP Development Tools (PDT) » Xdebug with M3!!!
| Xdebug with M3!!! [message #48680] |
Fri, 31 August 2007 22:25   |
Eclipse User  |
Hurray!!!! :)
Xdebug plugin is finally integrated into PDT starting M3 now. I know a
number of you would know by now, but in case some of you out there
haven't downloaded M3, do it now!! :) As it integrates *beautifully*
within PDT.
I'd like to take the chance to Thank Dave Kelsey, and the other plugin
contributers very much for the enormous amount of effort that was put
into this plugin. And also for the great, instant, constant and patient
support Dave has done to it. Thanks again man!
The truth is I haven't tested it fully yet (the implementation on M3 i
mean). But my first question is already here: Should the "Run" not work
when using a script debug using xdebug. I mean when we used to install
the plugin manually, the option of debugging with xdebug was not present
in the run dialog. Is it the same reason why we can use it to run?
should we use the zend debugger for running?
Ali
| Re: Xdebug with M3!!! [message #48736 is a reply to message #48680] |
Sat, 01 September 2007 04:05    |
Eclipse User  |
Hi Ali, you are correct, run doesn't work when you select XDebug as the
debugger. The workaround currently is to switch the launch to the zend
debugger (or create a separate launch). I hope to get a fix into CVS soon.
Dave Kelsey
Ali B. wrote:
> Hurray!!!! :)
> within PDT.
> Cheers,
> Ali
| Re: Xdebug with M3!!! [message #48796 is a reply to message #48736] |
Sat, 01 September 2007 14:31    |
Eclipse User  |
Having the XDebug enabled in myphp.ini for a long time now, I seem to
have forgotten how to enable the zend debugger back.
I would assume that it is possible to have both debuggers enabled in the
same php.ini, am I correct? if so, could anyone tell me how to enable
the zend debugger back to work side by side with xdebug?
Ali
> Dave Kelsey
> Ali B. wrote:
>> Hurray!!!! :)
>> within PDT.
>> patient support Dave has done to it. Thanks again man!
>> work when using a script debug using xdebug. I mean when we used to
>> install the plugin manually, the option of debugging with xdebug was
>> not present in the run dialog. Is it the same reason why we can use it
>> to run? should we use the zend debugger for running?
>> Cheers,
>> Ali
| Re: Xdebug with M3!!! [message #49828 is a reply to message #48796] |
Sun, 09 September 2007 14:09    |
Eclipse User  |
Originally posted by: joshbenner.gmail.com
According to Xdebug documentation, it cannot run alongside the Zend
Debugger.
http://www.xdebug.org/docs/install
> Thanks
> Ali
>> soon.
>> Dave Kelsey
>> Ali B. wrote:
>>> Hurray!!!! :)
>>> a number of you would know by now, but in case some of you out there
>>> within PDT.
>>> plugin contributers very much for the enormous amount of effort that
>>> was put into this plugin. And also for the great, instant, constant
>>> and patient support Dave has done to it. Thanks again man!
>>> i mean). But my first question is already here: Should the "Run" not
>>> it to run? should we use the zend debugger for running?
>>> Cheers,
>>> Ali
| Re: Xdebug with M3!!! [message #50575 is a reply to message #48736] |
Tue, 11 September 2007 21:38   |
Eclipse User  |
I have just downloaded RC1 and xdebug works on run now as well. Thank
you Dave.
Ali
> Dave Kelsey
> Ali B. wrote:
>> Hurray!!!! :)
>> within PDT.
>> Cheers,
>> Ali
 Current Time: Tue Nov 04 02:49:37 EST 2025
 Powered by  FUDForum. Page generated in 0.08410 seconds
